Structural Steel Section Pull Down Menu
Ok people this is my first post and I have had a read through the site, I'm currently looking for a program which allows you via pull down menu to select a steel section (British) I used to have one at my last place of work which saved mega time and effort. It was called Turbo steel and basically it inserted the section of your choice to scale. If anyone out there has a similar menufile could you please post it for myself and the rest of the members.
Thank you
Scottish-lawd
Hi Scottish-lawd...
You're in luck - I'm not often on this site any more, but I do have what you're looking for...you'll need three files - here's the first
(defun C:STEELS (/ SIZA dcl_id)
 (initerr)
 (setq userclick1 T)
 (setvar "OSMODE" 0)
 (setvar "CMDECHO" 0)
 (setq SIZA "UBEAM")
 (setq dcl_id (load_dialog "steels.dcl"))
 (if (not (new_dialog "steels" dcl_id))
   (exit)
 (setq w (dimx_tile "im")
      h (dimy_tile "im"))
    (start_image "im")
    (fill_image 0 0 w h 5)
    (setq w1 (/ w 2))
    (setq h1 (/ h 2))
    (vector_image 0 h w1 0 2)
    (vector_image w1 0 w h 2)
    (vector_image 0 h w1 h1 2)
    (vector_image w1 h1 w h 2)
    (end_image)
 (action_tile
   "UB"
   "(setq SIZA \"UBEAM\")"
 (action_tile
   "UC"
   "(setq SIZA \"UCOLUM\")"
 (action_tile
   "JO"
   "(setq SIZA \"JOIST\")"
 (action_tile
   "TFC"
   "(setq SIZA \"CHAN\")"
 (action_tile
   "PFC"
   "(setq SIZA \"PCHAN\")"
 (action_tile
   "ELA"
   "(setq SIZA \"RSA\")"
 (action_tile
   "ULA"
   "(setq SIZA \"URSA\")"
 (action_tile
   "RCR"
   "(setq SIZA \"SHOLL\")"
 (action_tile
   "CCR"
   "(setq SIZA \"CHOLL\")"
 (action_tile
   "cancel"
   "(done_dialog)(setq userclick nil)"
 (action_tile
   "accept"
   "(done_dialog) (setq userclick T)"
 (start_dialog)
 (unload_dialog dcl_id)
 (if userclick
     (if (eq SIZA "UBEAM")
   (UBEAM)
     (if (eq SIZA "UCOLUM")
   (UCOLUM)
     (if (eq SIZA "JOIST")
   (JOIST)
     (if (eq SIZA "CHAN")
   (CHAN)
     (if (eq SIZA "CHOLL")
   (CHOLL)
     (if (eq SIZA "RSA")
   (RSA)
     (if (eq SIZA "URSA")
   (URSA)
     (if (eq SIZA "SHOLL")
   (SHOLL)
     (if (eq SIZA "PCHAN")
   (PCHAN)
   )                    ;progn
 )                    ;if
 (reset)
 (if (= userclick1 nil)
   (c:steels)
)                    ;defun
(defun UBEAM (/        SIZA      size    file  fp    item  data    maxs  count
         chrct numb  dlist    X     Y        Z      IP    P1    P2
         P3    P4      P5    P6    P7    P8      P9    P10   P11
         P12   P13      P14    P15   P16   P17      P18    P19   P20
         P21   NAMES
;;;*CONVERT TO RADIANS
 (setq    X (* pi (/ 90.0 180.0))
   Y pi
   Z (* pi (/ 270.0 180.0))
 )                    ;setq
;;;*INITIALISE
 (setq    NAMES '("127x76x13"        "152x89x16"
       "178x102x19"        "203x102x23"
       "203x133x25"        "203x133x30"
       "254x102x22"        "254x102x25"
       "254x102.28"        "254x146x31"
       "254x146x37"        "254x146x43"
       "305x102x25"        "305x102x28"
       "305x102x33"        "305x127x37"
       "305x127x42"        "305x127x48"
       "305x165x40"        "305x165x46"
       "305x165x54"        "356x127x33"
       "356x127x39"        "356x171x45"
       "356x171x51"        "356x171x57"
       "356x171x67"        "406x140.39"
       "406x140x46"        "406x178x54"
       "406x178x60"        "406x178x67"
       "406x178x74"        "457x152x52"
       "457x152x60"        "457x152x67"
       "457x152x74"        "457x152x82"
       "457x191x67"        "457x191x74"
       "457x191x82"        "457x191x89"
       "457x191x98"        "533x210x82"
       "533x210x92"        "533x210x101"
       "533x210x109"        "533x210x122"
       "610x229x101"        "610x229x113"
       "610x229x125"        "610x229x140"
       "610x305x149"        "610x305x179"
       "610x305x238"        "686x254x125"
       "686x254x140"        "686x254x152"
       "686x254x170"        "762x267x134"
       "762x267x147"        "762x267x173"
       "762x267x197"        "838x292x176"
       "838x292x194"        "838x292x226"
       "914x305x201"        "914x305x224"
       "914x305x253"        "914x305x289"
       "914x419x343"        "914x419x388"
       "1016x305x222"        "1016x305x249"
       "1016x305x272"        "1016x305x314"
       "1016x305x349"        "1016x305x393"
       "1016x305x437"        "1016x305x487"
 (if (not (new_dialog "ubeam" dcl_id))
   (exit)
 (start_list "selections")
 (mapcar 'add_list NAMES)
 (end_list)
 (action_tile
   "cancel"
   "(done_dialog) (setq userclick1 nil)"
 (action_tile
   "accept"
   (strcat
     "(progn (setq SIZA (atof (get_tile \"selections\")))"
     "(done_dialog) (setq userclick1 T))"
 (start_dialog)
 (if userclick1
     (setq SIZA (fix SIZA))
     (setq SIZA (nth SIZA NAMES))
     (grab)
;;;*THIS ROUTINE DRAWS A UNIVERSAL BEAM.
