gpd Posted February 16, 2014 Posted February 16, 2014 Dear Members Consider the attached drawing. It contains one block and a line touching its base point. Distance between the start point of line and the base point of block is 0.0, still below lisp code returns nil. Please guide what is the reason. (setq ss(ssget "X" (list (cons 0 "INSERT")(cons 10 spt)))) spt is the start point of the line. Thanks. ssget.dwg Quote
Tharwat Posted February 16, 2014 Posted February 16, 2014 That 's due to the Z coordinates of the block Quote
pBe Posted February 16, 2014 Posted February 16, 2014 (edited) To "see" what "Z" coordinates tharwat mentioned above Select the block then select the line (setq BockInsertionPoint (cdr (Assoc 10 (entget (Car (entsel)))))) (setq LineStartpoint (Vlax-curve-getstartpoint (car (entsel)))) Edited February 16, 2014 by pBe Quote
GP_ Posted February 16, 2014 Posted February 16, 2014 (setq spt (getpoint)) ;[b]BLOCK -> insert point[/b] (619827.0 2.61951e+006 [color=red]1.11028e-011[/color]) _$ (setq ss(ssget "X" (list (cons 0 "INSERT")(cons 10 spt)))) [color=royalblue][b]<Selection set: 3da>[/b][/color] _$ (setq spt (getpoint)) ;[b]POLYLINE -> end point[/b] (619827.0 2.61951e+006 [color=red]0.0[/color]) _$ (setq ss(ssget "X" (list (cons 0 "INSERT")(cons 10 spt)))) [color=royalblue][b]nil[/b] [/color] _$ Oops... @Tharwat & pBe Sorry, I wrote without seeing your answers Quote
pBe Posted February 16, 2014 Posted February 16, 2014 (setq ss (ssget "_X" (list '(0 . "INSERT") '(-4 . "=,=,*") (cons 10 spt)) ) ) Quote
GP_ Posted February 16, 2014 Posted February 16, 2014 (list '(0 . "INSERT") [b]'(-4 . "=,=,*")[/b] (cons 10 spt)) Good stuff Quote
Stefan BMR Posted February 16, 2014 Posted February 16, 2014 You can use a fuzz factor: (setq f '(0.02 0.02 0.02) l (mapcar '- spt f) r (mapcar '+ spt f) ss (ssget "X" (list '(0 . "INSERT") '(-4 . ">,>,>") (cons 10 l) '(-4 . "<,<,<") (cons 10 r) ) ) ) The fuzz factor can be set to be equal to cursor size (setq f (/ (* (getvar 'cursorsize) (getvar 'viewsize) 0.5) (cadr (getvar 'screensize)) ) ) Quote
gpd Posted February 16, 2014 Author Posted February 16, 2014 Thanks everyone for the response. Block properties indicate that its elevation is 0. Quote
Lee Mac Posted February 16, 2014 Posted February 16, 2014 Block properties indicate that its elevation is 0. The values in the properties palette are rounded to the precision given by the LUPREC system variable; to see the true coordinate values to their stored precision, use the following: (defun c:blkins ( / s ) (if (setq s (ssget "_+.:E:S" '((0 . "INSERT")))) (princ (apply 'strcat (mapcar 'strcat '("\n" " " " ") (mapcar '(lambda ( x ) (rtos x 2 15)) (cdr (assoc 10 (entget (ssname s 0)))) ) ) ) ) ) (princ) ) Quote
