Does anyone know and can indicate some routine that allows, in a selection of text, to filter/separate the letters/numbers?
What exactly are you attempting to do? Please provide an example.
Here is my function:
[color=GREEN];; Split String  -  Lee Mac[/color]
[color=GREEN];; Splits a string into a list of text and numbers[/color]
([color=BLUE]defun[/color] LM:splitstring ( str )
       ([color=BLUE]lambda[/color] ( l )
           ([color=BLUE]read[/color]
               ([color=BLUE]strcat[/color] [color=MAROON]"("[/color]
                   ([color=BLUE]vl-list->string[/color]
                       ([color=BLUE]apply[/color] '[color=BLUE]append[/color]
                           ([color=BLUE]mapcar[/color]
                               ([color=BLUE]function[/color]
                                   ([color=BLUE]lambda[/color] ( a b c )
                                       ([color=BLUE]cond[/color]
                                           (   ([color=BLUE]=[/color] 92 b)
                                               ([color=BLUE]list[/color] 32 34 92 b 34 32)
                                           (   ([color=BLUE]or[/color] ([color=BLUE]<[/color] 47 b 58)
                                                   ([color=BLUE]and[/color] ([color=BLUE]=[/color] 45 b) ([color=BLUE]<[/color] 47 c 58) ([color=BLUE]not[/color] ([color=BLUE]<[/color] 47 a 58)))
                                                   ([color=BLUE]and[/color] ([color=BLUE]=[/color] 46 b) ([color=BLUE]<[/color] 47 a 58) ([color=BLUE]<[/color] 47 c 58))
                                               ([color=BLUE]list[/color] b)
                                           (   ([color=BLUE]list[/color] 32 34 b 34 32))
                               ([color=BLUE]cons[/color] [color=BLUE]nil[/color] l) l ([color=BLUE]append[/color] ([color=BLUE]cdr[/color] l) '(( )))
                   [color=MAROON]")"[/color]
       ([color=BLUE]vl-string->list[/color] str)
_$ (LM:splitstring "ab12c-3.1de4.2f56")
("a" "b" 12 "c" -3.1 "d" "e" 4.2 "f" 56)
ReMark,
I appreciate your interest.
In particular, selecting a set of texts, I intend to separate/ filter letters/numbers. I want this filtering to then be able to manipulate their selection, including separate into layers.
Attached a picture.
(defun kg:SsgetFilterReal ()
   (1 . "~*[~-.0-9]*") ; only minus signs, decimal points and numbers allowed
   (1 . "*`.*")        ; there must be one decimal point
   (1 . "~*`.*`.*")    ; only one decimal point allowed
   (-4 . "<OR")
     (1 . "~*-*")      ; there is no minus sign
     (-4 . "<AND")
       (1 . "-*")      ; the minus sign must be the first character
       (1 . "~*-*-*")  ; only one minus sign allowed
     (-4 . "AND>")
   (-4 . "OR>")
(defun c:Comp (/ ent ss i lst)
 (if
   (and
     (setq ent (entsel "\nPlease select a text for style, layer and text height filtering: "))
     (setq ent (entget (car ent)))
     (or
       (equal '(0 . "TEXT") (assoc 0 ent))
       (prompt "\nNot a text ")
     (or
       (setq ss
         (ssget
           "_X"
           (vl-list*
             '(0 . "TEXT")
             (assoc 7 ent)        ; style of digit text
             (assoc 8 ent)        ; selected layer name
             (assoc 40 ent)       ; selected text height
             (assoc 410 ent)      ; current tab only
             ;; numerical text filtering:
		  (kg:SsgetFilterReal)
       (prompt "\nNo selection ")
   (mapcar
     '(lambda (a) (cdr (assoc 1 (entget a))))
       (setq lst (cons (ssname ss (setq i (1- i))) lst))
Ah - I see that I misunderstood your question.
See this post:
http://www.theswamp.org/index.php?topic=35485.msg407075#msg407075
Lee,
I appreciate the attention.
I've been checking. From what I can understand and test, the routine can check and filter integers and real numbers in different steps. However, I intended for scanning to be simultaneously isolating all the numbers of letters, or vice versa.
It is also critical that the result of the filtering is available in a selection to be able to assign a specific layer.
 (if
   (and
I don't get it teknomatika, what are you targeting?
pBe,
This is part of the code referenced by lee mac.
From what I could try, as I explained, it can filter at different steps, integers and real but only displays the result in the prompt.
I intend that the filtering simultaneously and which is the result of a selection becomes available, allowing the manipulation / editing, such as assigning a specific layer.
In summary, the proposed target is to separate / isolate letters / numbers (real or integer)
The link I provided is not a ready-made solution for you to copy/paste for your task; I am simply pointing you in the right direction and providing the tools to help you to write your own program.
Yes, of course.
Well, for now this solution will help me.
Not exactly the solution you want, because the filter must include all entities text, even if with different properties (style, layer, color, height, etc..).
;;by:roy_043
;; http://www.theswamp.org/index.php?topic=35485.msg407075#msg407075
(defun kg:SsgetFilterNum ()
   (-4 . "<OR")
     (-4 . "<AND")
     (-4 . "AND>")
   (-4 . "OR>")
(defun kg:SsgetFilterInt ()
   (1 . "~*[~-0-9]*")  ; only minus signs and numbers allowed
   (-4 . "<OR")
     (-4 . "<AND")
     (-4 . "AND>")
   (-4 . "OR>")
   (-4 . "<OR")
     (-4 . "<AND")
     (-4 . "AND>")
   (-4 . "OR>")
(defun FilterNum (/ ent ss i lst)
 (if
   (and
     (or
     (or
       (setq ss
         (sssetfirst nil (ssget
           "_X"
           (vl-list*
             '(0 . "TEXT")
		  (kg:SsgetFilterNum)
   (mapcar
(defun FilterReal (/ ent ss i lst)
 (if
   (and
     (or
     (or
       (setq ss
           "_X"
           (vl-list*
             '(0 . "TEXT")
   (mapcar
(defun FilterInt (/ ent ss i lst)
 (if
   (and
     (or
     (or
       (setq ss
           "_X"
           (vl-list*
             '(0 . "TEXT")
		  (kg:SsgetFilterInt)
   (mapcar
(defun c:FILTEXT (/ gets)
(initget 1 "N I R")
(setq gets (getkword "\nFilter Mode: (N)umeric; (I)inters; (R)eal; : "))
(cond
((= gets "N")
(FilterNum)
((= gets "I")
(FilterInt)
((= gets "R")
(FilterReal)
(repeat (setq i (sslength [b][color=blue](setq ss (cadr ss))[/color][/b]))
And you can easily achieved this by using a lot less filter for DXF 1 [me thinks/ less codes that is]. but then again, I'm not sure unless we see what are the "other" conditions.
I'm just saying :)
pBe,
Thanks for your attention.
