adrath Posted September 12, 2013 Share Posted September 12, 2013 I'm having a problem with the 'label spot elevation' command under the profiles drop-down in Land Desktop 2009. I set a Romans text style with a height of 1.4 current (both through typing STYLE into the command line and through the 'set current text style' from the Profiles -> Label -> Set Current text style drop-down menu). After checking and re-checking these settings, I place a spot elevation label in the drawing and the label text is standard with a height of 7.2. Anyone else encountered this before/know how to fix it? I know that I could change the standard text style, but I don't want to because that would affect other text in the drawing. These labels are on a no-plot layer only for my reference so it's more of a minor annoyance than anything else, but it sure would be nice to have the labels not be so gigantic. Quote Link to comment Share on other sites More sharing options...
JerryG Posted September 26, 2013 Share Posted September 26, 2013 Been a while so I may be off on where the setting is. But go to your Points settings (were you set the color etc) and I think the text height is in the same place? Or at least the style it is using. That way you can create a new Text style just for the points - set the height you want then set the Point settings to that style. Quote Link to comment Share on other sites More sharing options...
