OMEGA-ThundeR Posted October 10, 2013 Share Posted October 10, 2013 Hi, I want a long command to be short. I do this in lisp with the following lines of code: (Defun C:mtp () (command "MAPTOPOLOGYTOPOLYGONS") (princ) ) This particular command normally opens a dialog box under Civil 3D. But when i use it in above lisp, is shows command line questions. Like if i would use the underscore. Any help on getting this to work? I could just edit the command in the CUI, but then i have to do it on every computer. The lisp file is loaded at everyones computers so always up to date for everyone. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 10, 2013 Share Posted October 10, 2013 Try: (defun c:mtp ( ) (initdia) (command "_.MAPTOPOLOGYTOPOLYGONS") (princ) ) Quote Link to comment Share on other sites More sharing options...
