drennich Posted April 23, 2014 Share Posted April 23, 2014 Using Acad 2011. Border w/title block is in paper space. Seems at random certain layouts sheets will lose the border. Attributes and text stays in place. Tried freezing/thawing border layer, redraw and regen commands but border never comes back.... When I scroll over the layout tab, the preview show the border. Any ideas how to fix this problem? Quote Link to comment Share on other sites More sharing options...
jarr3tt88 Posted April 23, 2014 Share Posted April 23, 2014 Are all layers visible in paperspace? Im running 2014, I can open the layer manager and see what layers are on and off (even in paperspace) See if you can do that, and see if the layer got turned off or frozen in current viewport. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 23, 2014 Share Posted April 23, 2014 Is the Border/Titleblock an xref? Quote Link to comment Share on other sites More sharing options...
drennich Posted April 23, 2014 Author Share Posted April 23, 2014 I can see that all layers are turned on; both in paperspace and modelspace. The border/Titleblock is not an xref. I'm not the only user that this is happening to; my co-workers are having the same problem. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 23, 2014 Share Posted April 23, 2014 Can you post a .dwg with the titleblock? Quote Link to comment Share on other sites More sharing options...
Marie-Christine Posted February 7, 2022 Share Posted February 7, 2022 Hi, It appears i have the same problem here. Does anyone have a solution for me? Thank you! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 7, 2022 Share Posted February 7, 2022 Are you using Plot "Layout" ? Are you using PUBLISH? I had problems with it doing just this. What does extents and fit do plot to pdf for testing. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 8, 2022 Share Posted February 8, 2022 On 4/23/2014 at 4:22 PM, SLW210 said: Can you post a .dwg with the titleblock? Quote Link to comment Share on other sites More sharing options...
Marie-Christine Posted February 16, 2022 Share Posted February 16, 2022 Hi! Here my dwg with a exemple of a table. I also link 2 images, one with of a table and the complete line under ''tableau des finis et quincaillerie'' and one with the line not complete. This problem appears only when i copy or move my table in my drawing. I check with a colleague and the problem seems to appear on her computer too. Thank for the help! test table.dwg Quote Link to comment Share on other sites More sharing options...