     (mapcar 'set '(H B T1 T2 R1) dlist)
     (setvar "OSMODE" OLDSNAP)
     (while
     (setq IP (getpoint "\nInsertion Point: "))
     (setvar "OSMODE" 0)
     (setq P1    (polar IP 0 (/ T1 2))
       P2    (polar P1 X (/ (- H (+ T2 T2 R1 R1)) 2))
       P3    (polar P2 X R1)
       P4    (polar P3 0 R1)
       P5    (polar P4 0 (/ (- B (+ T1 R1 R1)) 2))
       P6    (polar P5 X T2)
       P7    (polar P6 Y B)
       P8    (polar P7 Z T2)
       P9    (polar P8 0 (/ (- B (+ T1 R1 R1)) 2))
       P10    (polar P9 0 R1)
       P11    (polar P10 Z R1)
       P12    (polar P11 Z (- H (+ T2 T2 R1 R1)))
       P13    (polar P12 Z R1)
       P14    (polar P13 Y R1)
       P15    (polar P14 Y (/ (- B (+ T1 R1 R1)) 2))
       P16    (polar P15 Z T2)
       P17    (polar P16 0 B)
       P18    (polar P17 X T2)
       P19    (polar P18 Y (/ (- B (+ T1 R1 R1)) 2))
       P20    (polar P19 Y R1)
       P21    (polar P20 X R1)
     )                    ;setq
     (command "PLINE"         P1        "W"       "0.0"  "0.0"     P2    "ARC"
          P4     "LINE" P5        P6       P7      P8     P9    "ARC"
          P11    "LINE" P12    "ARC"  P14      "LINE" P15    P16
          P17    P18    P19    "ARC"  P21      "LINE" P1    ""
         )                ;command
     (prompt "\nRotation Angle: ")
     (command "ROTATE"
          "LAST"
          IP
          pause
     );command
   );while
   )                    ;progn
 )                    ;if
)                    ;defun UBEAM
(defun UCOLUM (/     SIZA   size     file  fp    item  data     maxs  count
          P21   NAMES
   Y pi
 )                    ;setq
;;;*INITIALISE
 (setq    NAMES '("152x152x23"       "152x152x30"
       "152x152x37"       "203x203x46"
       "203x203x52"       "203x203x60"
       "203x203x72"       "203x203x86"
       "254x254x73"       "254x254x89"
       "254x254x107"       "254x254x132"
       "254x254x167"       "305x305x97"
       "305x305x118"       "305x305x137"
       "305x305x158"       "305x305x198"
       "305x305x240"       "305x305x283"
 (if (not (new_dialog "ucolum" dcl_id))
   (exit)
 (end_list)
 (action_tile
   "cancel"
 (action_tile
   "accept"
   (strcat
     " (done_dialog)(setq userclick1 T))"
 (start_dialog)
 (if userclick1
     (grab)
;;;*THIS ROUTINE DRAWS A UNIVERSAL COLUMN.
     (while
     (setvar "OSMODE" 0)
       P3    (polar P2 X R1)
       P4    (polar P3 0 R1)
       P6    (polar P5 X T2)
       P7    (polar P6 Y B)
       P8    (polar P7 Z T2)
       P10    (polar P9 0 R1)
       P17    (polar P16 0 B)
     )                    ;setq
         )                ;command
     (command "ROTATE"
          "LAST"
          IP
          pause
     )                    ;command
     );while
   )                    ;progn
 )                    ;if
)                    ;defun UCOLUM
(defun CHAN (/      SIZA  size file fp   item data    maxs count     chrct
        numb dlist        X     Y    Z       IP    P1   P2      P3   P4
        P5      P6   P7   P8     P9   P10  P11    P15  P16  P17  H1
        H2      H3   H4   H5     B1   B2   B3    B4   NAMES
   Y pi
 )                    ;setq
;;;*INITIALISE
 (setq    NAMES '("100x50x11"     "120x55x13"      "140x60x16"
       "160x65x19"     "180x70x22"      "200x75x25"
       "220x80x29"     "240x85x32"      "260x90x38"
       "300x100x46"     "76x38x7"      "127x64x15"
       "152x76x18"     "178x54x15"      "381x102x55"
 (if (not (new_dialog "chan" dcl_id))
   (exit)
 (end_list)
 (action_tile
   "cancel"
 (action_tile
   "accept"
   (strcat
 (start_dialog)
 (if userclick1
     (grab)
;;;*THIS ROUTINE DRAWS A TAPERED FLANGE CHANNEL.
