Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
  1. #21
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    Fjärdhundra, Sweden
    5,148
    Ok, I inserted the drawing as an exploded block in another file, then I can Zoom and Pan as normal...
    tried all the tricks I know; Recover, Save to Dxf, Save to old DXF/DWG, purge, -purge, audit.... but Insert as block worked.
    Just realised that I removed all the blocks in the drawing before I inserted it as a block, so that could change things.
    MTJIGSTRING = BAZINGA
  2. #22
    Forum Newbie
    Civil
    AdrianR's Discipline Details
    Designer
    Civil
    Civil 3D 2014
    Feb 2014
    South Carolina
    8
    I tried copybase and pasting this drawing and another drawing that was doing the same thing into a new drawing and I could zoom in then. So I guess I could do that whenever this happens, it's just a pain to have to do. I was hoping there was a limits setting or something else I had wrong that would fix this.
    Thanks all!
  3. #23
    Forum Newbie
    Incadnito's Computer Details
    Windows 7
    AutoCAD 2012
    Nov 2010
    Denmark
    9
    Hey..
    Had this problem myself a couple of times
    My fix/hack is to activate viewcube and press "top"
    Downloaded your file and couldn't scrollzoom aswell. Did the above - and voila - no prob
  4. #24
    AutoCAD 2013
    Nov 2011
    5,985
    Quote Originally Posted by Incadnito View Post
    Hey..
    Right you are Incadnito, I was having about as much luck as everbody else, until I tried your fix, and all of a sudden, no problem!
    While the issue is odd and annoying, this fix is pretty painless, good call.
    It seems like the ZOOM to extents after view change option in the View Cube settings is resolving
    whatever the hang up is with the terminal Zoom issue.
  5. #25
    Forum Newbie
    Civil
    Designer
    Civil
    Civil 3D 2014
    Feb 2014
    South Carolina
    8
    Thank you x 1000000!! I tried this in a few drawings and it works!!
  6. #26
    Forum Newbie
    Architectural
    AutoCAD 2016
    Mar 2017
    1
    Default Similar problem - instant fix
    Hi there
    I have been having similar problems with not being able to zoom in as far as I want and I have just discovered what the issue was. now I have no problems.
    I had my view type on perspective rather than parallel. near the top left of your viewport, click on the view next to the + and change to parallel and you should have no more problems.
    Hope that helps!!
  7. #27
    Forum Newbie
    AutoCAD 2014
    May 2015
    1
    Hi Incadnito,
    My answer is a bit late now, but I am so grateful for your perfect and simple solution, that I have to write it down.
    Thank you very much!
  1. Completely lost
    By Quick Karl in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Apr 2012, 03:11 pm
  2. zoom extends doesn't zoom completely (hidden objects issue)
    By khoshravan in forum AutoCAD General
    Last Post: 4th Jul 2011, 06:21 am
  3. completely new
    By Precursor in forum AutoCAD Beginners' Area
    Last Post: 7th Dec 2005, 09:04 am
