Hi,
Im a bit of a lisp novice and am struggling with expending on a lisp routine I have been trying to write.
The routine takes a piece of text which is a number, stores the x,y and z (which is the number) and then inserts a block to those coordinates.
What I wrote so far works for a single piece of text but I've been scratching my head about how I can get it to work with multiple items, I've had a look at the 'while' function but I'm not getting it.
Does anyone have any tips to share to get me moving again?
;Get text points GB 06.12.13
(defun c:GTP ()
	(prompt "\nSelect text entities : ")	;Create windowed selection set
	(setq a (ssget))			;Store
	(setq b (entlast))			;Store entitys
	(setq c (entget b))			;Store Item
	(setq xyzval (cdr (assoc 10 c)))	;Store xyz of text
	(setq zval (cdr (assoc 1 c)))		;Extract Text value and store as z
	(setq xval (nth 0 xyzval))		;Seperate x
	(setq xval (rtos xval))			;Store x as string
	(setq yval (nth 1 xyzval))		;Seperate y
	(setq yval (rtos yval))			;Store y as string
	(setq xyzval (strcat xval  "," yval "," zval))	;Create x,y,z
	(command "-insert" "I:/Users/Graham/Documents/work/Carriage/Blocks/m10_nut" xyzval "1" "1" "0")	;Insert block
Please take care that ENTLAST is taking the last entity added to database and had nothing to do with the selection performed on previous statement.
I see what your saying, that has just made my issue worse :unsure:
On parsing the selection set created by SSGET, I suggest you to read this tutorial written by LeeMac.
May want also to take a look in help for SSGET filters.
Would something like this work for you? If so, I would be happy to explain what is going on.
(defun c:GTP ( / ss no p1)
       (setq ss (ssget '( (0 . "TEXT") ))
             no 0 )
           (while
               (< no (sslength ss) )
               (setq p1 (cdr (assoc 10 (entget (ssname ss no)))) )
                   (command "_.-insert" "I:/Users/Graham/Documents/work/Carriage/Blocks/m10_nut" p1 "1" "1" "0")
               (setq no (1+ no) )
Thanks CheSyn the 'while\repeat' function worked great, but it didn't put the block on the z value depicted in the text value, Ill try and fathom it, thanks a lot for answering
I have managed to get it working but I'm sure the code is not efficient:
Thanks a lot for your help CheSyn and MSasu not only for the assistance in this application but in helping me understand looping better.
(defun c:GTP ()
(setq a (ssget '( (0 . "TEXT") ))
	no 0 )
(while
	(< no (sslength a))
		(setq 	xyzval (cdr (assoc 10 (entget (ssname a no)))) )
		(setq	zval (cdr (assoc 1 (entget (ssname a no)))) )
	(setq no (1+ no) )
I have tweaked your routine with some comments:
(defun c:GTP( / selSet entity pointText pointBlock no )    [color=blue];don't forget to localize variables[/color]
(setq no 0 )                                              [color=blue];initiate counter here to avoid usage of PROGN[/color]
(if (setq selSet (ssget '((0 . "TEXT") )))                [color=blue];make sure user is making a valid selection[/color]
 (while (< no (sslength selSet))
  (setq entity       (entget (ssname selSet no))          [color=blue];not need to retrieve the entity twice from selection set[/color]
        pointText    (cdr (assoc 10 entity)))
  [color=blue];a point may be a list, may avoid inputting it as string[/color]
  (setq pointBlock (list (nth 0 pointText)                [color=blue];there is no need for those intermediate variables[/color]
                         (nth 1 pointText)
                         (distof (cdr (assoc 1 entity)))))
  [color=blue];use an underscore on command call to take care of localized AutoCADs[/color]
  (command "_-insert" "I:/Users/Graham/Documents/work/Carriage/Blocks/m10_nut" pointBlock "1" "1" "0")
  (setq no (1+ no))
Please try to use relevant names for variables, it will be easier later to revise the code; also avoid using the same variable to store different types (i.e. xyzval was used for a point, then a string).
Mircea , The name of the selection set with the sslength function is wrong . :)
Thanks for observation Tharwat; I believe that you noticed one of the intermediate "releases" (I edited the code here).
Correct , and I have been in these situation before . :D
Excellent MSasu,
Looks like you took pity on me in the end,
I appreciate you breaking the code down for me and making it more efficient and I shall endeavor to understand it.
Thanks a lot
You're entirely welcome! I'm happy to see people struggling to learn, so hope that that will be useful to your progress.
