nod684 Posted February 20, 2014 Posted February 20, 2014 Our company has this habit of hatching an object twice using the AR-CONC and ANSI31 patterns respectively using 100 as hatch scale. is it possible to have a routine than can do this automatically by picking in the internal points or just by selecting the closed object? Quote
BIGAL Posted February 20, 2014 Posted February 20, 2014 Closed 0bject is the best just need to run a simple VLA-addhatch twice. Just looking for example its vla-addhatch mspace hatch-pattern obj etc trying to find where I put it. Quote
BIGAL Posted February 20, 2014 Posted February 20, 2014 Quick and dirty pick a pline. (setq obj (entsel)) (command "-hatch" "p" "ansi31" 1 0 "S" obj "" "") (command "-hatch" "p" "solid" 1 0 "S" obj "" "") Quote
hugha Posted February 20, 2014 Posted February 20, 2014 You could combine the two patterns, pre-scaled by 100, as a custom pattern: *AR-CONC-ANSI131X100,Random dot and stone pattern plus ANSI31 scaled by 100 ;------------------------------------------------------------------------------- ; Pattern written by HatchKit v2.7 Hatch Pattern Editor ; HatchKit v2.7 Hatch Pattern Editor© Cadro Pty Ltd 1990-2014. ; www.hatchkit.com.au ;------------------------------------------------------------------------------- ;-Template=AR-CONC, Random dot and stone pattern ;-Source =G:\Users\Hugh\Desktop\TestHatches\ANSI31X100.PAT ;-Date =21/02/2014 ;-Time =12:57:59 AM ;------------------------------------------------------------------------------- 71.4514447388,149.74,116.45,191.82358991,693.976736169,63.74,-701.14230388 -34.0000000164,100,150,516.218792505,737.236840008,60,-659.999999993 21,100,150,487.024966,589.789472,75,-825 96.6356447388,88.937,186.21,287.735384866,1040.96510425,95.61,-1051.71345582 -8.81580001637,0,200,774.328188758,1105.85526001,90,-989.999999989 46.1842,0,200,730.537449,884.684208,112.5,-1237.5 100.451444739,59.772,-5.2293,191.82358991,693.976736169,63.74,-701.14230388 -5.00000001637,0,0,516.218792505,737.236840008,60,-659.999999993 50,0,0,487.024966,589.789472,75,-825 7.75374509883,0,0,56.9612851418,328.209676876,0,-1552.1210552 7.75374509883,517.27,396.91,56.9612851418,328.209676876,0,-1552.1210552 7.75374509883,1048.8,804.78,56.9612851418,328.209676876,0,-1552.1210552 9.74000554536,-323,0,214.228105711,1248.03846346,0,-591.715400847 9.74000554536,-83.385,-219.57,214.228105711,1248.03846346,0,-591.715400847 9.74000554536,298.52,-569.52,214.228105711,1248.03846346,0,-591.715400847 68.8819167095,645.69,-553.42,921.397900388,506.097174029,0,-1092.68936556 68.8819167095,-12.152,-134.32,921.397900388,506.097174029,0,-1092.68936556 68.8819167095,-223,0,921.397900388,506.097174029,0,-1092.68936556 56.2970215044,0,0,110.616853275,956.652017074,0,-474.095117039 56.2970215044,378.73,49.861,110.616853275,956.652017074,0,-474.095117039 56.2970215044,1010.3,133.01,110.616853275,956.652017074,0,-474.095117039 45,0,0,0,12.5 hth, Hugh Adamson www.hatchkit.com.au Quote
nod684 Posted February 21, 2014 Author Posted February 21, 2014 You could combine the two patterns, pre-scaled by 100, as a custom pattern: *AR-CONC-ANSI131X100,Random dot and stone pattern plus ANSI31 scaled by 100 ;------------------------------------------------------------------------------- ; Pattern written by HatchKit v2.7 Hatch Pattern Editor ; HatchKit v2.7 Hatch Pattern Editor© Cadro Pty Ltd 1990-2014. ; www.hatchkit.com.au ;------------------------------------------------------------------------------- ;-Template=AR-CONC, Random dot and stone pattern ;-Source =G:\Users\Hugh\Desktop\TestHatches\ANSI31X100.PAT ;-Date =21/02/2014 ;-Time =12:57:59 AM ;------------------------------------------------------------------------------- 