cgv Posted November 26, 2013 Posted November 26, 2013 Hi, Does anyone know of any good lisp routines that will allow you to select a polyline which has a Z vales and have it place a text label of the elevation over the line with a background mask? It would really help out. Thanks. Quote
ymg3 Posted November 27, 2013 Posted November 27, 2013 (edited) Here is a dynamic one modified from an Alan J Thompson routine. Your contour must be on layer "Major Contour" and "Minor Contour" for it to work. ;; c:dlbl Dynamic Contour Labeling by ymg ; ;; ; ;; Extension to LCE program by Alan J. Thompson ; ;; http://www.theswamp.org/index.php?topic=39644.msg449399#msg449399 ; ;; Code for grread loop from Freebird at TheSwamp ; ;; ; ;; Tab, Toggles from Major Contour Only to All Contours. ; ;; +, Increase Size of Text Labels. ; ;; -, Decrease Size of Text Labels. ; ;; Left-Click, Enter a Point for the Fence. ; ;; Right-Click, Undo to Previous Point of Fence. ; ;; u, Undo to Previous Point of Fence. ; ;; Space, Terminates the Command. ; ;; Enter, Terminates the Command. ; ;; ; (defun c:dlbl (/ *AcadDoc* *error* *util* angl b code ent errl i id loop lst lwp maj mtxtlst obj obj1 obj2 p point prev space ss text) (vl-load-com) ;;; Error Handler by ElpanovEvgenyi ; (defun *error* (msg) (mapcar 'eval errl) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*"))) (princ (strcat "\nError: " msg)) ) (and *AcadDoc* (vla-endundomark *AcadDoc*)) (princ) ) (setq errl '("CLAYER" "OSMODE" "CMDECHO" "DIMZIN") errl (mapcar (function (lambda (a) (list 'setvar a (getvar a)))) errl) ) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (setvar 'CMDECHO 0) (setvar 'DIMZIN 0) (setvar 'OSMODE 0) (defun Intersections (obj1 obj2 mode) ;; Return list of intersection(s) between two objects ;; obj1 - first VLA-Object ;; obj2 - second VLA-Object ;; mode - intersection mode (acExtendNone acExtendThisEntity acExtendOtherEntity acExtendBoth) ;; Alan J. Thompson, 12.13.10 ((lambda (foo) (foo (vlax-invoke obj1 'IntersectWith obj2 mode))) (lambda (l) (if (cddr l) (cons (list (car l) (cadr l) (caddr l)) (foo (cdddr l))) ) ) ) ) (defun AngleAtPoint (e p) ;; Return angle along curve, at specified point (on curve) ;; e - valid curve (ENAME or VLA-OBJECT) ;; p - point on curve ;; Alan J. Thompson, 11.04.10 (angle '(0. 0. 0.) (vlax-curve-getFirstDeriv e (vlax-curve-getParamAtPoint e p))) ) (defun MakeReadable (ang) ;; Make angle readable ;; Alan J. Thompson, 12.14.10 (if (and (> ang (/ pi 2.)) (<= ang (* pi 1.5))) (+ ang pi) ang ) ) (defun _lwp (l) (vlax-ename->vla-object (entmakex (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length l)) '(70 . 0) ) (mapcar '(lambda (p) (cons 10 (trans (list (car p) (cadr p)) 1 0))) l) ) ) ) ) ;; mk_layer by CAB at TheSwamp.org ; ;; Optionnal Arguments by ymg. ; ;; Routine to ENTAKE a TEXT entity. ; ;; ; ;; If the layer already exist, it will be: thawed ; ;; set on ; ;; unlocked ; ;; set as the current layer. ; ;; ; (defun mk_layer (argl / lay Color ltype) (setq lay (car argl) color (cadr argl) ltype (caddr argl) ) (if (tblsearch "LAYER" lay) (progn (if color (progn (setq ent (tblobjname "LAYER" lay) ent (entget ent) ent (subst (cons 62 color) (assoc 62 ent) ent) ) (entmod ent) ) ) (if ltype (progn (setq ent (tblobjname "LAYER" lay) ent (entget ent) ent (subst (cons 6 ltype) (assoc 6 ent) ent) ) (entmod