Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2014
    Sep 2013
    4
    Default Finding Inertia Values about the centre
    Hi
    Is there a way to create a macro which would find the inertia of a region out the (0,0)?
    Currently, I have to Massprop the object, draw a line from (0,0) to the centre of the object, move the object from the end of the line to the centroid, and then massprop it again to get the correct Ixx and Iyy values.
    I have looked into creating a macro for it, but I don't know how to use the initial centre values to move the object to (0,0). Is there a way to do this via amacro?
    If not, is there any other method unknown to me to find the Iyy and Ixx values of an object as if it is sitting at (0,0)?
    Thanks in advance, hope this all makes sense.
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,902
    When you run massprop there is an option to send results to file, what you can do is read this file and using this info move object to the required point then rerun massprop again. Its been a while since I did this. Will have to do a bit of home work.
    Full Member
    gtwatson's Computer Details
    Win 7 enterprize
    Hewlett-Packard HP Z800 Workstation
    Hewlett-Packard 0AECh D
    3.47 gigahertz Intel Xeon (2 installed)
    24 Gb
    NVIDIA Quadro 2000
    NEC EA261WM (2)
    Structural
    gtwatson's Discipline Details
    Structural Engineer
    Structural
    AutoCAD 2016
    Jan 2009
    Houston, Tx
    27
    I wish ACAD would output the MOI through the centroid for the Ixx and Iyy plus the Ixy. From what I've discovered MASSPROP calculates the MOI's about an axis thru 0,0,0. Is there a lisp routine that would draw short lines through the centroid parallel to the X axis and another short line parallel to the Y axis? A line at the angle of the Izz minimum MOI would also be nice so I could find the distance to the shapes outer fiber to calculate the stress due to bending on the Izz axis.
  1. Finding inertia of two sections
    By alrighty93 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th Sep 2013, 10:47 pm
  2. Help!! Decimal place values of Integers in a Lisp, importing values from excel
    By loveboatcaptain in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Feb 2012, 11:33 pm
  3. How to get Moment of Inertia?
    By Darwin0505 in forum AutoCAD General
    Last Post: 12th Dec 2011, 09:49 am
  4. Moment of Inertia
    By nicolas in forum AutoCAD Beginners' Area
    Last Post: 25th Aug 2011, 07:25 pm
  5. How to convert Latitude / Longitude values in to Northing / Easting values in meters
    By Chenna Siva Koteswara rao in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Dec 2008, 11:09 pm
Tags for this Thread
