"-BEdit" Multiple Blocks
Marcelo Marani
Hi all!
Please, someone can help me with this? I make this following LISP for edit a block and erase solids and hatch, but I need click one by one.
I want make a window selection and then the LISP edit one by one alone.
(defun C:Clean()
(vl-load-com)
(cond ((and (setq ent (car (entsel "\nSelecione o Bloco: ")))
(eq (cdr (assoc 0 (entget ent))) "INSERT")
(setq NAME (vla-get-effectivename(vlax-ename->vla-object ent))))))
(command "-bedit" NAME)
(setq HT (ssget "all" '((0 . "HATCH"))))
(command "erase" HT "")
(setq SS (ssget "all" '((0 . "SOLID"))))
(command "erase" SS "")
(command "chprop" "all" "" "Color" "bylayer" "")
(command "bclose" "S")
Thanks!
Edited by Marcelo Marani
A few suggestions maybe zoom in on each block or hatch and ask delete yes /no use as a yes any key as a no. You just need to use the following example code. This is not complete.
(sslength ht) ; this tells you how many objects
(repeat (sslength ht)) ;a loop that goes through all the object in the selection set
(ssname ht x) ; this retrieves the object based on the value of x start at 0
(command "erase" (ssname ht x) "") ; removes object
(entget (ssname ht 2)) ; look at 2nd object in HT use this for zooming etc
Thanks for reply BIGAL,
but I dont understand where I can place this codes....
For example, the client send me a file with many blocks with solids and hatchs inside of the block, and I need erase all solids and hatchs inside off all blocks...
Not tested, but try:
(defun C:Clean ( / bl ss i ent name h s )
 (vl-load-com)
 (setq bl (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
 (while (not ss)
   (if (setq ss (ssget "_:L" '((0 . "INSERT"))))
       (setq i -1)
       (while (setq ent (ssname ss (setq i (1+ i))))
         (setq name (vla-get-effectivename (vlax-ename->vla-object ent)))
         (if (eq (vla-get-isxref (vla-item bl name)) :vlax-false)
             (command "_.bedit" name)
             (setq h (ssget "all" '((0 . "HATCH"))))
             (command "_.erase" h "")
             (setq s (ssget "all" '((0 . "SOLID"))))
             (command "_.erase" s "")
             (command "_.chprop" "all" "" "Color" "ByLayer" "")
             (command "_.bclose" "S")
     (prompt "\nEmpty sel.set... Select again...")
Also this, by Tharwat (updated to include "SOLID")
http://www.cadtutor.net/forum/showthread.php?80180-Deleting-Hatch-from-Blocks
(vl-load-com)
(defun c:Test (/ b o)
   ;;--- Tharwat 26.June.2013 ---;;
   (or doc
       (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
   (vlax-for b
             (vla-get-blocks
                 doc
       (if (and
               (eq :vlax-false (vla-get-isLayout b))
               (eq :vlax-false (vla-get-isXref b))
           (vlax-for o b
               (if [b][color=red](or[/color][/b]
                       (eq "AcDbHatch" (vla-get-objectname o))
                       [b][color=red](eq "AcDbSolid" (vla-get-objectname o))[/color][/b]
[b][color=red]                   )[/color][/b]
                   (vl-catch-all-apply 'vla-delete (list o))
   (vla-regen doc acAllViewports)
marko_ribar
Thanks Marko_ribar... this works but edit all blocks in the drawing (around 1500) include block without hatchs and solids and get a "INTERNAL ERROR" and close AutoCad. (my fail dont explain better)
GP_
http://www.cadtutor.net/forum/showth...ch-from-Blocks
GP_
This work perfect! Thanks!
For edit blocks to change colors for "BYLAYER" is possible too?
Add...
[color=slategray]................[/color]
[color=slategray](vlax-for o b[/color]
[color=slategray]    (if (or[/color]
[color=slategray]            (eq "AcDbHatch" (vla-get-objectname o))[/color]
[color=slategray]            (eq "AcDbSolid" (vla-get-objectname o))[/color]
[color=slategray]        )[/color]
[color=slategray]        (vl-catch-all-apply 'vla-delete (list o))[/color]
       [color=red][b](vla-put-color o "256")[/b][/color]
[color=slategray])[/color]
Try this one ...
(vl-load-com)
 ;;---     Tharwat 2014         ---;;
 (or doc (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))))
 (vlax-for b (vla-get-blocks doc )
   (if
     (and
     (vlax-for o b
       (if (or
         (vl-catch-all-apply 'vla-put-color (list o AcBylayer))
