Hi,
I have some code, probably written by someone on this site, that I want to modify slightly. However I have run into trouble. The command runs fine but just bombs out after the pline command and doesn't reset the system variables. Here is the code:
; Start-Up Function
(defun C:ESS (/ SUCE SUOM SUSM SUAB SUAD SUCL SUCR)
 (setq SUCE (getvar "cmdecho"))
 (setq SUOM (getvar "orthomode"))
 (setq SUSM (getvar "osmode"))
 (setq SUAB (getvar "angbase"))
 (setq SUAD (getvar "angdir"))
 (setq SUCL (getvar "clayer"))
 (setq SUCR (getvar "cecolor"))
(ESS_MF)
; Main Function
(defun ESS_MF (/ SIZE$ SIZE MIDPT PLEN PT01  PT02 a b COLR SUCE SUOM SUSM SUAB SUAD SUCL SUCR)
 (setq temperr *error*)
 (setq *error* ESS_ETRAP)
(entmake
 (list
   (cons 0 "STYLE")
   (cons 100 "AcDbSymbolTableRecord")
   (cons 100 "AcDbTextStyleTableRecord")
   (cons 2 "CCC_Services")
   (cons 3 "Verdana.ttf")
   (cons 40 0)
   (cons 70 0)
 (setq S1_list '( "1500mm"  "1350mm" "1200mm" "1050mm" "900mm" "750mm" "675mm" "600mm" "525mm" "450mm" "375mm" "300mm" "225mm" "150mm"))
 (setq dcl_id (load_dialog "ESS.dcl"))
 (if
   (not
     (new_dialog "ESS" dcl_id)
     (ALERT "Can not find your dcl file")
     (exit)
 (start_list "S1")
 (mapcar 'add_list S1_list)
 (end_list)
 (if SIZE:DEF
   (set_tile "S1" (itoa SIZE:DEF))
 (action_tile "cancel"
  "(done_dialog)(setq userclick nil)"
 (action_tile "accept"
   (strcat
    "(progn
     (setq S:IZE (atoi (get_tile \"S1\")) SIZE:DEF S:IZE)"
    "(done_dialog)(setq userclick T))"
 (start_dialog)
 (unload_dialog dcl_id)
 (if userclick
   (ESS_VARIABLE)
; ESS_VARIABLE Function
(defun ESS_VARIABLE ()
   (setq SIZE$ (fix S:IZE))
   (setq SIZE$ (nth S:IZE S1_list))
   (cond
     ((= SIZE$ "1500mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E1500")(setq LTYP "E1500"))
     ((= SIZE$ "1350mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E1350")(setq LTYP "E1500"))
     ((= SIZE$ "1200mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E1200")(setq LTYP "E1500"))
     ((= SIZE$ "1050mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E1050")(setq LTYP "E1500"))
     ((= SIZE$ "900mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E900")(setq LTYP "E1500"))
     ((= SIZE$ "750mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E750")(setq LTYP "E1500"))
     ((= SIZE$ "675mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E675")(setq LTYP "E1500"))
     ((= SIZE$ "600mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E600")(setq LTYP "E1500"))
     ((= SIZE$ "525mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E525")(setq LTYP "E1500"))
     ((= SIZE$ "450mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E450")(setq LTYP "E1500"))
     ((= SIZE$ "375mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E375")(setq LTYP "E1500"))
     ((= SIZE$ "300mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E300")(setq LTYP "E1500"))
     ((= SIZE$ "225mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E225")(setq LTYP "E1500"))
     ((= SIZE$ "150mm")(setq SIZE$ "Existing_Drainage_Storm_Sewer_Concrete_E150")(setq LTYP "E1500"))
 (setq SIZE SIZE$)
 (ESS_OUTPUT)
; ESS_OUTPUT Function
(defun ESS_OUTPUT ()
 (setq a (strcat "CCC_DR_"LTYP)
       b (strcat "CCC_SERVICES_"SIZE)
 (if
   (not
     (tblsearch "LTYPE" a)
   (command "_.-linetype" "_l" a "CCC_Drainage_Existing Storm.lin" "")
 (command "_.-layer" "_N" b "_M" b "_L" a b "_C" "84" b "_LW" "0.3" b "" )
 (command "_-color"  "bylayer")
 (command "._-linetype"  "s"  "bylayer" "")
 (setvar "angbase" 0.0000)
 (setvar "cmdecho" 1)
 (setvar "angdir"  0)
 (setvar "clayer" b)
 (setvar "orthomode" 0)
 (setvar "osmode"    16383)
 (command "_.-layer" "_S" b "")
 ;(setvar "plinegen" 1)
 (command "._pline")
 (setq *error* temperr)
 (setvar "cmdecho" SUCE)
 (setvar "orthomode" SUOM)
 (setvar "osmode" SUSM)
 (setvar "angbase" SUAB)
 (setvar "angdir" SUAD)
 (setvar "clayer" SUCL)
 (setvar "cecolor" SUCR)
; Error Trap Function
(defun ESS_ETRAP (errmsg)
 (command nil nil nil)
 (if
   (not
     (member errmsg '("console break" "Function Cancelled"))
   (princ (strcat "\nError:" errmsg))
 (princ "\nError, Restoring ESS_VARIABLEs.")
