homer93 Posted June 23, 2013 Share Posted June 23, 2013 hi im trying to make some ribs for a plane wing. im having problems with just one of the ribs. ive got a plane then doing surface intersect. for some reason on this plane it isnt drawing the sketch line right. not sure why. it should be on the brown line, most of the sketch is right its just this front section of it. any ideas whats wrong? thanks rob Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 24, 2013 Share Posted June 24, 2013 What version of SWx? Can you attach the file here? Can you reproduce the behavior in a new file? Quote Link to comment Share on other sites More sharing options...
homer93 Posted June 24, 2013 Author Share Posted June 24, 2013 im using solidworks 2012 ive made a new assembly for the problem. its just got to parts that aernt working in. only problem is the file is still too big. how else can i add the file? Quote Link to comment Share on other sites More sharing options...
homer93 Posted June 24, 2013 Author Share Posted June 24, 2013 https://dl.dropboxusercontent.com/u/8058927/sketch_problem.SLDASM.zip uploaded it elsewhere Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 24, 2013 Share Posted June 24, 2013 Of course an assembly file (*.sldasm) is useless without the individual part files (*.sldprt) are they in that zip? You can dramatically reduce a file size by rolling up the feature tree before saving and zipping. Quote Link to comment Share on other sites More sharing options...
homer93 Posted June 25, 2013 Author Share Posted June 25, 2013 The parts are saved virtually aren't they? Quote Link to comment Share on other sites More sharing options...
