Hi everyone! Could somebody modify this lisp for me so I could repeat the command multiple times? This code is not mine and I don't know the author.
I have base knowledge about lisp and I've tried something to make it work using MULTIPLE command or WHILE function - but I'm not good at coding (when I try to run MULTIPLE command from lisp - it does not recognize my lisp command "BA" - I don't know why, and I have no idea how to set this code up with WHILE function)
Thanks.
;The AutoCAD built-in Break at Point does not work well because of AutoSnap. AutoSnap has to be temporarily turned off (important!!). I've written the following Lisp which allows user to select and object, and followed by picking a break point, command will be sent out with AutoSnap turned off temporarily.
(defun c:ba (/ obj pt1 osmode cmdecho)
 (setq obj (car (entsel)))
 (setq pt1 (getpoint "\nSpecify break point: "))
 (setq osmode (getvar "osmode"))
 (setq cmdecho (getvar "cmdecho"))
 (setvar "osmode" 0)
 (setvar "cmdecho" 0)
 (command "break" obj pt1 pt1)
 (setvar "osmode" osmode)
 (setvar "cmdecho" cmdecho)
Edited by SLW210
  (setvar "osmode" 512) ; nearest
  (while (setq pt1 (getpoint "\nSpecify break point: "))
    (command "break" pt1 pt1 pt1)
Set your osmode to 512 which is nearest.
Your point can be used to select the entity.
ymg
A quick-and-dirty adjustment:
(defun c:ba(/ obj pt1 osmode cmdecho)
(while (and (setq pt1 (getpoint "\nSpecify break point: "))
            (setq obj (ssget pt1)))
 (setq obj (ssname obj 0))
 (setvar "osmode" 0)
Please edit your post and add required code tags.
Thank you so much, guys! it works perfectly with osmode set to 544 (intersection and nearest) :)