 (terpri)
Here is the dump at the end command with the error:
Current layer:  "CCC_SERVICES_Existing_Drainage_Storm_Sewer_Concrete_E1500"
Enter an option
[?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Fre
eze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: _S
Enter layer name to make current or <select object>:
CCC_SERVICES_Existing_Drainage_Storm_Sewer_Concrete_E1500 Enter an option
Command: ._pline
Specify start point:[color="red"] AutoCAD variable setting rejected: "cmdecho" nil[/color]
Current line-width is 0.000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
I would appreciate it if someone could help with solving the error.
Thanks.
There were some variables that were localized twice, so the failure of atempt to restore the environment:
(defun ESS_MF (/ SIZE$ SIZE MIDPT PLEN PT01  PT02 a b COLR [color=red][s]SUCE SUOM SUSM SUAB SUAD SUCL SUCR[/s][/color])
What are you looking to achieve with this code? To allow user to interactivelly draw a polyline?
(command "._pline")
Yes. To have the user draw a polyline and reset the system variables on completion. This is a slightly different version of the code but it bombs out after the pline command and doesn't reset the system variables. Can anyone help with this?
; Start-Up Function
(defun C:PRWMDIA (/ HOLE$ SIZE$ HOLE SIZE PT01 PT02 a b lw DEGREES RADIANS)
 (PRWMDIA_SAVE)
 (princ))
; Save User Settings Function.
(defun PRWMDIA_SAVE (/ SUS SUCE SUOM SUSM SUAB SUAD SUCL SUCR)
 (setq SUS_LIST (list "cmdecho" "orthomode" "osmode" "blipmode" "clayer" "angbase" "angdir" "cecolor"))
 (setq TERR$ *error*)
 (setq *error* PRWMDIA_ETRAP)
 (PRWMDIA_MF)
 (princ))
; Main Function
(defun PRWMDIA_MF ()
 (setq T1_list '("Type A" "Type B"))
 (setq S1_list '("300mm" "250mm" "200mm" "150mm" "100mm"))
 (setq dcl_id (load_dialog "PRWMDIA.dcl"))
 (if (not (new_dialog "PRWMDIA" dcl_id))
   (progn (ALERT "Can not find your dcl file")
     (exit)))
 (start_list "T1")
 (mapcar 'add_list T1_list)
 (end_list)
 (start_list "S1")
 (end_list)
 (if HOLE:DEF (set_tile "T1" (itoa HOLE:DEF)))
 (if SIZE:DEF (set_tile "S1" (itoa SIZE:DEF)))
 (action_tile "cancel" "(done_dialog)(setq userclick nil)")
   (strcat
    "(progn
     (setq H:OLE (atoi (get_tile \"T1\")) HOLE:DEF H:OLE)"
    "(setq S:IZE (atoi (get_tile \"S1\")) SIZE:DEF S:IZE)"
    "(done_dialog)(setq userclick T))"))
 (start_dialog)
 (if userclick
   (PRWMDIA_VARIABLE))
 (princ))
; PRWMDIA_VARIABLE Function
(defun PRWMDIA_VARIABLE ()
   (setq HOLE$ (fix H:OLE))
   (setq HOLE$ (nth H:OLE T1_list))
   (cond
     ((= HOLE$ "Type A"))
     ((= HOLE$ "Type B"))))
 (setq HOLE HOLE$)
   (cond
     ((= SIZE$  "300mm")(setq SIZE$  "300D"))
     ((= SIZE$  "250mm")(setq SIZE$  "250D"))
     ((= SIZE$  "200mm")(setq SIZE$  "200D"))
     ((= SIZE$  "150mm")(setq SIZE$  "150D"))
     ((= SIZE$  "100mm")(setq SIZE$  "100D"))))
 (setq SIZE SIZE$)
 (PRWMDIA_OUTPUT)
 (princ))
; PRWMDIA_OUTPUT Function
(defun PRWMDIA_OUTPUT ()
 (if (null (tblsearch "STYLE" "CCC_Services"))
   (entmake
     (list
       (cons 0 "STYLE")
       (cons 40 0)
       (cons 70 0))))
 (setq a  (strcat "CCC_WM_"SIZE"_"HOLE)
       b  (strcat "CCC_SERVICES_PROPOSED_Watermain_Ductile_Iron_"SIZE"_"HOLE)
       lw 30)
 (if (null (tblsearch "LTYPE" a))
   (command "_.-linetype" "_l" a "CCC_Watermain_DI.lin" ""))
 (if (null (tblsearch "LAYER" b))
 (command "_.-layer" "_N" b "_M" b "_L" a b "_C" "30" b "_LW" "0.3" b "" ))
 (setvar "cmdecho" 0)
 (setvar "angdir"  0)
 (command "._pline")
 (PRWMDIA_RESTORE)
 (princ))
; Degrees to Radians Function
(defun PRWMDIA_DTR (DEGREES)
(* pi (/ DEGREES 180.0)))
; Radians to Degrees Function
(defun PRWMDIA_RTD (RADIANS)
 (* 180.0 (/ RADIANS pi)))
; Restore User Settings Function.
