Gavin Studd Posted August 22, 2013 Share Posted August 22, 2013 Hi, Im having trouble with autocad 2012. every time I try to save as it freezes the programme. if I press esc it unfreezes it but I can not save as. lots of my drawings require me to open a drawing then draw from it and save it as something else so this is something I need to do does anybody have any ideas? thanks Gavin Quote Link to comment Share on other sites More sharing options...
Tuns Posted August 22, 2013 Share Posted August 22, 2013 Make sure your FILEDIA = 1. If that isn't it then does the window simply not open? Does it open then freeze? Quote Link to comment Share on other sites More sharing options...
Mike_Taylor Posted August 22, 2013 Share Posted August 22, 2013 When you hit save as what is the command prompt saying? Quote Link to comment Share on other sites More sharing options...
Gavin Studd Posted August 22, 2013 Author Share Posted August 22, 2013 prompt command says save as Quote Link to comment Share on other sites More sharing options...
Gavin Studd Posted August 22, 2013 Author Share Posted August 22, 2013 FILEDIA=1 is already set Quote Link to comment Share on other sites More sharing options...
Tuns Posted August 22, 2013 Share Posted August 22, 2013 At what point does it freeze? Before or after the window opens? Quote Link to comment Share on other sites More sharing options...
Gavin Studd Posted August 22, 2013 Author Share Posted August 22, 2013 it freezes when I select save as and then try and select autocad drawing Quote Link to comment Share on other sites More sharing options...
Chilidawg Posted August 22, 2013 Share Posted August 22, 2013 Does your regular save work? As a simple work around, you can always copy and rename the file in the windows folder, then open it in autocad and do a simple save on it. A pain, but it will keep you going untill you figure out what is causeing the save as issue Quote Link to comment Share on other sites More sharing options...
Mike_Taylor Posted August 22, 2013 Share Posted August 22, 2013 Does this only occur in certain files or on all files. Test to see if this is occurring on drawings on your network/server (if you are using one) or your a local drive in your computer. Quote Link to comment Share on other sites More sharing options...
Tuns Posted August 22, 2013 Share Posted August 22, 2013 Try typing "saveas" in the command line and see what happens. Quote Link to comment Share on other sites More sharing options...
Matsui21 Posted August 26, 2013 Share Posted August 26, 2013 Another thing to look at is when you open the drawing; do you get a dialog box saying there are errors in the file? I know this has caused me not to be able to save before. If this is the case do a purge and an audit on the file (and you can type audit straight into the command line). Quote Link to comment Share on other sites More sharing options...
mikekmx Posted August 26, 2013 Share Posted August 26, 2013 Hi, Im having trouble with autocad 2012. every time I try to save as it freezes the programme. if I press esc it unfreezes it but I can not save as. lots of my drawings require me to open a drawing then draw from it and save it as something else so this is something I need to do does anybody have any ideas? thanks Gavin Another thing to look at is when you open the drawing; do you get a dialog box saying there are errors in the file? I know this has caused me not to be able to save before. If this is the case do a purge and an audit on the file (and you can type audit straight into the command line). i was thinking that maybe a dialogue box has popped up but is hidden behind summat else - and hitting escape gets rid of it (?) Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 26, 2013 Share Posted August 26, 2013 Have you considered running a REPAIR of the installation? Should take no more than 10 minutes. Quote Link to comment Share on other sites More sharing options...
Matsui21 Posted August 26, 2013 Share Posted August 26, 2013 i was thinking that maybe a dialogue box has popped up but is hidden behind summat else - and hitting escape gets rid of it (?) yes, it is very possible that the dialogue box is hidden behind the program window and hitting escape would make it freeze because it won't close that dialogue until you pick "OK" or the close button. Quote Link to comment Share on other sites More sharing options...
Tyke Posted August 26, 2013 Share Posted August 26, 2013 Following on from mikekmx'sline of thought, are you or have you been working on a dual monitor system and changed back to a single monitor? If so the dialogue box could be appearing where the second monitor used to be. If not try not maximising the AutoCAD window and then move it to the side to see if the dialogue box is being hidden. Quote Link to comment Share on other sites More sharing options...
Tuns Posted August 26, 2013 Share Posted August 26, 2013 I don't think it would come up behind something else unless he has dual screen. Even then by default it should come up in front of any windows he has open on that screen. Quote Link to comment Share on other sites More sharing options...
PEGAdevelopment Posted August 29, 2013 Share Posted August 29, 2013 It's not a "read only" file is it? Quote Link to comment Share on other sites More sharing options...
