whilin Posted June 25, 2013 Share Posted June 25, 2013 I am trying to writing a small lisp to do following thing between two polylines: It must: select first polyline divide it in n parts -> get computed points. From each point, draw a segments perpendicular to the first polyline that stops at the second polyline. Every two segments, break the drawn segment in two parts and delete one part. I don't know how to start writing my lisp Thank you a lot. Quote Link to comment Share on other sites More sharing options...
whilin Posted June 25, 2013 Author Share Posted June 25, 2013 I FOUND this autolisp but it doesn't work in AUTOCAD 2014: (defun C:PLWEB () (command "_.undo" "_begin") (setq poly1 (car (entsel "\nSelect first Polyline: ")) poly2 (car (entsel "\nSelect second Polyline: ")) segs (getint "\nDivide first Polyline into how many segments? ") seglen ; length of segment along 1st Pline (/ (vlax-curve-getDistAtParam poly1 (vlax-curve-getEndParam poly1) ); end getDist segs ); end getDist and length1 inc 0 osm (getvar 'osmode) ); end setq (setvar 'osmode 0) (repeat (1+ segs) (command "_.line" (vlax-curve-getPointAtDist poly1 (* seglen inc); position along 1st Pline ); end getPoint "per" (vlax-curve-getClosestPointTo poly2 (getvar 'lastpoint) ); end getClosest "" ; end line ); end command (setq inc (1+ inc)) ); end repeat (setvar 'osmode osm) (command "_.undo" "_end") ); end defun This is the error: Specify first point: Specify next point or [undo]: per to No Endpoint found for specified point. Point or option keyword required. ; error: Function cancelled Specify next point or [undo]: Hope it helps. Thank you again Quote Link to comment Share on other sites More sharing options...
