Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2014
    Apr 2014
    7
    Default How to extract integers from Getpoint?
    Say this is my code:
    Code:
    (defun c:test()
      (setq list(getpoint "\nChoose point here")
    When you click on your autocad drawing i know that it stores the coordinates in a x,y,z format in a list.. How can i extract those numbers?
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,249
    Firstly be careful to use a function as a variable which would popup a warning message then a conflict may take a place .
    Code:
    (setq p (getpoint "\n Specify point :"))
    (setq x (car p)
            y (cadr p)
            z (caddr p)
  1. store getint() integers to a list
    By samifox in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th May 2013, 02:36 pm
  2. Help!! Decimal place values of Integers in a Lisp, importing values from excel
    By loveboatcaptain in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Feb 2012, 11:33 pm
  3. Finding Integers
    By b_clive in forum AutoCAD General
    Last Post: 9th Dec 2010, 10:46 am
  4. Convert integers numbers into real numbers, introducing decimal separator.
    By teknomatika in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Sep 2010, 04:07 pm
  5. GetPoint
    By jandres in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Oct 2005, 02:38 pm
Tags for this Thread
