Baiksu Posted November 28, 2013 Share Posted November 28, 2013 Hi I inserted a block containing attributes to a drawing following all the process but still looks too big,the block. How does that happen? Suzy Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 28, 2013 Share Posted November 28, 2013 sorry, there's not really enough information to go on. The fact that the block has attributes is irrelevant, they don't affect the size in any way. Are you inserting a block into an existing drawing? If so, how much too big is the block. If it is about 25 times too big there is probably a misunderstanding between block and drawing, one is metric and the other imperial. Check the properties of the block. What scale is it? Quote Link to comment Share on other sites More sharing options...
Baiksu Posted November 29, 2013 Author Share Posted November 29, 2013 Hi, I am just doing exercise from the book & it says to create Attribute & blocks and insert to the drawing, it said to set the dwg for 1:100 annotation scale. I looked the Drawing unit, it is in decimal. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 29, 2013 Share Posted November 29, 2013 Sounds like you have set the attribute text to be annotative it will get big and small but line work will not, need to think about text size sometimes in a block with relation to plotted scale. 1:100 text 2.5 ? Quote Link to comment Share on other sites More sharing options...
