Romans text
akarees8080
I am currently using romans text style and when I PDF a drawing the text is quite unclear until I zoom into the pdf. It seems that half the letters are a lot less visible then appear when zoomed in.
Cheers,
Andrew
AutoCAD 2014
LT
First thing that comes to mind is Mtext (as opposed to Single Line Text) can sometimes have a weird effect on SHX fonts, such as RomanS. Also, SHX fonts are effected by the CTB plot style, so double check those settings (Line End Style, Line Join Style, Lineweight thickness, etc).
Have you considered going to a TTF instead, such as Arial? There are many benefits in my opinion in doing so. One thing is if you use a TTF, then your PDFs can now be searchable, along with having a much cleaner, more updated feel to the typography of your outputs.
-Tannar
