potencjalek Posted January 12, 2014 Share Posted January 12, 2014 i try to export data do external application from Autocad i have one problem i cannot create proper null character for that file i need null character for determine end of string in that file function (write-line (strcat "text" (chr 256))) doesn't create null sign on the end of line attached file i want to create (please open it by notepad++ to see null character) is it possible to create such a file by lisp? null_charakter.txt Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted January 12, 2014 Share Posted January 12, 2014 Try the following [color=GREEN];; Null Character Example by Lee Mac 2014-01-12[/color] ([color=BLUE]defun[/color] nullchartest ( str txt [color=BLUE]/[/color] fso stm ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] fso ([color=BLUE]vlax-create-object[/color] [color=MAROON]"scripting.filesystemobject"[/color])) ([color=BLUE]progn[/color] ([color=BLUE]vl-catch-all-apply[/color] '([color=BLUE]lambda[/color] ( ) ([color=BLUE]setq[/color] stm ([color=BLUE]vlax-invoke[/color] fso 'createtextfile txt -1 0)) ([color=BLUE]vlax-invoke[/color] stm 'write ([color=BLUE]strcat[/color] str ([color=BLUE]chr[/color] 256))) ([color=BLUE]vlax-invoke[/color] stm '[color=BLUE]close[/color]) ) ) ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'vla-object ([color=BLUE]type[/color] stm)) ([color=BLUE]vlax-release-object[/color] stm) ) ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'vla-object ([color=BLUE]type[/color] fso)) ([color=BLUE]vlax-release-object[/color] fso) ) ([color=BLUE]findfile[/color] txt) ) ) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) Test program: ([color=BLUE]defun[/color] c:test ( ) (nullchartest [color=MAROON]"line-text"[/color] ([color=BLUE]vl-filename-mktemp[/color] [color=MAROON]"test"[/color] ([color=BLUE]getvar[/color] 'dwgprefix) [color=MAROON]".txt"[/color])) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 13, 2014 Share Posted January 13, 2014 When you write a normal line of text if you hex dump it it will actually have two codes as end of string OD & OA this is carriage return & line feed. Can you not check for these codes if your reading the file like a database and 1 character at a time. If I remember correct is (chr 13) Quote Link to comment Share on other sites More sharing options...
potencjalek Posted January 13, 2014 Author Share Posted January 13, 2014 Try the following [color=GREEN];; Null Character Example by Lee Mac 2014-01-12[/color] ([color=BLUE]defun[/color] nullchartest ( str txt [color=BLUE]/[/color] fso stm ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] fso ([color=BLUE]vlax-create-object[/color] [color=MAROON]"scripting.filesystemobject"[/color])) ([color=BLUE]progn[/color] ([color=BLUE]vl-catch-all-apply[/color] '([color=BLUE]lambda[/color] ( ) ([color=BLUE]setq[/color] stm ([color=BLUE]vlax-invoke[/color] fso 'createtextfile txt -1 0)) ([color=BLUE]vlax-invoke[/color] stm 'write ([color=BLUE]strcat[/color] str ([color=BLUE]chr[/color] 256))) ([color=BLUE]vlax-invoke[/color] stm '[color=BLUE]close[/color]) ) ) ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'vla-object ([color=BLUE]type[/color] stm)) ([color=BLUE]vlax-release-object[/color] stm) ) ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'vla-object ([color=BLUE]type[/color] fso)) ([color=BLUE]vlax-release-object[/color] fso) ) ([color=BLUE]findfile[/color] txt) ) ) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) Test program: ([color=BLUE]defun[/color] c:test ( ) (nullchartest [color=MAROON]"line-text"[/color] ([color=BLUE]vl-filename-mktemp[/color] [color=MAROON]"test"[/color] ([color=BLUE]getvar[/color] 'dwgprefix) [color=MAROON]".txt"[/color])) ) works perfectly for me thank you very much i think its time to donate your website Quote Link to comment Share on other sites More sharing options...
potencjalek Posted January 13, 2014 Author Share Posted January 13, 2014 one more question i tried to change little bit your function to write more then one line (defun nullchartest ( str txt / fso stm ) (if (setq fso (vlax-create-object "scripting.filesystemobject")) (progn (vl-catch-all-apply '(lambda ( ) (setq stm (vlax-invoke fso 'createtextfile txt -1 0)) (vlax-invoke stm 'write (strcat str (chr 256))) (vlax-invoke stm 'write (strcat "text for line 2" (chr 256))) ;;;;;changes (vlax-invoke stm 'close) ) ) (if (= 'vla-object (type stm)) (vlax-release-object stm) ) (if (= 'vla-object (type fso)) (vlax-release-object fso) ) (findfile txt) ) ) ) but in results it write only one (first) line, why is that? Quote Link to comment Share on other sites More sharing options...
potencjalek Posted January 14, 2014 Author Share Posted January 14, 2014 ok, topic closed i figured it out i forgot about (vlax-invoke stm 'write (chr 10)) ;;; starting next line between lines thanks you all for help Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted January 14, 2014 Share Posted January 14, 2014 works perfectly for methank you very much i think its time to donate your website Excellent, I'm glad it works as required. Thank you also for your kind offer of a donation, I appreciate it but in results it write only one (first) line, why is that? As you have gathered, a carriage return & line feed are required for a new line: ;; Null Character Example by Lee Mac 2014-01-14 (defun nullchartest ( txt / fso stm ) (if (setq fso (vlax-create-object "scripting.filesystemobject")) (progn (vl-catch-all-apply '(lambda ( ) (setq stm (vlax-invoke fso 'createtextfile txt -1 0)) (vlax-invoke stm 'write (strcat "This is line 1" (chr 256) "\r\nThis is line 2" (chr 256) ) ) (vlax-invoke stm 'close) ) ) (if (= 'vla-object (type stm)) (vlax-release-object stm) ) (if (= 'vla-object (type fso)) (vlax-release-object fso) ) (findfile txt) ) ) ) Quote Link to comment Share on other sites More sharing options...
