1endmartin1 Posted August 1, 2013 Share Posted August 1, 2013 I'm installing version 2007 on my desk top computer and type in all of my 16 numbers to register and after I do that a empty 17th box come up. What number goes in the 17th box Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 1, 2013 Share Posted August 1, 2013 Isn't it another alpha-numeric set of four characters? Where did you get your "numbers" and why aren't you activating AutoCAD online? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 1, 2013 Share Posted August 1, 2013 .... all of my 16 numbers to register .... What numbers? Serial Numbers? Product Code? Activation Request Code? Activation Code? The normal process of activation - Activation of a license is accomplished by going on-line or otherwise sending your Activation Request Code to Autodesk. The Activation Request Code is generated by YOUR COMPUTER based on YOUR personal serial number and hardware. So each Activation Request Code is unique to a particular machine. Because the Activation Request Code is generated by a particular machine - the Activation Code that Autodesk sends back to you is unique to that computer. v2007 is 7 years old. What is the previous history of this license? What operating system (version of Windows) are you using? Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 2, 2013 Share Posted August 2, 2013 I took a look on the case holding my AutoCAD 2007 disks this morning and all I see is a serial number (format: 123-45678901) and N/A for the CDkey. The activation code requires four sets of four alpha-numeric characters (16 boxes). That's it. There is no box for another set. A copy of your registration number can be found in the following location on your hard drive: C:\ProgramData\AutoDesk\AutoCAD 2007\R17.0\Adlm\ACAD2007ENUReginfo.html One last question...Is this a legal copy of AutoCAD? Quote Link to comment Share on other sites More sharing options...