     (mapcar 'set '(H B H1 H2 H3 H4 H5 B1 B2 B3 B4) dlist)
     (while
     (setvar "OSMODE" 0)
     (setq P1    (polar IP Z H)
       P2    (polar P1 0 B)
       P3    (polar P2 X H1)
       P4    (polar P3 X H2)
       P5    (polar P4 Y B4)
       P6    (polar P5 Y B3)
       P7    (polar P6 X H3)
       P8    (polar P7 Y B2)
       P9    (polar P8 X H4)
       P10    (polar P9 X H5)
       P11    (polar P10 X H4)
       P12    (polar P11 0 B2)
       P13    (polar P12 X H3)
       P14    (polar P13 0 B3)
       P15    (polar P14 0 B4)
       P16    (polar P15 X H2)
       P17    (polar P16 X H1)
     )                    ;setq
     (command "PLINE"         IP        "W"       "0.0"  "0.0"     P1    P2
          P3     "ARC"  P5        "LINE" P7      "ARC"     P9    "LINE"
          P10    "ARC"  P12    "LINE" P14      "ARC"     P16    "LINE"
          P17    "Close"
         )                ;command
     (command "ROTATE"
          "LAST"
          IP
          pause
     )                    ;command
     );while
   )                    ;progn
 )                    ;if
)                    ;defun CHAN
(defun CHOLL (/ D D1 IP)
 (initget 1)
   D  (getreal "\nOutside Diameter: ")
   D1 (getreal "\nInside Diameter: ")
   D  (/ D 2)
   D1 (/ D1 2)
 )                    ;setq
 (setvar "OSMODE" 0)
 (command "CIRCLE"
      IP
      D
      "CIRCLE"
      IP
      D1
 )                    ;command
(defun RSA (/      SIZA    fp    size  file  item    data  maxs  count chrct
       numb  dlist    A     C        IP      P1    P2    P3    P4      P5
       P6      P7    P8    P9    P10      P11    NAMES
 (setq    A (* pi (/ 90.0 180.0))
   C pi
 )                    ;setq
;;;*INITIALISE
 (setq    NAMES '("25x25x3"    "25x25x5"    "30x30x3"
       "30x30x5"    "40x40x3"    "40x40x5"
       "40x40x6"    "45x45x3"    "45x45x5"
       "45x45x6"    "50x50x5"    "50x50x6"
       "50x50x8"    "60x60x5"    "60x60x6"
       "60x60x8"    "60x60x10"    "70x70x6"
       "70x70x8"    "70x70x10"    "80x80x6"
       "80x80x8"    "80x80x10"    "80x80x12"
       "90x90x8"    "90x90x10"    "90x90x12"
       "100x100x8"    "100x100x10"    "100x100x12"
       "100x100x15"    "120x120x10"    "120x120x12"
       "120x120x15"    "150x150x12"    "150x150x15"
       "150x150x18"    "200x200x16"    "200x200x18"
       "200x200x20"    "200x200x24"
 (if (not (new_dialog "rsa" dcl_id))
   (exit)
 (end_list)
 (action_tile
   "cancel"
 (action_tile
   "accept"
   (strcat
 (start_dialog)
 (if userclick1
     (grab)
;;;*THIS ROUTINE DRAWS A ROLLED STEEL ANGLE.
     (mapcar 'set '(H B T1 R1 R2) dlist)
     (while
     (setvar "OSMODE" 0)
     (setq P1    (polar IP 0 B)
       P2    (polar P1 A (- T1 R2))
       P3    (polar P2 A R2)
       P4    (polar P3 C R2)
       P5    (polar P4 C (- B (+ T1 R1 R2)))
       P6    (polar P5 C R1)
       P7    (polar P6 A R1)
       P8    (polar P7 A (- H (+ T1 R1 R2)))
       P9    (polar P8 A R2)
       P10    (polar P9 C R2)
       P11    (polar P10 C (- T1 R2))
     )                    ;setq
     (command "PLINE"         IP        "W"       "0.0"  ""     P1    P2
          "ARC"  P4     "LINE" P5       "ARC"  P7     "LINE"    P8
          "ARC"  P10    "LINE" P11       "Close"
         )                ;command
     (command "ROTATE"
          "LAST"
          IP
          pause
     )                    ;command
     );while
   )                    ;progn
 )                    ;if
)                    ;defun RSA
(defun URSA (/       SIZA     size  file  fp       item     data  maxs  count
        chrct numb     dlist A     C       IP     P1    P2    P3
        P4       P5     P6    P7    P8       P9     P10   P11   NAMES
   C pi
 )                    ;setq
;;;*INITIALISE
 (setq    NAMES '("65x50x6"    "65x50x8"    "75x50x6"
       "75x50x8"    "80x60x6"    "80x60x8"
       "90x65x6"    "90x65x8"    "90x65x10"
       "100x65x8"    "100x65x10"    "100x75x6"
       "100x75x8"    "100x75x10"    "100x75x12"
       "125x75x8"    "125x75x10"    "125x75x12"
       "150x75x10"    "150x75x12"    "150x75x15"
       "150x90x10"    "150x90x12"    "150x90x15"
 (if (not (new_dialog "ursa" dcl_id))
   (exit)
 (end_list)
 (action_tile
   "cancel"
 (action_tile
   "accept"
   (strcat
 (start_dialog)
 (if userclick1
     (grab)
     (while
     (setvar "OSMODE" 0)
       P3    (polar P2 A R2)
       P4    (polar P3 C R2)
       P6    (polar P5 C R1)
       P7    (polar P6 A R1)
       P9    (polar P8 A R2)
       P10    (polar P9 C R2)
     )                    ;setq
         )                ;command
     (command "ROTATE"
          "LAST"
          IP
          pause
     )                    ;command
     );while
   )                    ;progn
 )                    ;if
)                    ;defun URSA
(defun SHOLL (/    x y z h    b t1 r1    r2 h1 b1 p1 p2 p3 p4 p5    p6 p7 p8 p9 p10
         p11 p12 p13)
 (setq    x (* pi (/ 90.0 180.0))
   y pi
   z (* pi (/ 270.0 180.0))
 )                    ;setq
 (initget 1)
 (setq ip (getpoint "\nInsertion Point <Pick Point>: "))
 (initget 7)
 (setq h (getreal "\nHeight of Section <mm>: "))
 (initget 7)
 (setq b (getreal "\nWidth of Section <mm>: "))
 (initget 7)
 (setq t1 (getreal "\nWall Thickness <mm>: "))
 (setq    r2 (/ t1 2)
   h1 (- h t1 t1)
   b1 (- b t1 t1)
   r1 (+ t1 r2)
 )                    ;setq
 (setvar "OSMODE" 0)
 (repeat 2
   (setq p1  (polar ip 0 (/ b 2))
     p2  (polar p1 x (/ (- h r1 r1) 2))
     p3  (polar p2 x r1)
     p4  (polar p3 y r1)
     p5  (polar p4 y (- b r1 r1))
     p6  (polar p5 y r1)
     p7  (polar p6 z r1)
     p8  (polar p7 z (- h r1 r1))
     p9  (polar p8 z r1)
     p10 (polar p9 0 r1)
     p11 (polar p10 0 (- b r1 r1))
     p12 (polar p11 0 r1)
     p13 (polar p12 x r1)
   )                    ;setq
   (command "Pline"       p1      "W"     "0.0"    "0.0"  p2     "Arc"
        p4        "Line" p5      "Arc"     p7    "Line" p8     "Arc"
        p10    "Line" p11      "Arc"     p13    "Line" p1     ""
       )                ;command
   (setq h  h1
     b  b1
     r1 r2
   )                    ;setq
 )                    ;repeat
)                    ;defun
(defun JOIST (/       SIZA    size file fp   item data maxs count    chrct
         P5   P6    P7   P8      P9   P10  P11     P15  P16  P17    P18
         P19  P20    P21  P22  P23  P24  P25     P26  P27  P28    P29
         P30  P31    P32  P33  H1   H2   H3     H4   H5   B1    B2
         B3   B4
   Y pi
 )                    ;setq
;;;*INITIALISE
 (setq    NAMES '("127x76x13"      "152x89x17"        "178x102x22"
       "203x102x25"      "203x152x52"        "254x152x59"
       "305x152x66"
 (if (not (new_dialog "joist" dcl_id))
   (exit)
 (end_list)
 (action_tile
   "cancel"
 (action_tile
   "accept"
   (strcat
 (start_dialog)
 (if userclick1
     (grab)
;;;*THIS ROUTINE DRAWS A JOIST.
