slovenc0417 Posted November 22, 2013 Share Posted November 22, 2013 I am able to create my own leader style, a loop, similar to the "dot blank" option that ACAD provides. However, as with any leader style, once you pick the starting point of your leader you must extend it a certain length in order for the arrow, dot, slash, etc. to appear. This is a draw back in tight spaces where you are trying to fit the leader and the subsequent text. Basically I would like to know if there is a setting that will allow me to pick the starting point of the leader and have the shortest length of leader line while still showing the "arrowhead". I realize I can scale down the arrowhead type to give me more space. I realize I can explode the leader and shorten the line portion of the leader. I realize I can create a block of a "leader" that will give the appearance that I am looking for. However, these are last ditch options if there is no solution. Any help would be greatly appreciated! Thanks, Rob Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 24, 2013 Share Posted November 24, 2013 For those rare instances have you considered using a dynamic block instead? Quote Link to comment Share on other sites More sharing options...
