grandhougday Posted June 1, 2013 Posted June 1, 2013 I need a lisp to explode a Cylindrical Solid shape. in fact explode 2 times. first it become to surface and after another explosion it become to two circles. then i want to do something with that circles. How i can do this? in VBA by Explode Function by default return objects: explodedObjects = BlockObj.Explode but how is it in lisp? Quote
Lee Mac Posted June 1, 2013 Posted June 1, 2013 (vlax-invoke [color=green][/color] 'explode) Will return a list of exploded objects (where is the object to be exploded); note that this method will retain the original object. Quote
pBe Posted June 1, 2013 Posted June 1, 2013 or (defun c:demo (/ qf) (setq qf (getvar 'Qaflags ) ) (setvar 'qaflags 1) (if (setq ss (ssget "_:L" '((0 . "3DSOLID")))) (progn (command "_explode" ss "") (command "_explode" "_Previous" "") (sssetfirst nil (ssget "P" '((0 . "[color=blue][b]CIRCLE"[/b][/color][color=black]))))[/color] (setvar 'qaflags qf) ) ) ) Quote
vanowm Posted March 12, 2015 Posted March 12, 2015 Hello. I'm trying pBe's code on ruled surface: (defun c:demo (/ qf) (setq qf (getvar 'Qaflags ) ) (setvar 'qaflags 1) (if (setq ss (ssget '((100 . "AcDbPolygonMesh")))) (progn (command "_explode" ss "") (command "_explode" "_Previous" "") (sssetfirst nil (ssget "P" '((0 . "3DFACE")))) (setvar 'qaflags qf) ) ) ) but it returns Command: demoSelect objects: 1 found Select objects: _explode Select objects: 1 found Select objects: Command: _explode Select objects: _Previous 12 found 12 were not able to be exploded. Select objects: None found. Command: 1 Any ideas how I can retrieve 3dface's out of a ruled surface without possibly affecting the original surface? Thank you. Quote
pBe Posted March 12, 2015 Posted March 12, 2015 (defun c:demo (/ qf) (setq qf (getvar 'Qaflags ) ) (setvar 'qaflags 1) (if (setq ss (ssget '((100 . [b]"Mesh"[/b])))) (progn [b] (command "_copy" ss "" "0,0" "@" "")[/b] (command "_explode" ss "") (sssetfirst nil (ssget "P" '((0 . "3DFACE")))) (setvar 'qaflags qf) ) ) ) Quote
vanowm Posted March 13, 2015 Posted March 13, 2015 Thank you very much! The problem was (command "_explode" "_Previous" "") Removed that line and it worked. Copy object on top of itself also worked, thank you. P.S. rulesurf creates mesh with (100 . "AcDbPolygonMesh") Quote
3dwannab Posted December 4, 2024 Posted December 4, 2024 (edited) Here's the program I wrote based on @pBe's code. See header for the additions. (vl-load-com) ;; ;; 3dwannab_Explode.lsp ;; ;; WHAT THIS DOES: ;; - Redefines the explode command 'X'; ;; - Avoids exploding hatches; ;; - keeps the exploded objects selection set afterwards; ;; - If no valid objects need to be exploded the original selection is retained; ;; - Outputs to the commandline, info on the count for exploded and not so exploded objects; ;; - Undo handling. ;; ;; ABOUT ;; Written on 2024.12.03 by 3dwannab. ;; Based on pBe's code found here: https://www.cadtutor.net/forum/topic/46380-retrieve-objects-after-explode/#findComment-379156 ;; (defun c:X (/ *error* acDoc cntExploded cntExplodedNot ss ssExploded ssSel var_cmdecho var_qaflags) (defun *error* (errmsg) (and acDoc (vla-EndUndoMark acDoc)) (and errmsg (not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " errmsg " >>\n")) ) (setvar 'cmdecho var_cmdecho) (setvar 'qaflags var_qaflags) ) ;; Start the undo mark here (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object))) (or (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc)) ;; Get any system variables here (setq var_cmdecho (getvar "cmdecho")) (setq var_qaflags (getvar "Qaflags")) (setvar 'cmdecho 0) (setvar 'qaflags 1) ;; Helps to get the selection set after the explode command. ;; Initialize the merged selection set (setq ssSel (ssadd)) ; Start with an empty selection set (setq ss nil) ; Start with an empty selection set (setq ssExploded nil) ; Start with an empty selection set (if (setq ss (ssget "_:L" '((0 . "~HATCH")))) (progn (command "_explode" ss "") ;; Explode the selected objects (setq ssExploded (ssget "P")) ;; Get the exploded items. QAFLAGS variable must be set to 1. (setq ssSel (_mergeSS ss ssExploded)) ;; Merge the two selection sets. ;; If there were no exploded items, make sure ssExploded is an empty set (if (not ssExploded) (progn (setq ssExploded (ssadd)) ;; Regen if the selection set ssSel is valid ;; Use this to select all objects again if there was no valid objects to explode (if ssSel (progn (sssetfirst nil ssSel) (command "_.regen") ) ) ) ;; Select the exploded objects only (sssetfirst nil ssExploded) ) ;; Count objects not exploded and exploded (setq cntExplodedNot (abs (- (sslength ssSel) (sslength ssExploded)))) (setq cntExploded (abs (sslength ssExploded))) ;; Print the results (princ (strcat "\n" (itoa cntExploded) (if (or (= cntExploded 0) (> cntExploded 1)) " objects" " object") " exploded")) (princ (strcat "\n" (itoa cntExplodedNot) (if (or (= cntExplodedNot 0) (> cntExplodedNot 1)) " objects" " object") " not exploded")) ) ) ;; if ss (vla-EndUndoMark acDoc) (*error* nil) (princ) ) ;; Merges two selection sets. Checks each entity first before adding it to the newly created selection set. ;; Returns new selection set. (defun _mergeSS (ss1 ss2 / en i ssNew) (setq ssNew (ssadd)) ; Start with an empty selection set ;; Check and merge the first selection set (ss1) (if ss1 (progn (setq i 0) (while (< i (sslength ss1)) ; Loop through ss1 (setq en (ssname ss1 i)) ; Get the object from ss1 (if (entget en) ; Check if the object is valid (setq ssNew (ssadd en ssNew)) ; Add valid object to merged set ) (setq i (1+ i)) ; Increment the counter ) ) ) ;; Check and merge the second selection set (ss2) (if ss2 (progn (setq i 0) (while (< i (sslength ss2)) ; Loop through ss2 (setq en (ssname ss2 i)) ; Get the object from ss2 (if (entget en) ; Check if the object is valid (setq ssNew (ssadd en ssNew)) ; Add valid object to merged set ) (setq i (1+ i)) ; Increment the counter ) ) ) ssNew ; Return the merged selection set ) (princ "\n3dwannab_Explode.lsp is loaded. Type 'explode' to run...") ; (c:X) ;; Unblock for testing Edited December 4, 2024 by 3dwannab Quote