     (while
     (setvar "OSMODE" 0)
     (setq P1    (polar IP 0 B1)
       P2    (polar P1 X (/ H5 2))
       P3    (polar P2 X H4)
       P4    (polar P3 0 B2)
       P5    (polar P4 X H3)
       P6    (polar P5 0 B3)
       P7    (polar P6 0 B4)
       P8    (polar P7 X H2)
       P9    (polar P8 X H1)
       P10    (polar P9 Y B)
       P11    (polar P10 Z H1)
       P12    (polar P11 Z H2)
       P13    (polar P12 0 B4)
       P15    (polar P14 Z H3)
       P16    (polar P15 0 B2)
       P17    (polar P16 Z H4)
       P18    (polar P17 Z H5)
       P19    (polar P18 Z H4)
       P20    (polar P19 Y B2)
       P21    (polar P20 Z H3)
       P22    (polar P21 Y B3)
       P23    (polar P22 Y B4)
       P24    (polar P23 Z H2)
       P25    (polar P24 Z H1)
       P26    (polar P25 0 B)
       P27    (polar P26 X H1)
       P28    (polar P27 X H2)
       P29    (polar P28 Y B4)
       P30    (polar P29 Y B3)
       P31    (polar P30 X H3)
       P32    (polar P31 Y B2)
       P33    (polar P32 X H4)
     )                    ;setq
          P4     "LINE" P6        "ARC"  P8      "LINE" P9    P10
          P11    "ARC"  P13    "LINE" P15      "ARC"     P17    "LINE"
          P18    "ARC"  P20    "LINE" P22      "ARC"     P24    "LINE"
          P25    P26    P27    "ARC"  P29      "LINE" P31    "ARC"
          P33    "LINE" P1        ""
         )                ;command
     (command "ROTATE"
          "LAST"
          IP
          pause
     )                    ;command
     );while
   )                    ;progn
 )                    ;if
)                    ;defun JOIST
(defun PCHAN (/        SIZA      size    file  fp    item  data    maxs  count
         NAMES
   Y pi
 )                    ;setq
;;;*INITIALISE
 (setq    NAMES '("100x50x10"     "120x55x13"      "140x60x15"
       "160x65x18"     "180x70x21"      "200x75x24"
       "220x80x28"     "240x85x32"      "260x90x36"
       "280x95x41"     "300x100x45"
 (if (not (new_dialog "pchan" dcl_id))
   (exit)
 (end_list)
 (action_tile
   "cancel"
 (action_tile
   "accept"
   (strcat
 (start_dialog)
 (if userclick1
     (grab)
;;;*THIS ROUTINE DRAWS A PARALLEL FLANGE CHANNEL.
     (while
     (setvar "OSMODE" 0)
       P2    (polar P1 0 B)
       P3    (polar P2 X T2)
       P4    (polar P3 Y (- B (+ R1 T1)))
       P5    (polar P4 Y R1)
       P6    (polar P5 X R1)
       P7    (polar P6 X (- H (+ T2 T2 R1 R1)))
       P8    (polar P7 X R1)
       P9    (polar P8 0 R1)
       P10    (polar P9 0 (- B (+ R1 T1)))
       P11    (polar P10 X T2)
     )                    ;setq
          P3     P4     "ARC"  P6       "LINE" P7     "ARC"    P9
          "LINE" P10    P11    "Close"
         )                ;command
     (command "ROTATE"
          "LAST"
          IP
          pause
     )                    ;command
     );while
   )                    ;progn
 )                    ;if
)                    ;defun PCHAN
;;;*FILE & INFORMATION RETRIEVAL ROUTINE.