71.4514447388,149.74,116.45,191.82358991,693.976736169,63.74,-701.14230388 -34.0000000164,100,150,516.218792505,737.236840008,60,-659.999999993 21,100,150,487.024966,589.789472,75,-825 96.6356447388,88.937,186.21,287.735384866,1040.96510425,95.61,-1051.71345582 -8.81580001637,0,200,774.328188758,1105.85526001,90,-989.999999989 46.1842,0,200,730.537449,884.684208,112.5,-1237.5 100.451444739,59.772,-5.2293,191.82358991,693.976736169,63.74,-701.14230388 -5.00000001637,0,0,516.218792505,737.236840008,60,-659.999999993 50,0,0,487.024966,589.789472,75,-825 7.75374509883,0,0,56.9612851418,328.209676876,0,-1552.1210552 7.75374509883,517.27,396.91,56.9612851418,328.209676876,0,-1552.1210552 7.75374509883,1048.8,804.78,56.9612851418,328.209676876,0,-1552.1210552 9.74000554536,-323,0,214.228105711,1248.03846346,0,-591.715400847 9.74000554536,-83.385,-219.57,214.228105711,1248.03846346,0,-591.715400847 9.74000554536,298.52,-569.52,214.228105711,1248.03846346,0,-591.715400847 68.8819167095,645.69,-553.42,921.397900388,506.097174029,0,-1092.68936556 68.8819167095,-12.152,-134.32,921.397900388,506.097174029,0,-1092.68936556 68.8819167095,-223,0,921.397900388,506.097174029,0,-1092.68936556 56.2970215044,0,0,110.616853275,956.652017074,0,-474.095117039 56.2970215044,378.73,49.861,110.616853275,956.652017074,0,-474.095117039 56.2970215044,1010.3,133.01,110.616853275,956.652017074,0,-474.095117039 45,0,0,0,12.5 hth, Hugh Adamson www.hatchkit.com.au wow.. i never though of that... besides i don't know how to code the pattern anyway... thanks! a lot will try this out and give feedback Quote
BIGAL Posted February 21, 2014 Posted February 21, 2014 hugha the ar-conc pattern has a nasty habit of not working and requiring resetting of the origin point if working in real world co-ords so not sure aout combining two hatches. Quote
nod684 Posted February 21, 2014 Author Posted February 21, 2014 it says missing pattern at Line 33 Quote
hugha Posted February 21, 2014 Posted February 21, 2014 it says missing pattern at Line 33 nod684, add an extra blank line at the end of the file and try again. BIGAL, try it anywhere you like - HatchKit recalculates poorly specified patterns to work at high co-ordinates. We explain this at http://www.hatchkit.com.au/faq.php#Tip2 Hugh Adamson www.hatchkit.com.au Quote
nod684 Posted February 21, 2014 Author Posted February 21, 2014 nod684, add an extra blank line at the end of the file and try again. BIGAL, try it anywhere you like - HatchKit recalculates poorly specified patterns to work at high co-ordinates. We explain this at http://www.hatchkit.com.au/faq.php#Tip2 Hugh Adamson www.hatchkit.com.au now it says missing parameter at Line 33 then ? on the next line... Quote
hugha Posted February 21, 2014 Posted February 21, 2014 Try the attached file (remove the .txt extension first!) AR-CONC-ANSI131X100.PAT.txt Quote
hmsilva Posted February 21, 2014 Posted February 21, 2014 (edited) Our company has this habit of hatching an object twice using the AR-CONC and ANSI31 patterns respectively using 100 as hatch scale. is it possible to have a routine than can do this automatically by picking in the internal points or just by selecting the closed object? In addition to what BIGAL said, and as a demo for select an object or pick a point: (defun c:Myh ( / pt) (vl-load-com) (defun isclosed (pt / msg vlaobj) (setq vlaobj (vlax-ename->vla-object pt) msg "\nNot a closed Entity!!!") (cond ((wcmatch (vla-get-objectname vlaobj) "AcDbEllipse") (if (and (= (vlax-curve-getStartParam vlaobj) 0.0) (= (vlax-curve-getEndParam vlaobj) (* pi 2)) );; and (bhatchobj pt) (prompt msg) );; if ) ((wcmatch (vla-get-objectname vlaobj) "AcDbSpline,*Polyline") (if (= (vla-get-closed vlaobj) :vlax-true) (bhatchobj pt) (prompt msg) );; if ) ((wcmatch (vla-get-objectname vlaobj) "AcDbCircle") (bhatchobj pt) (prompt msg) ) ((prompt msg)) );; cond );; isclosed (defun bhatchpt (pt) (command "-bhatch" "_P" "AR-CONC" "100" "0" pt "" "-bhatch" "_P" "ANSI31" "100" "0" pt "") );; bhatchpt (defun bhatchobj (pt) (command "-bhatch" "_P" "AR-CONC" "100" "0" "_S" pt "" "" "-bhatch" "_P" "ANSI31" "100" "0" "_S" pt "" "") );; bhatchobj ;; Rebuilt by me ;; from Tony Tanzillo's SelectObjectOrWindow (defun hms:SelP ( / ans) (setvar "errno" 0) (if (setq ans (entsel "\nSelect Closed Object or Pick a Point <exit>: ")) (car ans) (if (and (eq 7 (getvar "errno")) (setq ans (grread t)) );;and (setq ans (cadr ans)) );; if );; if );; hms:SelP (while (setq pt (hms:SelP)) (cond ((and pt (= (type pt) 'ENAME)) (isclosed pt) ) (pt (bhatchpt pt) ) );; cond );; while (princ) );; myh HTH Henrique Edited February 22, 2014 by hmsilva typo in BIGAL name, sorry Quote
nod684 Posted February 22, 2014 Author Posted February 22, 2014 Try the attached file (remove the .txt extension first!) thanks a lot! its working fine now... however can i request to change the scale of concrete to 25 and the ansi31 to 100? sorry i don't know where to edit that in the pattern. In addition to what BIGALL said, and as a demo for select an object or pick a point: (defun c:Myh ( / pt) (vl-load-com) (defun isclosed (pt / msg vlaobj) (setq vlaobj (vlax-ename->vla-object pt) msg "\nNot a closed Entity!!!") (cond ((wcmatch (vla-get-objectname vlaobj) "AcDbEllipse") (if (and (= (vlax-curve-getStartParam vlaobj) 0.0) (= (vlax-curve-getEndParam vlaobj) (* pi 2)) );; and (bhatchobj pt) (prompt msg) );; if ) ((wcmatch (vla-get-objectname vlaobj) "AcDbSpline,*Polyline") (if (= (vla-get-closed vlaobj) :vlax-true) (bhatchobj pt) (prompt msg) );; if ) ((wcmatch (vla-get-objectname vlaobj) "AcDbCircle") (bhatchobj pt) (prompt msg) ) ((prompt msg)) );; cond );; isclosed (defun bhatchpt (pt) (command "-bhatch" "_P" "AR-CONC" "100" "0" pt "" "-bhatch" "_P" "ANSI31" "100" "0" pt "") );; bhatchpt (defun bhatchobj (pt) (command "-bhatch" "_P" "AR-CONC" "100" "0" "_S" pt "" "" "-bhatch" "_P" "ANSI31" "100" "0" "_S" pt "" "") );; bhatchobj ;; Rebuilt by me ;; from Tony Tanzillo's SelectObjectOrWindow (defun hms:SelP ( / ans) (setvar "errno" 0) (if (setq ans (entsel "\nSelect Closed Object or Pick a Point <exit>: ")) (car ans) (if (and (eq 7 (getvar "errno")) (setq ans (grread t)) );;and (setq ans (cadr ans)) );; if );; if );; hms:SelP (while (setq pt (hms:SelP)) (cond ((and pt (= (type pt) 'ENAME)) (isclosed pt) ) (pt (bhatchpt pt) ) );; cond );; while (princ) );; myh HTH Henrique Thanks so much Henrique...working fine! i superb! Quote
hugha Posted February 22, 2014 Posted February 22, 2014 thanks a lot! its working fine now...however can i request to change the scale of concrete to 25 and the ansi31 to 100? sorry i don't know where to edit that in the pattern. You'll see the unbroken line from ANSI131 remains scaled by 100 while the broken lines forming AR-CONC are now scaled by 25 instead of 100. You can do this sort of thing in Excel, just scale every number in the pattern except the first on each line (which should remain unchanged) but I'm using something else for this. hth, Hugh Adamson www.hatchkit.com.au AR-CONCX25-ANSI131X100.PAT.txt Quote
nod684 Posted February 22, 2014 Author Posted February 22, 2014 thanks a lot hugha! really appreciated Quote
hmsilva Posted February 22, 2014 Posted February 22, 2014 ... Thanks so much Henrique...working fine! i superb! You're welcome. Glad I could help Henrique Quote
