Block editor - linear parameter q
cruse
Hi,
i have been trying to search for an answer for this question but without any luck.
First i have to mention i am using a mac and since i am the only 1 in my class who uses mac, no one can help me.
We are supposed to make a block (window for house) and in the windows version, apparently when entering BLOCK EDITOR - a tool palette comes up where you are able to choose "Linear Parameter" and then an arrow comes up where you can pull the arrows to each side.
MY PROBLEM: is that when i enter block editor this tool palette doesnt show, and i cant find where this linear parameter is. Can any1 give some advice?:)
Thanks
You might take a look at this page: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19483315&linkID=15839490
Possibly of special interest (I don't use a Mac):
Features only available in AutoCAD for Mac
  • Coverflow
  • Multitouch
  • Visual Quickview
  • Layout Visor
  • Cocoa-centric collapsible and dockable Palette System
Alternatives Exist
  • DesignCenter (the equivalent in AutoCAD for Mac is the Content Palette)
  • Tool palettes (the equivalent in AutoCAD for Mac is the Content Palette)
  • Quick Properties palette (the AutoCAD for Mac property palette has “Essential” and “All” views)
I found this in the AutoCAD for Mac 2013 Help file.
Note: Dynamic blocks can be inserted and manipulated in a drawing, but cannot be created or edited in the Block Editor.
Online help for 2011, 2012 and 2013 along with tutorials can be found here...http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=15839814&linkID=15839488
That just sounds cruel and I'm not holding on to much hope here; however, the Help link above led to the following for AutoCAD Mac 2013 (http://docs.autodesk.com/ACDMAC/2013/ENU/filesACRMac/GUID-D57D4195-72FC-4FA5-B9F4-E021291D808C.htm):
The Block Editor is a separate environment for creating and changing block definitions for the current drawing. You can also use it to add dynamic behavior to blocks.
Hi,
Thanks
seriously dude,get a PC
