LISP to make a selected text style current
Hi all, does anyone know of a lisp routine that can set the current text style by selecting an existing inserted or modified text entity in the drawing? (Sorry, my title says Dimension when I meant TEXT)
I'm new to the forum, but not AutoCAD and I'm self taught when it comes LISP. Any code suggestions would be greatly appreciated.
Thanks in advance
Welcome to the forum.
I have renamed your thread and moved it to the AutoLisp section. For best results, always post in the appropriate area of the forum. ;)
(defun c:picktxtstyle ( / adoc ent st stcoll stobj )
 (vl-load-com)
 (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
 (while (not ent)
   (setq ent (car (entsel "\nPick text object that has TEXT STYLE property - DXF 7 code to make its style current")))
   (if (not (assoc 7 (entget ent)))
       (setq ent nil)
       (prompt "\nPicked entity doesn't have TEXT STYLE property, or missed selection; Try again...")
 (setq st (cdr (assoc 7 (entget ent))))
 (setq stcoll (vla-get-textstyles adoc))
 (setq stobj (vla-item stcoll st))
 (vla-put-activetextstyle adoc stobj)
(defun c:pckst nil (c:picktxtstyle))
M.R.
Another, without using DXF 7 code - just Vlisp 'stylename property...
 (vl-load-com)
 (while (not ent)
   (if (not (vlax-property-available-p (vlax-ename->vla-object ent) 'stylename))
       (setq ent nil)
 (setq st (vla-get-stylename (vlax-ename->vla-object ent)))
M.R.
