loveboatcaptain Posted January 28, 2014 Posted January 28, 2014 I have a drawing that contains a map area to XY coordinates (MAP.dwg) I am trying to create a lisp that will create & insert a block by grabbing element info from the MAP.dwg area (using user input) to XY co-ordinates The lisp would need to open the MAP.dwg, copy elements from specified user XY co-ords, then insert as a block into the current drawing. I want the inserted block to be a consistent sized square. Can anyone help or has anyone done something similar? Quote
loveboatcaptain Posted January 28, 2014 Author Posted January 28, 2014 I am currently using the below multiple lisps, one at a time, but want to automate it into one click. \\INSERTS UKMAP (defun C:insert_railmapuk ( ) (command "insunits" "4") (command "osmode" "0" ) (command "-layer" "set" "0" "") (command "-insert" "*UK" "0,0" "1" "0") (princ) ) \\INSERTS RAIL LOCATION MAP BOX (defun C:INSERTZZMAP ( ) (command "INSUNITS" "4") (command "-insert" "*scalemapmodel" pause "1" "0") (princ) ) \\CREATES MAP BLOCK (defun C:CREATEZZMAP ( ) (command "-BLOCK" "MAP" "Y" pause) (princ) ) \\DELETES UKMAP IGNORES MAP BLOCK (defun c:DELZZMAP (/ ss i sset e) (if (setq ss (ssget "_x" '((8 . "_ACM-BLCK-UKMAP-LANDLINE,_ACM-BLCK-UKMAP-RAIL,_ACM-BLCK-UKMAP-STATION,_ACM-BLCK-UKMAP-STATION NAME")))) (repeat (setq i (sslength ss)) (setq sset (ssname ss (setq i (1- i)))) (setq e (entget sset)) (if (not (eq (cdr (assoc 2 e))"MAP")) (entdel sset) ) ) (princ) ) (princ) ) \\SCALES MAP BLOCK IN PAPER SPACE (defun C:SCALEZZMAP ( ) (sssetfirst nil (ssget "_x" '((0 . "INSERT")(2 . "MAP")))) (command "SCALE" "p" "" "1059,397.2416" "0.01") (princ) ) \\INSERTS RED DOT (defun C:LOCATEZZMAP ( ) (command "insunits" "4") (command "osmode" "0" ) (command "-layer" "set" "0" "") (command "-insert" "*reddot" pause "1" "0") (princ) ) Quote
BIGAL Posted January 29, 2014 Posted January 29, 2014 If you look into writing a script its pretty do able, just open master dwg it writes the xy to a txt file open second dwg via script block is inserted, you can do stuff like jump between dwgs code is it a bit more complex. A script can run multiple lisps one after each other. Quote
