Hi all,
Sorry, my English so so so bad
I have a centerline of road in the drawing. I want to create two polyline on left side and right side of that centerline from file .txt
File structure:
1st column: Station of centerline
2nd column: Perpendicular distance from the LEFT edge road to centerline at Station point
3rd column: Perpendicular distance from the RIGHT edge road to centerline at Station point
we select a polyline of centerline in the drawing, select a starting point, then select file .txt.
example please download the attach file.
Please help me!
Test.txt
example1.dwg
Hello .
Try this routine and let me know how would you get on with it .
(defun c:Test (/ _ps _lw f o st l p s st nd pt ang e lst len)
 ;;    Author : Tharwat 30. Mar. 2014        ;;
 (if (and (setq f (getfiled "Select txt file :" "" "txt" 16))
          (setq o (open f "r"))
          (setq p (getpoint "\n Specify point at start point of Polyline :"))
          (setq s (ssget p '((0 . "LWPOLYLINE"))))
     (defun _ps (st / p v)
       (while (setq p (vl-string-position 9 st))
         (setq v  (cons (substr st 1 p) v)
               st (substr st (+ 2 p) (strlen st))
       (if st
         (setq v (cons st v))
       (reverse v)
     (while (setq st (read-line o)) (setq l (cons (_ps st) l)))
     (setq l (reverse l))
     (close o)
     (if (< (distance p (setq st (vlax-curve-getstartpoint (setq e (ssname s 0)))))
            (distance p (setq nd (vlax-curve-getendpoint e)))
         (setq p st)
         (foreach d l
           (if (setq ang (angle '(0.0 0.0 0.0)
                                (vlax-curve-getfirstderiv
                                  e
                                  (vlax-curve-getparamatpoint e (setq pt (vlax-curve-getpointatdist e (atof (car d)))))
             (setq lst
                    (cons
                      (list (polar pt (+ (/ pi 2.) ang) (atof (cadr d))) (polar pt (- ang (/ pi 2.)) (atof (caddr d))))
                      lst
       (progn (setq len (vlax-curve-getdistatpoint e nd))
              (foreach d l
                (if (setq
                      ang (angle
                            '(0.0 0.0 0.0)
                              e
                              (vlax-curve-getparamatpoint e (setq pt (vlax-curve-getpointatdist e (- len (atof (car d))))))
                  (setq lst
                         (cons
                           lst
     (if (and lst (> (length lst) 1))
       (progn (defun _lw (pts)
                (entmakex (append (list '(0 . "LWPOLYLINE")
                                        '(100 . "AcDbEntity")
                                        '(100 . "AcDbPolyline")
                                        (cons 90 (length lst))
                                        '(70 . 0)
                                  (mapcar '(lambda (x) (cons 10 x)) pts)
              (mapcar '_lw (list (mapcar 'car lst) (mapcar 'cadr lst)))
   (princ "\n Invalid file or Picked isn't on Polyline !!")
)(vl-load-com)
Hi Tharwat, thank you very much for helping me. This routine worked!
But what happens when two (or >2) polylines have a common starting point if not selected a polyline in the drawing?
Nice job Tharwat. Can I ask you a question.
a)What happend if we have a file like this
b)If i want to select a specific point of road centerline with specific Station what happend ?
0,3.5,3.6
20,3.4,3.6
45,3.6,3.5
70,3.5,3.4
100,3.4,3.6
Thanks
0,3.5,3.6
20,3.4,3.6
45,3.6,3.5
70,3.5,3.4
100,3.4,3.6
Thanks
Try to replace this in the routine and let me know .
Replace this .
With this .
(while (setq p (vl-string-position 44 st))
Only one would be considered .
Ok i change it.
If i want to select a specific point of road centerline with specific Station what happend ? I want to give any time the beginning Station not to be all the times 0 ,and is not nessesary all the times to be the start or the end of the polyline ,must be any point of a polyline.
Example
I have a road from 4+500 to 8+400 and i want to offset lines from 4+500 to 6+200 .First i pick the point to 4+500 , i give the beginning Station 4+500 and then i load the file from 4+500 --> 6+200
Look the attach file
       (if st
       (reverse v)
     (close o)
         (setq p st)
         (foreach d l
                                  e
             (setq lst
                    (cons
                      lst
              (foreach d l
                (if (setq
                      ang (angle
                            '(0.0 0.0 0.0)
                              e
                  (setq lst
                         (cons
                           lst
                                        '(70 . 0)
)(vl-load-com)
EXAMPLE.dwg
Edited by prodromosm
