legio Posted November 2, 2013 Share Posted November 2, 2013 I can not solve the problem . i have interference in elbow ( left side ) . p/s part in sheet metal Quote Link to comment Share on other sites More sharing options...
Lazer Posted November 18, 2013 Share Posted November 18, 2013 Looks like yo have modelled this as a standard .itp using surfaces then added a thickness to each surface?. I would have used sheetmetal using contour roll for this. Quote Link to comment Share on other sites More sharing options...
legio Posted November 18, 2013 Author Share Posted November 18, 2013 hi. when will you collect parts. you will have a penetration between the parts. and the problem is thicker.you cfn use contur roll but it is not real material . Quote Link to comment Share on other sites More sharing options...
JD Mather Posted November 18, 2013 Share Posted November 18, 2013 I would not use Contoured Roll for this. Attach your file(s) here for instruction on correct technique. Quote Link to comment Share on other sites More sharing options...
legio Posted November 19, 2013 Author Share Posted November 19, 2013 hi / i have 2 more . and i go way 2.ipt 1.ipt Quote Link to comment Share on other sites More sharing options...
legio Posted November 19, 2013 Author Share Posted November 19, 2013 my assembly not uploud 3.ipt Quote Link to comment Share on other sites More sharing options...
