milesfrankland Posted August 7, 2013 Share Posted August 7, 2013 Hi, When Ive needed to fill a corner gap I have used a Linear Weld relief shape. This has worked as all the angles have been the same but I have come across a problem today trying to create a linear weld on the corners of two seperate flanges at different angles. I am using a 3mm thick material which minimum bend radius is thickness * 2 (6mm) so I get a nasty hole in the corner. The two sides are 80° and the top flange is 45°. Thanks Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 7, 2013 Share Posted August 7, 2013 Attach the ipt file here. Quote Link to comment Share on other sites More sharing options...
milesfrankland Posted August 7, 2013 Author Share Posted August 7, 2013 Oh dear, its quite a mess... Here goes: 4MW.7CC9.011 Side Door Handle AD RHD v1.2.ipt Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 7, 2013 Share Posted August 7, 2013 I found your dimensions rather confusing, but maybe this will help. Door Handle_jd.ipt Quote Link to comment Share on other sites More sharing options...
milesfrankland Posted August 8, 2013 Author Share Posted August 8, 2013 Thanks very much! I did try the corner function but was clicking on the wrong edges and faces Quote Link to comment Share on other sites More sharing options...
