ste_clectic Posted October 6, 2013 Share Posted October 6, 2013 Hi guys. I've been given a floor plan of a building which I need to populate with smoke detectors. The smoke detectors are larger than the entire building. I've used the same smoke detectors on other floor plans and they've always been scaled properly. Any ideas? I'm a complete newb here. Also, I notice the floorplan is 1:250@A3 Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 6, 2013 Share Posted October 6, 2013 Is INSUNITS set to a value of "0"? If not try that first. Do you know what the diameter of the smoke detector is? Assuming you do you could scale the overly large smoke detector (previously inserted) and scale it using the Reference option. Do you know how to do that? Quote Link to comment Share on other sites More sharing options...
ste_clectic Posted October 6, 2013 Author Share Posted October 6, 2013 I don't want to scale the smoke as I need to use it with other floor plans (which scale correctly). I just realized I was in paper view, in model view the smoke is scaled perfectly. The problem I now have is that I can't see my title block in model view even though the layer is turned on. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 6, 2013 Share Posted October 6, 2013 Wouldn't your title block and border be over in your layout? Makes the most sense. Quote Link to comment Share on other sites More sharing options...
ste_clectic Posted October 6, 2013 Author Share Posted October 6, 2013 I need to add the symbols to the legend in the title block. I can't do that if the symbols are huge. I'm going to get my friend to look at it for me. Appreciate the help. Cheers Quote Link to comment Share on other sites More sharing options...
mikekmx Posted October 6, 2013 Share Posted October 6, 2013 I need to add the symbols to the legend in the title block. I can't do that if the symbols are huge. I'm going to get my friend to look at it for me. Appreciate the help. Cheers copy a modelspace symbol then changespace the symbol to bring it to paperspace.....it will be automatically scaled to appear the same size Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 6, 2013 Share Posted October 6, 2013 The command Mike is referring to is CHSPACE. Even if you did not use the command you could still rescale the symbol easily. Quote Link to comment Share on other sites More sharing options...
Bogbadbob658 Posted October 7, 2013 Share Posted October 7, 2013 I need to add the symbols to the legend in the title block. I can't do that if the symbols are huge. I'm going to get my friend to look at it for me. Appreciate the help. Cheers Why not use a second viewport to create the legend. I usually create all my legends in model space to avoid scaling in the layout tab. Quote Link to comment Share on other sites More sharing options...