(defun grab ()
 (setq    dlist nil
   size  (strcat "*" SIZA)
   file  (findfile "steels.DAT")
   fp    (open file "r")
   item  (read-line fp)
 )                    ;setq
 (while item
   (if    (= item size)
     (setq data (read-line fp)
       item nil
     )                    ;setq
     (setq item (read-line fp))
   )                    ;if
 )                    ;while
 (if data
     (setq maxs  (strlen data)
       count 1
       chrct 1
     )                    ;setq
     (while (< count maxs)
   (if (/= "," (substr data count 1))
     (setq chrct (1+ chrct))
     (setq    numb  (atof (substr data (1+ (- count chrct)) chrct))
       dlist (append dlist (list numb))
       chrct 1
     )                ;setq
   )                ;if
   (setq count (1+ count))
     )                    ;while
     (setq numb  (atof (substr data (1+ (- count chrct))))
     )                    ;setq
   )                    ;progn
 )                    ;if data
 (close fp)
)                    ;defun
(defun initerr ()
 (setq oldlayer (getvar "clayer"))
 (setq oldsnap (getvar "osmode"))
 (setq oldpick (getvar "pickbox"))
 (setq temperr *error*)
 (setq *error* trap)
)                    ;defun
(defun trap (errmsg)
 (command nil nil nil)
 (if (not (member errmsg '("console break" "Function Cancelled"))
   (princ (strcat "\nError: " errmsg))
 (setvar "clayer" oldlayer)
 (setvar "menuecho" 0)
 (setvar "highlight" 1)
 (setvar "osmode" oldsnap)
 (setvar "pickbox" oldpick)
 (princ "\nError Resetting Enviroment ")
 (terpri)
 (setq *error* temperr)
)                    ;defun
(defun reset ()
)                    ;defun
Hi...
You need to copy that last file to the clipboard and paste it using notepad into a file called steels.lsp.
Here's the code for the second file - it's not as long as the last one
steels : dialog {
   label = "Steel Sections (Metric)";
     : boxed_radio_column {
     label = "Available Sections";
       : radio_button {
         label = "Universal &Beams";
         key = "UB";
         value = "1";
       : radio_button {
         label = "Universal &Columns";
         key = "UC";
       : radio_button {
         label = "&Joists";
         key = "JO";
       : radio_button {
         label = "&Tapered Flange Channels";
         key = "TFC";
       : radio_button {
         label = "&Parallel Flange Channels";
         key = "PFC";
       : radio_button {
         label = "&Equal Leg Angles";
         key = "ELA";
       : radio_button {
         label = "U&n-Equal Leg Angles";
         key = "ULA";
       : spacer { width = 1;}
       : radio_button {
         label = "&Rectangular Cold Rolled";
         key = "RCR";
       : radio_button {
         label = "&Circular Cold Rolled";
         key = "CCR";
  ok_cancel ;
  : row {
                : image {
                  key = "im" ;
                  height = 1.0 ;
                  width = 4.0 ;
              : paragraph {
        : text_part {
                  label = "Designed and Created";
                : text_part {
                  label = "by AMEC Design and Management";
ubeam : dialog {
       label = "U.B's.";
    : list_box {
       label = "&Choose Section :";
       key = "selections";
       height = 12;
       allow_accept = true ;
    ok_cancel ;
    :text_part {
    :text_part {
chan : dialog {
       label = "R.S.C's.";
    : list_box {
       key = "selections";
       height = 12;
    ok_cancel ;
    :text_part {
    :text_part {
joist : dialog {
       label = "R.S.J's.";
    : list_box {
       key = "selections";
       height = 8;
    ok_cancel ;
    :text_part {
    :text_part {
pchan : dialog {
       label = "P.F.C's.";
    : list_box {
       key = "selections";
       height = 12;
    ok_cancel ;
    :text_part {
    :text_part {
rsa : dialog {
       label = "R.S.A's.";
    : list_box {
       key = "selections";
       height = 12;
    ok_cancel ;
    :text_part {