(defun PRWMDIA_RESTORE ()
 (setq *error* TERR$)
 (if SUS (mapcar 'setvar SUS_LIST SUS))
 (princ "\nProgram completed and will now restore the user settings and exit.")
 (princ))
; Error Trap Function.
(defun PRWMDIA_ETRAP (ERRORMSG)
 (if (not (member ERRORMSG '("console break" "Function cancelled")))
   (princ (strcat "\nError:" ERRORMSG)))
 (princ "\nAn *error* has occured!")
 (princ "\nThe program will now restore the user settings and exit.")
 (terpri)
 (princ))
Edited by woodman78
Mispelling
woodman78,
Those condition statements are nuts, each one (1st example & 2nd example) only take 1-single line of code.
(setq SIZE$ (strcat "Existing_Drainage_Storm_Sewer_Concrete_E" (itoa(atoi SIZE$)))
     LTYP "E1500")
(setq  SIZE$ (strcat (itoa(atoi SIZE$)) "D"))
Bruce
It does not appear that you defined the system variable values in the SUS variable list prior to running the functions, so there is no original system settings saved any where. You defined the list of system settings "SUS_LIST" to change but not their original values. You should define the SUS variable at the same time you define the list of system settings.
Thanks Snownut. How do I define the SUS variable.
Replace the existing function with the current one.
I have not tested anything, just saw this error.
(defun PRWMDIA_SAVE (/  SUCE SUOM SUSM SUAB SUAD SUCL SUCR)
   (setq SUS_list '(cmdecho orthomode osmode blipmode clayer angbase angdir cecolor)
         SUS       (mapcar 'getvar SUS_list)
         TERR$ *error*
     (PRWMDIA_MF)
Then to reset the system variables you need to use this.
   (mapcar 'setvar SUS_list SUS)
Thanks Snownut,
I made those changes but the system variables still aren't resetting:
; Start-Up Function
 (PRWMDIA_SAVE)
 (princ))
 ;(setq SUS_LIST (list "cmdecho" "orthomode" "osmode" "blipmode" "clayer" "angbase" "angdir" "cecolor"))
 ;(setq TERR$ *error*)
 ;(setq *error* PRWMDIA_ETRAP)
[color="red"]    (setq SUS_list '(cmdecho orthomode osmode blipmode clayer angbase angdir cecolor))
         TERR$ *error*
         *error* PRWMDIA_ETRAP[/color]
 (PRWMDIA_MF)
 (princ))
; Main Function
     (exit)))
 (start_list "T1")
 (end_list)
 (start_list "S1")
 (end_list)
   (strcat
    "(progn
 (start_dialog)
 (if userclick
   (PRWMDIA_VARIABLE))
 (princ))
   (cond
 (setq HOLE HOLE$)
   (cond
 (setq SIZE SIZE$)
 (PRWMDIA_OUTPUT)
 (princ))
   (entmake
     (list
       (cons 0 "STYLE")
       (cons 40 0)
       (cons 70 0))))
       lw 30)
 (setvar "angdir"  0)
 (command "._pline")
 (PRWMDIA_RESTORE)
 (princ))
[color="red"]  (mapcar 'setvar SUS_LIST SUS)[/color]
 (princ))
 (terpri)
 (princ))
I have looked at the command line dump after running the command and it looks as if the program is completing before the pline command is run.
Enter name list of layers(s) for lineweight 0.30mm
<CCC_SERVICES_PROPOSED_Watermain_Ductile_Iron_300D_Type A>:
CCC_SERVICES_PROPOSED_Watermain_Ductile_Iron_300D_Type A Enter an option
Command: _-color
Enter default object color [Truecolor/COlorbook] <BYLAYER>: bylayer
Command: ._-linetype
Current line type:  "ByLayer"
Enter an option [?/Create/Load/Set]: s
Specify linetype name or [?] <ByLayer>: bylayer
Command:
Would appreciate your help again. Thanks.
I would appreciate it if anyone could help me with this!
woodman78,
you have the closing parenthesis in the wrong place.
TERR$ *error*
Should be;
TERR$ *error*
Thanks Snownut. I changed that but it still behaves in the same way.
  • 2 weeks later...
