Results 1 to 2 of 2
    Senior Member Bogbadbob658's Avatar
    Bogbadbob658's Computer Details
    Windows 7
    Asus P8P67 LE
    Intel 2nd Generation Coreā„¢ i5-2500
    8GB 1333MHz Dual Channel DDR3 SDRAM
    512MB Nvidia GeForce Quadro FX 580
    1TB Samsung F3 SATA 7200rpm 32MB Cache
    24" Iiyama LCD Monitor - Full HD 1920x1080
    Architecture 2013
    Aug 2007
    Gloucester UK
    Default xref'd Architecture models not displaying as expected
    I have to overlay my building model over a site model and have done this using xref but when I select the display configuration to get the view of the building I want it doesn't appear. If I copy the wall types into the plan file they work correctly. I only use the 'presentation' and 'high detail' options which are ones I've edited to what I need. How do I get them to appear the test plan file as they do in the test model file.
    I've stripped down the attached files to better help explain the issue. The test model is xref'd into the test plan file. If you change the display configuration to high detail the walls disappear in the test plan file. (Grrr I can't upload the files at the moment.)
    Any help appreciated.
    Senior Member hertz hound's Avatar
    hertz hound's Computer Details
    windows 7
    Dell precision T1600
    hertz hound's Discipline Details
    Auto Cad as-built and coordination drawings when needed, otherwise in the field with the tools.
    MEP 2015
    Jan 2012
    USA - New Jersey
    I will take a stab at it, even though I am not sure I fully understand your problem. If you go into drawing utilitys < drawing set up. go to the display tab. you will se a check box at the bottom. "when used as an xref overlay, use this drawings display default display configuration initially. See what happens when you change the setting?
    Other wise I think you are asking how to copy a display configuration to another drawing. I think you know that so that is probably not your question.
  1. Viewport Issue: Not displaying Xref
    By funk in forum AutoCAD General
    Last Post: 24th Feb 2011, 07:14 am
  2. Solid not displaying from xref
    By KJB in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Oct 2010, 05:44 pm
  3. XREF not displaying embedded Image
    By stopandgo in forum AutoCAD Beginners' Area
    Last Post: 15th Feb 2010, 09:23 pm
  4. Xref Attach file not displaying when added
    By irishcowboy in forum AutoCAD Beginners' Area
    Last Post: 12th May 2008, 03:19 pm
  5. rendering xref'd models query
    By loff in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Nov 2002, 04:49 pm
