road runner Posted April 6, 2014 Share Posted April 6, 2014 Can some one please tell me how to find the Advance Start-up Wizard:oops:? Coming from autocad 2012 to 2014 I'm finding that the start-up Wizard is no were to be found. I've looked on the Net and all I can find is about Start-up Variable and Filedia. My Stard-up Variabe is set to 0 and my Filedia is set to 1. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
ROBP Posted April 6, 2014 Share Posted April 6, 2014 What exactly do you mean by start-up wizzard? I have the same set-up and filedia values and cad start when i click the exe shortcut from desktop r Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 6, 2014 Share Posted April 6, 2014 At the command line type STARTUP then hit Enter. Set the value to "1" then hit Enter. That should do it. BTW...the correct name is the Startup Wizard. Quote Link to comment Share on other sites More sharing options...
ROBP Posted April 6, 2014 Share Posted April 6, 2014 At the command line type STARTUP then hit Enter. Set the value to "1" then hit Enter. That should do it. BTW...the correct name is the Startup Wizard. I never use starup set to 1 here anyway i open file from main menu I hit new when a new drawing is needed and always start with a template that was already preset in the option file tab with the exact template drawings location Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 6, 2014 Share Posted April 6, 2014 As most users do but this particular user doesn't want to do that. Quote Link to comment Share on other sites More sharing options...
ROBP Posted April 6, 2014 Share Posted April 6, 2014 At the command line type STARTUP then hit Enter. Set the value to "1" then hit Enter. That should do it. BTW...the correct name is the Startup Wizard. One should make this as a poll to see how many users uses templates and who does'nt and who uses the wizzard Results would be interresting to see Quote Link to comment Share on other sites More sharing options...
road runner Posted April 6, 2014 Author Share Posted April 6, 2014 Thanks mark, you always deliver. Spot on. Quote Link to comment Share on other sites More sharing options...
