Faouweb Posted January 18, 2014 Posted January 18, 2014 Hi I have made a Part and added some ILogic code, if i change the length of the Part the numbers of holes change, as you can see in the picture: The problem is, if i click on the red cross to close the window without selecting any value the Part disappear What I have to add at my code to solve the problem? I know that with Case we usually use Default, but it does not work in my code Here is the code: longueur = InputListBox("Prompt", MultiValue.List("longueur"), longueur, Title := "Faouweb", ListName := "List") Select Case longueur Case 24.64 d20 = 2 Case 37.3 d20 = 3 Case 88.2 d20 = 7 End Select iLogicVb.UpdateWhenDone = True The file is bellow. Thank you Part1.zip Quote
