MJLM Posted March 18, 2014 Posted March 18, 2014 I am trying to select all lines that have a handle greater than given. I type (setq hdl (getstring "\nEnter handle: ")) (setq lngrss (ssget "X" (list (cons 0 "LINE") (cons -4 ">") (cons 5 hdl))) However this returns nil. How could I do this? Quote
Bhull1985 Posted March 18, 2014 Posted March 18, 2014 What do you mean by "handle" Usually people filter by layer, lineweight, linetype.... Quote
Tharwat Posted March 18, 2014 Posted March 18, 2014 What do you mean by "handle"Usually people filter by layer, lineweight, linetype.... Handle is a unique number or a mixed value of chars and numbers in a string type that can not be duplicated with any other object in the same drawing . Quote
MJLM Posted March 18, 2014 Author Posted March 18, 2014 As Tharwat said this is a unique identifier of any entity in the drawing. It is stored always with flag "5" in hexadecimal format. I cant filter according to line type, color or layer as my lines share the same properties. Quote
Tharwat Posted March 18, 2014 Posted March 18, 2014 So it's like the ename? You can say that . Handle somehow it means the ear to users to catch with . Quote
MSasu Posted March 18, 2014 Posted March 18, 2014 MJLM, the handle is a string representing a hexadecimal number, so I'm not sure if you can reliable define a filter to sort all entities that have thier handle smaller than a certain value. To parse entities by their creation order I suggest to rather check the ENTNEXT function. Quote
MSasu Posted March 18, 2014 Posted March 18, 2014 So it's like the ename? The difference between handle and entity name is that first is invariable, while the second will be different in each session for same entity. However, both were unique in one drawing. Quote
Tharwat Posted March 19, 2014 Posted March 19, 2014 Try this code to highlight a line if it match its handle of course . You need to regen to unhighlight the entity back if any line entity highlighted . (if (and (/= "" (setq hdl (getstring "\nEnter handle: "))) (setq go t s (ssget "_X" '((0 . "LINE")))) ) ((lambda (i /) (while (and go (setq n (ssname s (setq i (1+ i))))) (if (vl-some '(lambda (u) (and (eq (car u) 5) (eq (cdr u) (strcase hdl)))) (entget n)) (progn (redraw n 3) (setq go nil)) ) ) ) -1 ) ) Quote
Bhull1985 Posted March 19, 2014 Posted March 19, 2014 The difference between handle and entity name is that first is invariable, while the second will be different in each session for same entity. However, both were unique in one drawing. Thanks for clearing this up guys Quote
David Bethel Posted March 19, 2014 Posted March 19, 2014 From the Swamp http://www.theswamp.org/index.php?action=post;quote=98894;topic=7796.0;last_msg=98928 author=Jürg Menzi In addition to the other answers... From help: The ssget function recognizes all group codes except entity names (group –1), handles (group 5), and xdata codes (groups greater than 1000). I think that this still holds true. -David Quote
MJLM Posted March 19, 2014 Author Posted March 19, 2014 I think that this still holds true. -David Apparently and unfortunately yes. Quote
Tharwat Posted March 19, 2014 Posted March 19, 2014 MJLM , did you see my post No 9 ? was it helpful at any ? Quote
MJLM Posted March 19, 2014 Author Posted March 19, 2014 MJLM , did you see my post No 9 ? was it helpful at any ? Yes, thank you but this doesnt quite work for me cause I already pick the entity myself. I want to see all other lines created after the one I pick. I managed to solve that, maybe not fully but it s on the right direction, by colorizing all lines in the drawing from color A to color B. So cold colors are past and warm colors are present. It kinda help me do what I want. Quote
MSasu Posted March 19, 2014 Posted March 19, 2014 I want to see all other lines created after the one I pick. May achieve that by parsing drawing's database using ENTNEXT and the entity name of picked line as starting argument. Quote
Tharwat Posted March 19, 2014 Posted March 19, 2014 Yes, thank you but this doesnt quite work for me cause I already pick the entity myself. I want to see all other lines created after the one I pick. I managed to solve that, maybe not fully but it s on the right direction, by colorizing all lines in the drawing from color A to color B. So cold colors are past and warm colors are present. It kinda help me do what I want. I see you have changed your mind cause what you have just said is different than the first post . Quote
MSasu Posted March 19, 2014 Posted March 19, 2014 Not necesarily, Tharwat. Seems that OP was hopping to get all entities added after a particular one based on the assumption that their handles will always be given in an ascending order. Quote
Tharwat Posted March 19, 2014 Posted March 19, 2014 Not necesarily, Tharwat. How is that not necessarily ? I did give an example of codes that related to their first post and now it looks wrong because they changed their mind and searching for something else. Quote
marko_ribar Posted March 19, 2014 Posted March 19, 2014 (edited) I think that it's bad idea to colorize entities... Please, test this code, I think it's better approach to select entities... (defun c:selpents ( / _entnext ss e ent ) (defun _entnext ( en / ee ) (setq ee en) (while (wcmatch (cdr (assoc 0 (entget (setq ee (entnext ee))))) "ATTRIB,VERTEX,SEQEND")) ee ) (setq ss (ssadd)) (setq e (entnext)) (setq ent (car (entsel "\nPick entity for selecting entities created before picked entity"))) (while (not (equal e ent)) (ssadd e ss) (setq e (_entnext e)) ) (sssetfirst nil ss) (princ) ) Edited March 19, 2014 by marko_ribar Quote
MJLM Posted March 19, 2014 Author Posted March 19, 2014 I see you have changed your mind cause what you have just said is different than the first post . Yes, that was a work around I thought and it works. It is not the best solution Quote
