bienda Posted April 7, 2014 Share Posted April 7, 2014 Please help me as title See the attached Drawing Drawing.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 8, 2014 Share Posted April 8, 2014 A quick answer is to use Array and just make the circles, possibly combined with a lisp pick a few pts and done. One question the upright has the circles not quite the same as the horizontal section should they be more equal on the horizontal section ? this may require a section by section task ? Are these concrete reo bars ? Thought of a quick possible answer for a pline just offset add circle at each vertice, then divide the pline segments and place circle need some form of rule here max spacing. Your dwg 200 c-c but vert bit is 100 & 120 Already got conflicting answers as per screen grab need a set of rules supports my section by section approach Quote Link to comment Share on other sites More sharing options...
bienda Posted April 21, 2014 Author Share Posted April 21, 2014 Thank for help BIGAL Quote Link to comment Share on other sites More sharing options...
bienda Posted April 21, 2014 Author Share Posted April 21, 2014 I find the Topic http://www.cadtutor.net/forum/showthread.php?69319-a-series-of-polyline-in-between-two-bounding-polyline I want to replace coordinate of end line by Circle with manual Diameter. Please help me Thanks in advance Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 21, 2014 Share Posted April 21, 2014 2nd look at problem different approach pick two diagonal corners use rectang and work out the new offset pline explode use divide to create circle points & end points, this will take into account different shapes and islands. Just need some time. Quote Link to comment Share on other sites More sharing options...
bienda Posted April 24, 2014 Author Share Posted April 24, 2014 I need a lisp like Topic: http://www.cadtutor.net/forum/showthread.php?69319-a-series-of-polyline-in-between-two-bounding-polyline Quote Link to comment Share on other sites More sharing options...
bienda Posted April 24, 2014 Author Share Posted April 24, 2014 Please help me! Thank you in advance Quote Link to comment Share on other sites More sharing options...
