cordill Posted July 5, 2013 Share Posted July 5, 2013 Hello everybody! This is mine dynablock of Flat reinforcement cage. When you change the height of the walls, height of a flat frame should change so that the penultimate transverse rod was located at the distance not less than 50 and not more than 200mm from the last (upper rod). Now I could define this range, but there are some height of the wall in which the unit produces a range of 50 to 320mm. 320mm is more than a step transverse reinforcement 200mm, so the work of the unit is not entirely correct. Please help to achieve the range of 50-200mm. Thanks in advance! Flat reinforcement cage.dwg Quote Link to comment Share on other sites More sharing options...
