EVriderDK Posted November 2, 2013 Share Posted November 2, 2013 When i select icons with a scaling of 1.000 it is very very small, and I have to set it to around 30 to have a decent size with normal zoom. But I have just importet a circuit breaker as a .dwg and when I import that one it is huge! I have to scale it to 0.1 or something. How can I set a uniform scaling factor for the icons? It is Autocad electrical 2014. I have also tried with different sheets, but it does not seem to work. Quote Link to comment Share on other sites More sharing options...
mikekmx Posted November 2, 2013 Share Posted November 2, 2013 When i select icons with a scaling of 1.000 it is very very small, and I have to set it to around 30 to have a decent size with normal zoom. But I have just importet a circuit breaker as a .dwg and when I import that one it is huge! I have to scale it to 0.1 or something. How can I set a uniform scaling factor for the icons? It is Autocad electrical 2014. I have also tried with different sheets, but it does not seem to work. don't mix imperial & metric blocks Quote Link to comment Share on other sites More sharing options...
EVriderDK Posted November 2, 2013 Author Share Posted November 2, 2013 Oh, how do I convert an icon to metric? Quote Link to comment Share on other sites More sharing options...
mikekmx Posted November 2, 2013 Share Posted November 2, 2013 does scaling the small icon (block?) up by 24.5 make it the exact correct size? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted November 2, 2013 Share Posted November 2, 2013 Do you know how to use the scale command? 1 inch = 25.4mm (not 24.5 as indicated in post #4) 1 mm = .03937 inch Quote Link to comment Share on other sites More sharing options...
EVriderDK Posted November 2, 2013 Author Share Posted November 2, 2013 No it does not work. The big MCCB is scaled 1.000 and the small transformer is scaled 24.5 http://peecee.dk/upload/view/424913 Quote Link to comment Share on other sites More sharing options...
mikekmx Posted November 2, 2013 Share Posted November 2, 2013 Do you know how to use the scale command? 1 inch = 25.4mm (not 24.5 as indicated in post #4) 1 mm = .03937 inch thank you Quote Link to comment Share on other sites More sharing options...
EVriderDK Posted November 3, 2013 Author Share Posted November 3, 2013 Mike, far from. I have replied, but reply is pending approval because of link I think. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted November 3, 2013 Share Posted November 3, 2013 You should be able to attach *.dwg files here. In any case, it is a simple matter to measure current size and apply scale factor to get desired size. (Scale with Reference is even easier - once you figure out how it works.) Quote Link to comment Share on other sites More sharing options...