    :text_part {
ucolum : dialog {
       label = "U.C's.";
    : list_box {
       key = "selections";
       height = 12;
    ok_cancel ;
    :text_part {
    :text_part {
ursa : dialog {
       label = "U.R.S.A's.";
    : list_box {
       key = "selections";
       height = 12;
    ok_cancel ;
    :text_part {
    :text_part {
And the last file...
**TAPERED FLANGE CHANNELS
*100x50x11
100.0,50.0,1.9,4.9,2.5,9.2,63.0,6.0,8.5,31.0,4.5
*120x55x13
120.0,55.0,2.3,4.9,2.8,9.7,80.6,7.0,9.0,34.5,4.5
*140x60x16
140.0,60.0,2.6,5.4,3.1,10.8,96.2,7.0,10.0,38.0,5.0
*160x65x19
160.0,65.0,2.4,6.0,3.3,11.4,113.8,7.5,10.5,41.5,5.5
*180x70x22
180.0,70.0,2.7,6.0,3.7,11.9,131.4,8.0,11.0,45.5,5.5
*200x75x25
200.0,75.0,2.5,6.5,3.9,12.5,149.2,8.5,11.5,49.0,6.0
*220x80x29
220.0,80.0,2.8,7.0,4.2,13.5,165.0,9.0,12.5,52.0,6.5
*240x85x32
240.0,85.0,3.1,7.0,4.5,14.1,182.6,9.5,13.0,56.0,6.5
*260x90x38
260.0,90.0,3.4,7.6,4.8,15.1,198.2,10.0,14.0,59.0,7.0
*300x100x46
300.0,100.0,4.0,8.7,5.3,17.3,229.4,10.0,16.0,66.0,8.0
**OLD IMPERIAL TAPERED FLANGE CHANNELS
*76x38x7
76.0,38.0,2.9,2.6,2.0,8.3,44.4,5.1,7.6,22.9,2.4
*127x64x15
127.0,64.0,4.3,2.6,3.9,11.7,82.0,6.4,10.7,44.5,2.4
*152x76x18
152.0,76.0,6.7,2.6,4.8,13.3,97.2,6.4,12.2,55.0,2.4
*178x54x15
178.0,54.0,4.3,3.3,1.3,8.6,143.0,5.8,8.3,36.7,3.2
*381x102x55
381.0,102.0,6.4,5.2,6.3,16.6,312.0,10.4,15.2,71.6,4.8
**PARALLEL FLANGE CHANNELS
**H B T1 T2 R1
*100x50x10
100.0,50.0,5.0,8.4,8.4
*120x55x13
120.0,55.0,5.5,9.1,9.1
*140x60x15
140.0,60.0,6.0,9.9,9.9
*160x65x18
160.0,65.0,6.5,10.4,10.4
*180x70x21
180.0,70.0,7.0,10.9,10.9
*200x75x24
200.0,75.0,7.5,11.4,11.4
*220x80x28
220.0,80.0,7.9,12.5,12.5
*240x85x32
240.0,85.0,8.4,13.0,13.0
*260x90x36
260.0,90.0,8.8,13.9,13.9
*280x95x41
280.0,95.0,9.2,14.8,14.8
*300x100x45
300.0,100.0,9.6,15.5,15.5
**ROLLED STEEL JOISTS DATA
*127x76x13
127.0,76.2,3.6,2.6,2.2,8.6,93.0,2.3,7.9,25.6,2.3
*152x89x17
154.4,88.9,4.1,2.6,2.8,8.6,116.2,2.45,7.9,31.7,2.4
*178x102x22
177.8,102.0,3.7,3.5,3.1,10.3,136.6,2.6,9.4,35.8,3.2
*203x102x25
203.2,101.6,5.1,3.5,3.9,9.4,159.4,2.9,9.4,35.3,3.2
*203x152x52
203.0,152.0,3.8,8.7,6.8,17.8,128.8,4.4,15.5,48.5,7.6
*254x152x59
254.0,152.0,5.3,8.7,6.8,17.8,176.8,4.6,15.5,48.3,7.6
*305x152x66
305.0,152.0,5.5,8.7,6.7,17.8,227.6,5.1,15.5,47.8,7.6
**ROLLED STEEL ANGLE DATA
**H X B X T1 X R1 X R2
*25x25x3
25.0,25.0,3.0,3.5,2.0
*25x25x5
25.0,25.0,5.0,3.5,2.0
*30x30x3
30.0,30.0,3.0,5.0,2.5
*30x30x5
30.0,30.0,5.0,5.0,2.5
*35x35x3
35.0,35.0,3.0,5.0,2.5
*35x35x5
35.0,35.0,5.0,5.0,2.5
*40x40x3
40.0,40.0,3.0,6.0,3.0
*40x40x5
40.0,40.0,5.0,6.0,3.0
*40x40x6
40.0,40.0,6.0,6.0,3.0
*45x45x3
45.0,45.0,3.0,7.0,3.5
*45x45x5
45.0,45.0,5.0,7.0,3.5
*45x45x6
45.0,45.0,6.0,7.0,3.5
*50x50x5
50.0,50.0,5.0,7.0,3.5
*50x50x6
50.0,50.0,6.0,7.0,3.5
*50x50x8
50.0,50.0,8.0,7.0,3.5
*60x60x5
60.0,60.0,5.0,8.0,4.0
*60x60x6
60.0,60.0,6.0,8.0,4.0
*60x60x8
60.0,60.0,8.0,8.0,4.0
*60x60x10
60.0,60.0,10.0,8.0,4.0
*70x70x6
70.0,70.0,6.0,9.0,4.5
*70x70x8
70.0,70.0,8.0,9.0,4.5
*70x70x10
70.0,70.0,10.0,9.0,4.5
*80x80x6
80.0,80.0,6.0,10.0,5.0
*80x80x8
80.0,80.0,8.0,10.0,5.0
*80x80x10
80.0,80.0,10.0,10.0,5.0
*80x80x12
80.0,80.0,12.0,10.0,5.0
*90x90x8
90.0,90.0,8.0,11.0,5.5
*90x90x10
90.0,90.0,10.0,11.0,5.5
*90x90x12
90.0,90.0,12.0,11.0,5.5
*100x100x8
100.0,100.0,8.0,12.0,6.0
*100x100x10
100.0,100.0,10.0,12.0,6.0
*100x100x12
100.0,100.0,12.0,12.0,6.0
*100x100x15
100.0,100.0,15.0,12.0,6.0
*120x120x10
120.0,120.0,10.0,13.0,6.5
*120x120x12
120.0,120.0,12.0,13.0,6.5
*120x120x15
120.0,120.0,15.0,13.0,6.5
*150x150x12
150.0,150.0,12.0,16.0,8.0
*150x150x15
150.0,150.0,15.0,16.0,8.0
*150x150x18
150.0,150.0,18.0,16.0,8.0
*200x200x16
200.0,200.0,16.0,18.0,9.0
*200x200x18
200.0,200.0,18.0,18.0,9.0
*200x200x20
200.0,200.0,20.0,18.0,9.0
*200x200x24
200.0,200.0,24.0,18.0,9.0
**UNIVERSAL BEAMS DATA
**H X B X T1 X T2 X R1
*127x76x13
127.0,76.0,4.0,7.6,7.6
*152x89x16
152.4,88.7,4.5,7.7,7.6
*178x102x19
177.8,101.2,4.8,7.9,7.6
