Block insertion routine based on part block file name
Hi guys,
1st of all I am a very very basic lisp user. I can write very simple lisp (probably not very well written but they work!) for every day tedious tasks.
I am trying to write, put together a lisp to insert a block based on part of the file name.
I will have a block named in following way.
Partnumber1-Partnumber2.dwg
The user when wanting to insert the block may have either of the part numbers. So only 1 part number will ever be entered.
I need to the lisp to wildcard the block name.
I have had a mess around with "wcmatch" but couldnt really get my head round it, hey I did say I was a basic user!!
Any way. after days & hours of trial & error & web searching I found a code that does all but what I need.
The only problem is after inserting the block the user needs to set scale & rotation. I have spent ages trying to work out where the "" "" "" would go to eliminate the user from having to do so but for the life of me I can not get it to work.
Also I clue to where I would add "*" if i wanted the block to be exploded.
Thanks in advance for help you guys can give.
Heres the code.
(defun c:test (/ file dir files itm n fil qt)
 (setq file (getstring "\nEnter partial block name to insert: "))
 (if (and (setq dir "C:\\test\\test\\Blocks\\");; changes to your search path
   (setq files (vl-directory-files dir (strcat "*" file "*.dwg") 1))
     (cond ((= (length files) 1)
     (command "_.insert" (strcat (car files)))
     (while (> (getvar 'cmdactive) 0) (command pause))
    ((> (length files) 1)
     (setq itm 0)
     (textscr)
     (foreach n	files
       (print (strcat " " (rtos itm 2 0) " <-- " n))
       (setq itm (1+ itm))
     (setq qt (- (length files) 1))
     (while
       (or
	 (not fil)
	 (not (<= 0 fil qt))
	(setq
	  fil (getint
		(strcat "\nEnter block number from 0 to " (rtos qt 2 0) " :")
     (graphscr)
     (command "_.insert" (strcat (nth fil files)))
   (princ (strcat "\nThere are no blocks with -> " file " <- in the name!!!")
This code is familiar to me.
Perhaps something like this:
     (command "_.insert" (strcat "*" dir (car files)) pause "" "" "")
     (setq itm 0)
     (textscr)
     (foreach n files
       (setq itm (1+ itm))
     (while
       (or
  (not fil)
  (not (<= 0 fil qt))
 (setq
   fil (getint
     (graphscr)
     (command "_.insert" (strcat "*" dir (nth fil files)) pause "" "" "")
hope that helps
Henrique
Edited by hmsilva
  • 2 weeks later...
Absolutely perfect thanks.
I think it may have been your code in the 1st place seeing your username rings a bell!
Thanks again & sorry for the late reply have given it a rest for a while & only just read, applied & tested the code.
Got another problem now but on a different code I have been writing so look out for a new tread!! :)
You're welcome.
Glad i could help.
Henrique
