Sbeth85 Posted March 10, 2014 Share Posted March 10, 2014 When you select multiple objects you can go through the groupings by object type, one-by-one, via Quick Properties. My issue is that let's say I want to see all the Lines, only, or all the Plines... Is there a way to do an Object Laywalk the same way there is to do a Layer laywalk? Also, is there a way to Quick Select all the lines in X area without having to go through the whole weird Quick Select picking process? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted March 10, 2014 Share Posted March 10, 2014 Also, is there a way to Quick Select all the lines in X area without having to go through the whole weird Quick Select picking process?An alternative selection method would be to try the FILTER command. The main benefit, is that you can save your selection criteria for later use. Since it saves to a *.LOG text file, it can be migrated to future versions of AutoCAD so you don't lose the saved selection criteria's you've built up in time. Quote Link to comment Share on other sites More sharing options...
Sbeth85 Posted March 10, 2014 Author Share Posted March 10, 2014 And an addendum, wouldn't it be cool if QuickSelect worked THROUGH the Quick Prop dropdown menu? So often I wish that when I pick "Dimensions" on the Drop Down it'll select them and de-select everything else! Quote Link to comment Share on other sites More sharing options...
Sbeth85 Posted March 10, 2014 Author Share Posted March 10, 2014 tzframpton- dang, filter looks intense. I'ma gonna have to lookup a tutorial on it. Could you tell me an example of what kinda filters you use? The only one I can think of is for Dims. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 10, 2014 Share Posted March 10, 2014 I use it all the time to change text styles. choose text then style name. Quote Link to comment Share on other sites More sharing options...