*203x102x23
203.2,101.8,5.4,9.3,7.6
*203x133x25
203.2,133.2,5.7,7.8,7.6
*203x133x30
206.8,133.9,6.4,9.6,7.6
*254x102x22
254.0,101.6,5.7,6.8,7.6
*254x102x25
257.2,101.9,6.0,8.4,7.6
*254x102.28
260.4,102.2,6.3,10.0,7.6
*254x146x31
251.4,146.1,6.0,8.6,7.6
*254x146x37
256.0,146.4,6.3,10.9,7.6
*254x146x43
259.6,147.3,7.2,12.7,7.6
*305x102x25
305.1,101.6,5.8,7.0,7.6
*305x102x28
308.7,101.8,6.0,8.8,7.6
*305x102x33
312.7,102.4,6.6,10.8,7.6
*305x127x37
304.4,123.4,7.1,10.7,8.9
*305x127x42
307.2,124.3,8.0,12.1,8.9
*305x127x48
311.0,125.3,9.0,14.0,8.9
*305x165x40
303.4,165.0,6.0,10.2,8.9
*305x165x46
306.6,165.7,6.7,11.8,8.9
*305x165x54
310.4,166.9,7.9,13.7,8.9
*356x127x33
349.0,125.4,6.0,8.5,10.2
*356x127x39
353.4,126.0,6.6,10.7,10.2
*356x171x45
351.4,171.1,7.0,9.7,10.2
*356x171x51
355.0,171.5,7.4,11.5,10.2
*356x171x57
358.0,172.2,8.1,13.0,10.2
*356x171x67
363.4,173.2,9.1,15.7,10.2
*406x140.39
398.0,141.8,6.4,8.6,10.2
*406x140x46
403.2,142.2,6.8,11.2,10.2
*406x178x54
402.6,177.7,7.7,10.9,10.2
*406x178x60
406.4,177.9,7.9,12.8,10.2
*406x178x67
409.4,178.8,8.8,14.3,10.2
*406x178x74
412.8,179.5,9.5,16.0,10.2
*457x152x52
449.8,152.4,7.6,10.9,10.2
*457x152x60
454.6,152.9,8.1,13.3,10.2
*457x152x67
458.0,153.8,9.0,15.0,10.2
*457x152x74
462.0,154.4,9.6,17.0,10.2
*457x152x82
465.8,155.3,10.5,18.9,10.2
*457x191x67
453.4,189.9,8.5,12.7,10.2
*457x191x74
457.0,190.4,9.0,14.5,10.2
*457x191x82
460.0,191.3,9.9,16.0,10.2
*457x191x89
463.4,191.9,10.5,17.7,10.2
*457x191x98
467.2,192.8,11.4,19.6,10.2
*533x210x82
528.3,208.8,9.6,13.2,12.7
*533x210x92
533.1,209.3,10.1,15.6,12.7
*533x210x101
536.7,210.0,10.8,17.4,12.7
*533x210x109
539.5,210.8,11.6,18.8,12.7
*533x210x122
544.5,211.9,12.7,21.3,12.7
*610x229x101
602.6,227.6,10.5,14.8,12.7
*610x229x113
607.6,228.2,11.1,17.3,12.7
*610x229x125
612.2,229.0,11.9,19.6,12.7
*610x229x140
617.2,230.2,13.1,22.1,12.7
*610x305x149
612.4,304.8,11.8,19.7,16.5
*610x305x179
620.2,307.1,14.1,23.6,16.5
*610x305x238
635.8,311.4,18.4,31.4,16.5
*686x254x125
677.9,253.0,11.7,16.2,15.2
*686x254x140
683.5,253.7,12.4,19.0,15.2
*686x254x152
687.5,254.5,13.2,21.0,15.2
*686x254x170
692.9,255.8,14.5,23.7,15.2
*762x267x134
750.0,264.4,12.0,15.5,16.5
*762x267x147
754.0,265.2,12.8,17.5,16.5
*762x267x173
762.2,266.7,14.3,21.6,16.5
*762x267x197
269.8,268.0,15.6,25.4,16.5
*838x292x176
834.9,291.7,14.0,18.8,17.8
*838x292x194
840.7,292.4,14.7,21.7,17.8
*838x292x226
850.9,293.8,16.1,26.8,17.8
*914x305x201
903.0,303.3,15.1,20.2,19.1
*914x305x224
910.4,304.1,15.9,23.9,19.1
*914x305x253
918.4,305.5,17.3,27.9,19.1
*914x305x289
926.6,307.7,19.5,32.0,19.1
*914x419x343
911.8,418.5,19.4,32.0,24.1
*914x419x388
921.0,420.5,21.4,36.6,24.1
*1016x305x222
970.3,300.0,16.0,21.1,30.0
*1016x305x249
980.2,300.0,16.5,26.0,30.0
*1016x305x272
990.1,300.0,16.5,31.0,30.0
*1016x305x314
1000.0,300.0,19.1,35.9,30.0
*1016x305x349
1008.1,302.0,21.1,40.0,30.0
*1016x305x393
1016.0,303.0,24.4,43.9,30.0
*1016x305x437
1025.9,305.4,26.9,49.0,30.0
*1016x305x487
1036.1,308.5,30.0,54.1,30.0
*100x55x8
100.0,55.0,4.1,5.7,7.0
*120x64x10
120.0,64.0,4.4,6.3,7.0
*140x73x13
140.0,73.0,4.7,6.9,7.0
*160x82x16
160.0,82.0,5.0,7.4,9.0
*180x91x19
180.0,91.0,5.3,8.0,9.0
*200x100x22
200.0,100.0,5.6,8.5,12.0
*203x133x25
203.2,133.4,5.8,7.8,7.6
*203x133x30
206.8,133.8,6.3,9.6,7.6
*254x146x31
251.5,146.1,6.1,8.6,7.6
*254x146x37
256.0,146.4,6.4,10.9,7.6
*254x146x43
259.6,147.3,7.3,12.7,7.6
*305x102x25
304.8,101.6,5.8,6.8,7.6
*305x102x29
308.9,101.9,6.1,8.9,7.6
*305x102x33
*305x165x41
303.8,165.1,6.1,10.2,8.9
*305x165x46
307.1,165.7,6.7,11.8,8.9
*305x165x54
310.9,166.8,7.7,13.7,8.9
*356x171x45
352.0,171.0,6.9,9.7,10.2
*356x171x51
355.6,171.5,7.3,11.5,10.2
*356x171x57
358.6,172.1,8.0,13.0,10.2
*356x171x67
364.0,173.2,9.1,15.7,10.2
*406x140x39
397.3,141.8,6.3,8.6,10.2
*406x140x46
402.3,142.4,6.9,11.2,10.2
*406x178x54
402.6,177.6,7.6,10.9,10.2
*406x178x60
406.4,177.8,7.8,12.8,10.2
*406x178x67
*406x178x75
