ahank Posted April 1, 2014 Posted April 1, 2014 I've tried several lisp routines to help count blocks that are color coded and also have a given attribute; but all the routines require me to select each block. Is there a lisp routine that will count all blocks/ attributes within model space (only) and export to a table (or even better an Excel sheet)? I want to include in the lisp routine what blocks to look for... I'm a novice looking for a lot of help and would be greatly appreciated!!! Quote
BIGAL Posted April 2, 2014 Posted April 2, 2014 You hinted you looked at various lisps but using a filter will do what you want when selecting blocks looking at this snippet of code it has its filter set to a block of a certain name and must be in Modelspace. Once you have the selection set you can delve deeper and check the attribute value and count up. (defun getblk (bname / ss1) (setq ss1 (ssget "x" (list (cons 0 "INSERT") (cons 2 bname)(cons 410 "Modelspace")))) (princ (sslength ss1)) ; total number of blocks with that name found (do something here total up attributes) ) ;This will get all blocks called Fred (getblk "Fred") ; multiple runs (getblk "Fred") (getblk "Part56") (getblk "Obj32") Quote
