121madhu Posted July 21, 2013 Posted July 21, 2013 (PE join lines,arcs select) same prosses of PE but there is taking long time if have any lisp file . select lines,arcs to convert polyline. lines,arcs old layer but new polyline take new layer thank you cadtutors Quote
Tharwat Posted July 21, 2013 Posted July 21, 2013 You did not reply to your previous thread HERE Quote
Tharwat Posted July 21, 2013 Posted July 21, 2013 (PEjoin lines,arcs select) same prosses of PE but there is taking long time if have any lisp file . select lines,arcs to convert polyline. lines,arcs old layer but new polyline take new layer thank you cadtutors This ? (defun c:foo (/ ss) (if (setq ss (ssget "_:L" '((0 . "LINE,ARC")))) (command "_.pedit" "_multiple" ss "" "_y" "_join" "0.0000" "")) (princ)) Quote
121madhu Posted July 21, 2013 Author Posted July 21, 2013 hello tharwat My English is very poor actually i am interested to learn lisp programs but where can i found best definitions about defun , set ,setq, ssget, progn, i dont know everything im also vist afralisp site. your reply my previous thread thanks and ur code is working thank you very much being support Quote
Tharwat Posted July 21, 2013 Posted July 21, 2013 your reply my previous thread thanks and ur code is working thank you very much being support You're welcome and I just wanted to know if I got you right and brought the correct code for you . hello tharwat My English is very poor actually i am interested to learn lisp programs but where can i found best definitions about defun , set ,setq, ssget, progn, i dont know everything im also vist afralisp site. The Acad help document is one of the best books that you can use for learning and the online websites of course and Afralisp is one of the best of them . Good luck Quote
121madhu Posted July 21, 2013 Author Posted July 21, 2013 nice but old lines,arc are available in old layer, new polyline generate new layer Quote
Tharwat Posted July 21, 2013 Posted July 21, 2013 nice but old lines,arc are available in old layer, new polyline generate new layer If all entities are on the same layer , the new created polyine would be on the same layer otherwise one layer would be picked from one the selected objects . Quote
Tharwat Posted July 22, 2013 Posted July 22, 2013 Thank you very much Tharwat You're very welcome . Quote
Tharwat Posted July 22, 2013 Posted July 22, 2013 Be mindful of PEDITACCEPT variable Good catch PBe Thanks Quote
rkent Posted July 22, 2013 Posted July 22, 2013 I would highly recommend using this one called POLYJOIN.LSP. http://www.lee-mac.com/polylineprograms.html Quote
121madhu Posted July 27, 2013 Author Posted July 27, 2013 i am facing new problem please give me another suggestion lines and arc selected make a new polyline older lines and arcs are same but take a new polyline selected object its option very useful for me Quote
