muzicman82 Posted February 13, 2014 Share Posted February 13, 2014 Hi all, I know this has probably been asked but I don't know what you'd call it. When I start making a selection window, and then pan mid-selection, it the selection window only selects what is in the view on the last click. How do I make the selection window include everything from the first click to the last, even after I pan? Using AutoCAD 2014. Quote Link to comment Share on other sites More sharing options...
MSasu Posted February 13, 2014 Share Posted February 13, 2014 I'm afraid that is a known bug (comming along from many releases) - seems that isn't solved in release 2014 yet. Quote Link to comment Share on other sites More sharing options...
muzicman82 Posted February 13, 2014 Author Share Posted February 13, 2014 Bug? Geez. Seems to me like this should be a preference? Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 13, 2014 Share Posted February 13, 2014 Bug? Geez. Seems to me like this should be a preference?You can get it to keep your selection by selecting before you enter the command. Set the variables pickfirst to 1, and pickadd to 1. It is only when running the command before doing the selections that the dropping off occurs. Quote Link to comment Share on other sites More sharing options...
rkent Posted February 13, 2014 Share Posted February 13, 2014 You can get it to keep your selection by selecting before you enter the command. Set the variables pickfirst to 1, and pickadd to 1. It is only when running the command before doing the selections that the dropping off occurs. It doesn't work that way here with 2014, what is selected and panned off the screen is dropped. Quote Link to comment Share on other sites More sharing options...
