Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 59 of 59
Thread: Standard scale
  1. #51
    Full Member
    AutoCAD LT 2006
    Jul 2013
    25
    JD - I am not a student. AutoCAD LT is no listed on my Windows Control Panel.
  2. #52
    Full Member
    AutoCAD LT 2006
    Jul 2013
    25
    JD - As I wrote, I am not a Student, but I am a 79 year old Senior. That may be part of the problem.
  3. #53
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Walter, just as one last check before repair/reinstall, please verify that Properties manager does not display the objects properties in the Modelspace tab. If the problem persists on the Modelspace tab as well, then proceed with repair/reinstall. (Be sure you have the Serial number or product key you originally used to install with)
    You have two options to repair/reinstall:
    1) Put the AutoCAD 2006 CD in the drive, and the installer should launch and prompt you to Add/Remove Features, Repair/Reinstall, or Remove. You want to choose Repair/Reinstall, and then it should ask whether you want to Repair, or Reinstall. I would try Repair first.
    2) From the Windows(XP)* Start menu follow this progression: Start > Settings > Control Panel > Add/Remove Programs > AutoCAD 2006 > Change (then refer to #1 above)
    * if using Windows7, replace "Add/Remove Programs with "Programs and Settings"
  4. #54
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    While waiting, here's a little trivia about the problem. A blank/non-functional properties palette is often caused by a registry cleaner removing entries from the Windows registry that AutoCAD needs to work correctly. Not just designated registry cleaners either, Norton Antivirus (among others) has been a known culprit, although I think antivirus is less of a problem now, compared to several years ago. Any of the many programs advertised to "speed up your PC" probably fall into the category of "registry cleaners"
  5. #55
    Full Member
    AutoCAD LT 2006
    Jul 2013
    25
    JD, nestly and everyone else, thank you, the repair worked. I'm back in business. Thank you for going the extra mile with me.
    Walter
  6. #56
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Glad to hear it.
  7. #57
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Quote Originally Posted by nestly View Post
    It sounds like you have a fairly common problem and need to repair or reinstall AutoCAD. I'm replying from my phone right now, but if you need help with that I'll be back in a little while
    That might explain why the drawing was boogered all up when I opened it but began to work properly after I got the properties manager to open. My registry was correct, but probably didn't match addresses in a dll somewhere, until the dll was changed. Once I saved, it worked thereafter.
    Back in the '90s I used to use a program called Norton Clean Sweep to keep my computer emptied out and running. Back then, in the days of the 365 meg memory and 100 meg disks, one had to do something, anything to keep the danged slow machines functioning at a non-exasperating level. Occasionally I would let it delete things I needed by accident. Then I would spend hours, even days retrieving "system" files I needed from other computers. Nowadays you can turn off services and applications one after the other, and create a custom boot profile. Then if you discover you have turned off something you need, just boot up using the original default boot.
    I don't let my OS or my virus software perform any sort of automatic Clean-up routines any more. At least not the ones I can find.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  8. #58
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Quote Originally Posted by WalterCarlson View Post
    Hey, stop it. You're only a few years past me.
  9. #59
    Full Member
    AutoCAD LT 2006
    Jul 2013
    25
    Glad to hear that everyone is in a good mood. I know I am... Thanks again.
  1. Standard scale of a viewport
    By dannywi77iams in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Feb 2012, 01:13 pm
  2. Is There a Standard for Symbol Sizes that are Not to Scale?
    By David_Feynman in forum CAD Management
    Last Post: 3rd Jun 2011, 01:23 am
  3. Replies: 7
    Last Post: 22nd Sep 2010, 03:51 am
  4. Confused about "standard scale" and "custom scale" interaction.
    By tnb23 in forum AutoCAD Beginners' Area
    Last Post: 28th Jan 2009, 10:38 pm
  5. Standard drawing scale
    By heretic in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jul 2006, 04:54 am
