Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2014
    Apr 2014
    1
    Default How to display existing and new items in a Base view
    I work in the Structural design field and have used Autocad and Revit for years. Upon finding the "Create View" in the 2014 Ribbon, I am trying to find a way to differentiate existing structural steel 3d blocks from new blocks. I have used a generic 4 column and a floor steel box as a test. I can get all the selected elements to display but I would like to some existing members half toned. If anyone has information on how to display objects differently, I would greatly appreciate it.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    If the color of entities forming your blocks was set as ByBlock, then sort them in layers (i.e. Existing and New); after just play with the color of these layers.
    Also, welcome to the Forum, EagleCat!
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,596
    You won't have that type of control with the view base command.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  1. base view problem
    By Steve_B in forum AutoCAD Drawing Management & Output
    Last Post: 31st Jul 2013, 09:08 am
  2. Base View Problem
    By mukneel in forum AutoCAD Beginners' Area
    Last Post: 26th Jun 2013, 02:22 am
  3. Views won't display/Items won't display
    By glubad55 in forum AutoCAD General
    Last Post: 7th May 2012, 08:22 pm
  4. Add view scale to Base Model View label?
    By Hickoz_bro in forum SolidWorks
    Last Post: 16th May 2011, 09:23 am
  5. add items or layers to existing block
    By the ber in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Mar 2008, 11:47 am