ent) ) ) (command "._Layer" "_Thaw" lay "_On" lay "_UnLock" lay "_Set" lay "") ) (progn (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 lay) (cons 70 0) (cons 62 (if (or (null color)(= Color "")) 7 Color)) (cons 6 (if (or (null ltype)(= ltype "")) "Continuous" ltype)) (cons 290 1) (cons 370 -3) ) ) ) ) ) (defun getmtext (plst / ) (setq mtxtlst nil) (if maj (setq ss (ssget "_F" plst (list '(0 . "LWPOLYLINE")(cons 8 "Contour Major")))) (setq ss (ssget "_F" plst (list '(0 . "LWPOLYLINE")(cons 8 "Contour Major,Contour Minor")))) ) (if ss (progn (setq lwp (_lwp plst) space (if (eq (getvar 'CVPORT) 1) (vla-get-paperspace *AcadDoc*) (vla-get-modelspace *AcadDoc*) ) point (vlax-3d-point '(0. 0. 0.)) angl (if (zerop (getvar 'WORLDUCS)) (angle '(0. 0. 0.) (trans (getvar 'UCSXDIR) 0 (trans '(0. 0. 1.) 1 0 t) t)) 0. ) *util* (vla-get-utility *AcadDoc*) ) (mk_layer (list "Contour Label")) (repeat (setq i (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))) id (if (vlax-method-applicable-p *util* 'GetObjectIdString) (vla-GetObjectIdString *util* obj :vlax-false) (itoa (vla-get-ObjectId obj)) ) ) (vla-put-elevation lwp (vla-get-elevation obj)) (foreach p (Intersections lwp obj acExtendNone) (setq text (vla-addMText space point 0. (strcat "%<\\AcObjProp.16.2 Object(%<\\_ObjId " id ">%).Elevation \\f \"%lu2%pr2%zs8\">%" ) ) ) (vlax-put-property text 'BackgroundFill :vlax-true) (vla-put-attachmentpoint text acAttachmentPointMiddleCenter) (vla-put-insertionpoint text (vlax-3d-point p)) (vla-put-rotation text (MakeReadable (- (AngleAtPoint obj p) angl))) (setq mtxtlst (cons (entlast) mtxtlst)) (vlax-release-object text) ) ) (if lwp (progn (entdel (vlax-vla-object->ename lwp)) (vlax-release-object lwp) (vlax-release-object obj) ) ) ) ) mtxtlst ) (setq loop t lst nil prev nil ) (vla-startundomark *AcadDoc*) (while loop (setq code (grread t ) (cond ((= (car code) 5) (if lst (progn (redraw) (if prev (mapcar 'entdel prev)) (setq prev (getmtext (cons (cadr code) lst))) (mapcar '(lambda (a b) (grdraw a b 2 1)) lst (cons (cadr code) lst) ) ) ) ) ((= (car code) 3) (setq lst (cons (cadr code) lst))) ; Left Click, Add point to fence. ; ((= (car code) 25) (if (> (length lst) 1) (setq lst (cdr lst)))) ; Right Click, Undo. ; ((equal code '(2 13)) (redraw)(setq loop nil)) ; Enter, Exit the loop. ; ((equal code '(2 32)) (redraw)(setq loop nil)) ; Space, Exit the loop. ; ((equal code '(2 9)) (if maj (setq maj nil)(setq maj t))) ; Tab, toggles majcontour only. ; ((equal code '(2 117))(if (> (length lst) 1) (setq lst (cdr lst)))) ; u, Undo. ; ((equal code '(2 85)) (if (> (length lst) 1) (setq lst (cdr lst)))) ; U, Undo. ; ((equal code '(2 43)) (setvar 'textsize (+ (getvar 'textsize) 0.5))) ; +, Increase Text Size. ; ((equal code '(2 45)) (setvar 'textsize (- (getvar 'textsize) 0.5))) ; -, Decrease Text Size. ; ) ) (*error* nil) ) ymg Edited November 27, 2013 by ymg3 Quote
Lee Mac Posted November 27, 2013 Posted November 27, 2013 Here's another program that may help: http://www.cadtutor.net/forum/showthread.php?82346-Level-lines-calculate-height&p=562138&viewfull=1#post562138 Quote
hawstom Posted February 20, 2017 Posted February 20, 2017 Here's another one that's pretty robust with options to elevate and label: http://autocad.wikia.com/wiki/Contour_Elevations_at_Intervals_with_Labels_(AutoLISP_application) Quote
