Adam Parker Posted February 24, 2014 Posted February 24, 2014 I have a block called "north"....I need to move the block in increments of 6" and render an image to create an animation. Can anyone help me out with the proper script to do this. thanks in advance. --AP Quote
MSasu Posted February 24, 2014 Posted February 24, 2014 Please take a look to this previous discussion. Quote
Adam Parker Posted February 24, 2014 Author Posted February 24, 2014 I looked at it.....I got the rendering part down but just don't understand what to put in my script for the relocation of my block. Quote
MSasu Posted February 24, 2014 Posted February 24, 2014 Is that block inserted only once in your drawing (unique instance)? Quote
Adam Parker Posted February 24, 2014 Author Posted February 24, 2014 yes. I need to move the dame block in small increments and render a .jpg after each movement. Quote
MSasu Posted February 24, 2014 Posted February 24, 2014 Then this statement may help you: (command "MOVE" (ssget "_X" '((0 . "INSERT") (2 . "NORTH"))) "" "" '(6 0 0)); Quote
Adam Parker Posted February 24, 2014 Author Posted February 24, 2014 I will try it.....I will let you know.... Thanks for your help Quote
Adam Parker Posted February 25, 2014 Author Posted February 25, 2014 It worked very well. Thank you for your help. You saved me a lot of work. --AP Quote
MSasu Posted February 25, 2014 Posted February 25, 2014 Sound good! You're entirely welcome, Adam! Quote
Adam Parker Posted March 30, 2014 Author Posted March 30, 2014 Mircea, You helped me out on script to move something...which was awesome! How about to rotate a block about a point? Thanks. --AP Quote
MSasu Posted March 31, 2014 Posted March 31, 2014 This statement will rotate the same block around origin with -15 degrees: (command "_ROTATE" (ssget "_X" '((0 . "INSERT") (2 . "NORTH"))) "" '(0 0 0) -15.0); For sure this line may be refined to other results, but will need to get before more details from you on what you intend to achive by said rotation. Quote
Adam Parker Posted April 14, 2014 Author Posted April 14, 2014 Thanks again for your help. You are very knowledgeable. I am going to take a shot in the dark here........We are looking to build some 3d models in cad and are wanting to manipulate the models with menu functions (.cuix or .mnu files). I am assuming we will need to build/load a .vlx or something to define the model. However, I am not quite sure how to make this happen or put it together. Is this something you might be interested in? Are you available for hire for something like this? Thanks, --Adam Quote
Adam Parker Posted April 14, 2014 Author Posted April 14, 2014 Me again..... I am now trying to rotate and object 10 degrees around a point. I called out the coordinates of the rotation point but get the command back "Specify base point:" any ideas? Here is my script; (command "_ROTATE" (ssget "_X" '((0 . "INSERT") (2 . "rotor"))) "" '(964'-10.46592178" -1406'-6.23244661" 271'-0.02875073") -10.0); Quote
MSasu Posted April 15, 2014 Posted April 15, 2014 Since your input is Imperial, please pay attention that in order to specify a point as an AutoLISP list you should use decimal values: (command "_ROTATE" (ssget "_X" '((0 . "INSERT") (2 . "rotor"))) "" [color=red]'(11578.46592178 -16878.23244661 3252.02875073)[/color] -10.0); An alternative will be to input said point as a sting, similar with what you do on prompter: (command "_ROTATE" (ssget "_X" '((0 . "INSERT") (2 . "rotor"))) "" [color=red]"964'-10.46592178,-1406'-6.23244661,271'-0.02875073"[/color] -10.0); For the future, please use tags to post code excerpts. Quote