412.8,179.7,9.7,16.0,10.2
*457x191x67
453.6,189.9,8.5,12.7,10.2
*457x191x75
457.2,190.5,9.1,14.5,10.2
*457x191x82
460.2,191.3,9.9,16.0,10.2
*457x191x90
463.6,192.0,10.6,17.7,10.2
*457x191x98
467.4,192.8,11.4,19.6,10.2
*533x210x82
528.3,208.7,9.6,13.2,12.7
*533x210x93
533.1,209.3,10.2,15.6,12.7
*533x210x101
536.7,210.1,10.9,17.4,12.7
*533x210x109
539.5,210.7,11.6,18.8,12.7
*533x210x122
544.6,211.9,12.8,21.3,12.7
*610x229x101
602.2,227.6,10.6,14.8,12.7
*610x229x113
607.3,228.2,11.2,17.3,12.7
*610x229x125
611.9,229.0,11.9,19.6,12.7
*610x229x140
617.0,230.1,13.1,22.1,12.7
*610x305x149
609.6,304.8,11.9,19.7,16.5
*610x305x179
617.5,307.0,14.1,23.6,16.5
*610x305x238
633.0,311.5,18.6,31.4,16.5
*686x254x125
*686x254x140
*686x254x152
687.6,254.5,13.2,21.0,15.2
*686x254x170
**UNIVERSAL COLUMNS DATA
*152x152x23
152.4,152.4,6.1,6.8,7.6
*152x152x30
157.5,152.9,6.6,9.4,7.6
*152x152x37
161.8,154.4,8.1,11.5,7.6
*203x203x46
203.2,203.2,7.3,11.0,10.2
*203x203x52
206.2,203.9,8.0,12.5,1O.2
*203x203x60
209.6,205.2,9.3,14.2,10.2
*203x203x71
215.9,206.2,10.3,17.3,10.2
*203x203x86
222.3,208.8,13.0,20.5,10.2
*254x254x73
254.0,254.0,8.6,14.2,12.7
*254x254x89
260.4,255.9,10.5,17.3,12.7
*254x254x107
266.7,258.3,13.0,20.5,12.7
*254x254x132
276.4,261.0,15.6,25.1,12.7
*254x254x167
289.1,264.5,19.2,31.7,12.7
*305x305x97
307.8,304.8,9.9,15.4,15.2
*305x305x118
314.5,306.8,11.9,18.7,15.2
*305x305x137
320.5,308.7,13.8,21.7,15.2
*305x305x158
327.2,310.6,15.7,25.0,15.2
*305x305x198
339.9,314.1,19.2,31.4,15.2
*305x305x240
352.6,317.9,23.0,37.7,15.2
*305x305x283
365.3,321.8,26.9,44.1,15.2
**ROLLED STEEL UNEQUAL ANGLES DATA
*65x50x6
65.0,50.0,6.0,6.0,3.0
*65x50x8
65.0,50.0,8.0,6.0,3.0
*75x50x6
75.0,50.0,6.0,7.0,3.5
*75x50x8
75.0,50.0,8.0,7.0,3.5
*80x60x6
80.0,60.0,6.0,8.0,4.0
*80x60x8
80.0,60.0,8.0,8.0,4.0
*90x65x6
90.0,65.0,6.0,8.0,4.0
*90x65x8
90.0,65.0,8.0,8.0,4.0
*90x65x10
90.0,65.0,10.0,8.0,4.0
*100x65x8
100.0,65.0,8.0,10.0,5.0
*100x65x10
100.0,65.0,10.0,10.0,5.0
*100x75x6
100.0,75.0,6.0,10.0,5.0
*100x75x8
100.0,75.0,8.0,10.0,5.0
*100x75x10
100.0,75.0,10.0,10.0,5.0
*100x75x12
100.0,75.0,12.0,10.0,5.0
*125x75x8
125.0,75.0,8.0,11.0,5.5
*125x75x10
125.0,75.0,10.0,11.0,5.5
*125x75x12
125.0,75.0,12.0,11.0,5.5
*150x75x10
150.0,75.0,10.0,11.0,5.5
*150x75x12
150.0,75.0,12.0,11.0,5.5
*150x75x15
150.0,75.0,15.0,11.0,5.5
*150x90x10
150.0,90.0,10.0,12.0,6.0
*150x90x12
150.0,90.0,12.0,12.0,6.0
*150x90x15
150.0,90.0,15.0,12.0,6.0
Hello again...
I suppose you want to know how to save and use the files now...
As I said - save the code from the first file as steels.lsp
Save the code from the second file as steels.dcl
Save the code from the third file as steels.dat
I use notepad to create the files so you don't get any stray unicode formating messing with the code. When you've got the 3 files created, place them all in the same directory (I use c:\lisps) and make sure that the directory is included in the search file path in Autocad. Type (load "steels.lsp") at the command prompt to load the routine and then type "steels" (without the inverted commas and the dialogue box will come up - the rest should be self explanatory.
Feel free to remove the references to Amec in the second file if you want - it's not copywrited.
Also the data in the third file is the info you'd get from the corus book - so if there are any updates, have a look at one the the existing sections and you should be able to figure out what order to put them in.
Depending on which version of autocad you're using I can show you how to create a line in the pulldown menus to add the command automatically
All the best
Spacepig
Hello again...
All the best
Spacepig
Superb Mate just what I needed. Thanks alot mate well appreciated.
  • 3 years later...
My first use of lisps and that's damn good mate! :)
Spacepig Thamks for this great lisp
I want to ask you for another lisp if you have.
Its about welding symbol.
Thanks again for sharing this lisp
