neo Posted September 20, 2013 Posted September 20, 2013 Hello members , This is my first post in CADTUTOR ,well I Need Help with my DCL Codes I was Created Lisp with Dialog Box , and I got one problem here ,which is how to save user settings , if I select one toggle key, same time I am going to select text objects ,when the Dialog box return ,my toggle selection is showing unselected Please help ..... Lisp Codes (defun switch (/ mod) (setq mod(atoi (get_tile "left"))) (if (= mod 1) (mode_tile "right" 1) (mode_tile "right" 0) ) ) (defun switch2(/ mod2) (setq mod2(atoi (get_tile "right"))) (if (= mod2 1) (mode_tile "left" 1) (mode_tile "left" 0) ) ) (defun savevars (l r sset e / sname ent new_txt) (repeat (setq s (sslength sset)) (setq sname (ssname sset (setq s (1- s)))) (setq ent (entget sname)) (if (= l 1) (setq new_txt(vl-string-left-trim e (cdr (assoc 1 ent)))) (setq new_txt(vl-string-right-trim e (cdr (assoc 1 ent)))) ) (entmod (subst (cons 1 new_txt) (assoc 1 ent) ent)) (entupd (cdr (assoc -1 ent))) ) (princ)) (defun c:trim_t (/ counter dcl_id lft rht ed obj) (setq counter 3) (while (> counter 2) (if (not (setq dcl_id (load_dialog "C:\\Text Trim.dcl"))) (progn (alert "Could not be find Dcl file") (exit) ) (progn (if (not (new_dialog "Trim" dcl_id)) (progn (alert "The definition could not be found inside the DCL file") (exit) ) (progn (action_tile "left" "(setq lft (atoi(get_tile\"left\"))) (switch)") (action_tile "right" "(setq rht (atoi(get_tile\"right\"))) (switch2)") (action_tile "edit" "(setq ed (get_tile \"edit\"))") (action_tile "apply" "(done_dialog 1)") (action_tile "cancel" "(done_dialog 0)") (action_tile "select objects" "(done_dialog 3)") (setq counter (start_dialog)) (cond ((= counter 1) (savevars lft rht obj ed)) ((= counter 0) (princ "\n...Function cancelled.")) ((= counter 3) (setq obj (ssget '((0 . "TEXT"))))) ) ) ) ) ) ) (unload_dialog dcl_id) (princ)) Dialog Codes Trim: dialog {label= "Trim String 1.0"; :boxed_radio_row { :text {label=" Select Objects";} :button{label=" > > ";key="select objects";width=0.5;height=3 ;} } : boxed_radio_row { :toggle {label="Trim from Left";key="left";value=0;} :toggle {label="Trim from Right";key="right";value=0;} } :edit_box{label="Type String ";key="edit";edit_limit=true;edit_width=30;allow_accept=true;} :boxed_radio_row{ :button{label="Apply";key="accept";alignment=centered ;width=12 ;is_default=true;} :button{label="Cancel";key="cancel";alignment=centered;width=12;is_default=false;is_cancel=true;} } } Quote
satishrajdev Posted September 20, 2013 Posted September 20, 2013 Try this code :- (defun savevars (l r sset e / sname ent new_txt) (repeat (setq s (sslength sset)) (setq sname (ssname sset (setq s (1- s)))) (setq ent (entget sname)) (if (= l 1) (setq new_txt (vl-string-left-trim e (cdr (assoc 1 ent)))) (setq new_txt (vl-string-right-trim e (cdr (assoc 1 ent)))) ) (entmod (subst (cons 1 new_txt) (assoc 1 ent) ent)) (entupd (cdr (assoc -1 ent))) ) (princ) ) (defun c:trim_t (/ counter dcl_id lft rht ed obj) (setq counter 3) (if (not *MyToggles@) (setq *MyToggles@ (list nil "0" "0")) ) (setq left (nth 1 *MyToggles@) right (nth 2 *MyToggles@) ) (while (> counter 2) (if (not (setq dcl_id (load_dialog "C:\\Text Trim.dcl"))) (progn (alert "Could not be find Dcl file") (exit) ) ) (if (not (new_dialog "Trim" dcl_id)) (progn (alert "The definition could not be found inside the DCL file" ) (exit) ) ) (defun switch (/ mod) (setq mod (atoi (get_tile "left"))) (if (= mod 1) (mode_tile "right" 1) (mode_tile "right" 0) ) ) (defun switch2 (/ mod2) (setq mod2 (atoi (get_tile "right"))) (if (= mod2 1) (mode_tile "left" 1) (mode_tile "left" 0) ) ) (defun set_defaults () (set_tile "right" right) (set_tile "left" left) (set_tile "edit" "") ) (progn (set_defaults) (action_tile "left" "(setq left $value) (switch)") (action_tile "right" "(setq right $value) (switch2)") (action_tile "edit" "(setq ed (get_tile \"edit\"))") (action_tile "apply" "(done_dialog 1)") (action_tile "cancel" "(done_dialog 0)") (action_tile "select objects" "(done_dialog 3)") (setq counter (start_dialog)) (cond ((= counter 1) (savevars left left obj ed)) ((= counter 0) (princ "\n...Function cancelled.")) ((= counter 3) (setq obj (ssget '((0 . "TEXT"))))) ) ) ) (unload_dialog dcl_id) (princ) ) Quote
neo Posted September 20, 2013 Author Posted September 20, 2013 Try this code :- (defun savevars (l r sset e / sname ent new_txt) (repeat (setq s (sslength sset)) (setq sname (ssname sset (setq s (1- s)))) (setq ent (entget sname)) (if (= l 1) (setq new_txt (vl-string-left-trim e (cdr (assoc 1 ent)))) (setq new_txt (vl-string-right-trim e (cdr (assoc 1 ent)))) ) (entmod (subst (cons 1 new_txt) (assoc 1 ent) ent)) (entupd (cdr (assoc -1 ent))) ) (princ) ) (defun c:trim_t (/ counter dcl_id lft rht ed obj) (setq counter 3) (if (not *MyToggles@) (setq *MyToggles@ (list nil "0" "0")) ) (setq left (nth 1 *MyToggles@) right (nth 2 *MyToggles@) ) (while (> counter 2) (if (not (setq dcl_id (load_dialog "C:\\Text Trim.dcl"))) (progn (alert "Could not be find Dcl file") (exit) ) ) @ (if (not (new_dialog "Trim" dcl_id)) (progn (alert "The definition could not be found inside the DCL file" ) (exit) ) ) (defun switch (/ mod) (setq mod (atoi (get_tile "left"))) (if (= mod 1) (mode_tile "right" 1) (mode_tile "right" 0) ) ) (defun switch2 (/ mod2) (setq mod2 (atoi (get_tile "right"))) (if (= mod2 1) (mode_tile "left" 1) (mode_tile "left" 0) ) ) (defun set_defaults () (set_tile "right" right) (set_tile "left" left) (set_tile "edit" "") ) (progn (set_defaults) (action_tile "left" "(setq left $value) (switch)") (action_tile "right" "(setq right $value) (switch2)") (action_tile "edit" "(setq ed (get_tile \"edit\"))") (action_tile "apply" "(done_dialog 1)") (action_tile "cancel" "(done_dialog 0)") (action_tile "select objects" "(done_dialog 3)") (setq counter (start_dialog)) (cond ((= counter 1) (savevars left left obj ed)) ((= counter 0) (princ "\n...Function cancelled.")) ((= counter 3) (setq obj (ssget '((0 . "TEXT"))))) ) ) ) (unload_dialog dcl_id) (princ) ) satishrajdev That was brilliant , Thank So much for Helping Me to fix This 5 Stars Quote
neo Posted September 20, 2013 Author Posted September 20, 2013 satishrajdev That was brilliant , Thank You So Much for Your Help to fix This 5 Stars Quote
