automaticad Posted July 5, 2013 Share Posted July 5, 2013 How to draw the curve exactly similar such as the attached image in AutoCAD? Quote Link to comment Share on other sites More sharing options...
alanjt Posted July 5, 2013 Share Posted July 5, 2013 Looks to be a spline to me. eg. Quote Link to comment Share on other sites More sharing options...
automaticad Posted July 6, 2013 Author Share Posted July 6, 2013 What is meant by "375" and "325"? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 6, 2013 Share Posted July 6, 2013 Those are unitless "weights" added to the curve to control curvature in SolidWorks. Quote Link to comment Share on other sites More sharing options...
automaticad Posted July 7, 2013 Author Share Posted July 7, 2013 How to draw the curve using the CV method? Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 7, 2013 Share Posted July 7, 2013 Isn't the Control Vertices available on the Grip menu? Are you really using AutoCAD 2000 or did you fail to update your Profile? Options may vary depending on the version of AutoCAD one is using. Here is one explanation regarding the use of the Control Vertices Method: http://www.g-wlearning.com/CAD/9781605253282/student/ch04/PDF/SupMat03.pdf Quote Link to comment Share on other sites More sharing options...
welldriller Posted July 9, 2013 Share Posted July 9, 2013 First i printed the image in post #1 Then using autocadLT 2000 i did the following and got a perfect fit i only used 3 lines and a arc (this was done in metric) line 1 = @171.50 line 2 = @442.50 line 3 = @221.25 with osnap turned on pick arc pick the end points of each line print out your new drawing and cut it out mine was a perfect fit over the image i printed from post #1 yep bet a dollar to a donut ReMark checks me on this one. Quote Link to comment Share on other sites More sharing options...
