habakay Posted May 3, 2014 Share Posted May 3, 2014 Hi, Is it possible to get coordinates of any text object that assigned to collection? First I add some of texts from selectionset to collection. And then I want to sort these members of collection according to the their coordinates X and Y. But I can not able to get coordinates of a member of collection. Here is my collection: For Each oObj In oSset If TypeOf oObj Is AcadText Then Set oText = oObj If InStr(1, oText.TextString, "Km =") > 0 Then collection_km.Add oText End If End If Next oObj I try this but it gives an error collection_km.Item(i).InsertionPoint(0) Thanks for your advice Quote Link to comment Share on other sites More sharing options...
SEANT Posted May 3, 2014 Share Posted May 3, 2014 Perhaps try: Set oText = collection_km.Item(i) dim dblX as Double dblX = oText.InsertionPoint(0) Quote Link to comment Share on other sites More sharing options...
fixo Posted May 3, 2014 Share Posted May 3, 2014 Try from my codes, slightly edited Public Sub TestCollectTextPoints() Dim ent As AcadEntity Dim objSSet As AcadSelectionSet Dim setObj As AcadSelectionSet Dim oText As AcadText Dim oMText As AcadMText Dim intFilterType(0 To 0) As Integer Dim varFilterData(0 To 0) As Variant Dim dxfCode, dxfValue intFilterType(0) = 0: varFilterData(0) = "TEXT,MTEXT" 'to select texts and mtexts ' Creates an empty selection set. Dim setColl As AcadSelectionSets With ThisDrawing Set setColl = .SelectionSets For Each setObj In setColl If setObj.Name = "mySelSet" Then .SelectionSets.item("mySelSet").Delete Exit For End If Next Set objSSet = .SelectionSets.Add("mySelSet") End With objSSet.SelectOnScreen intFilterType, varFilterData If objSSet.Count = 0 Then Exit Sub End If Dim txtColl As New Collection Dim n As Long n = 0 Dim textArr(0 To 3) As Variant For Each ent In objSSet If TypeOf ent Is AcadText Then Set oText = ent 'store text record in array textArr(0) = oText.handle textArr(1) = oText.InsertionPoint(0) textArr(2) = oText.InsertionPoint(1) textArr(3) = oText.TextString txtColl.Add textArr End If If TypeOf ent Is AcadMText Then Set oMText = ent ' 'store mtextrecord in array textArr(0) = oMText.handle textArr(1) = oMText.InsertionPoint(0) textArr(2) = oMText.InsertionPoint(1) textArr(3) = oMText.TextString txtColl.Add textArr End If Next ent ' write collection to comma delimited file, ' You can use .csv extension instead of .txt Call ahha("C:\Test\MyTextCollection.txt", txtColl) 'release collection at the end Set txtColl = Nothing End Sub Quote Link to comment Share on other sites More sharing options...
habakay Posted May 3, 2014 Author Share Posted May 3, 2014 fixo Thanks for your interest. I edit my codes according to yours, but can not use the coordinates of members. When I try to compare them in "If ... Else If" loop it gives an error again. Can you explain it with an example please? For example : I have three textArr arrays in my collection. Each of these textArr arrays have three properties like this (textArr(0)=oText.InsertionPoint(0),textArr(1)=oText.InsertionPoint(1),textArr(2)=oText.TextString) Is it possible to compare and reordering these textArrs in collection according to their insertionpoints with loop? Thanks. Quote Link to comment Share on other sites More sharing options...
fixo Posted May 4, 2014 Share Posted May 4, 2014 habakay, I think there is enough to use 2 decimal array instead of collection, again, this one is from my oldies, sorry, havent have a time to explain good Option Explicit Sub TestTextSort() Dim ss As AcadSelectionSet Dim ftype(0) As Integer Dim fdata(0) As Variant Dim ent As AcadEntity Dim hndl As String Dim xcoord As Double Dim ycoord As Double Dim i As Integer Dim j As Integer Dim tmp As Variant Dim otext As AcadText Dim txtstring As String ftype(0) = 0: fdata(0) = "TEXT": With ThisDrawing.SelectionSets While .Count > 0 .Item(0).Delete Wend End With With ThisDrawing.SelectionSets Set ss = .Add("SortText") End With ss.SelectOnScreen ftype, fdata If ss.Count = 0 Then MsgBox "Nothing selected" Exit Sub Else ' collect text handles and Y-coordinates of block for sorting them ' below by Y-coordinate from top to bottom: ReDim txtdata(0 To ss.Count - 1, 0 To 3) i = 0 For Each ent In ss Set otext = ent hndl = otext.Handle xcoord = otext.InsertionPoint(0) ycoord = otext.InsertionPoint(1) txtstring = otext.TextString txtdata(i, 0) = ycoord: txtdata(i, 1) = ycoord: txtdata(i, 2) = txtstring: txtdata(i, 3) = hndl i = i + 1 Next ent 'sort blocks by X txtdata = CoolSort(txtdata, 1) ' by Y would be txtdata = CoolSort(txtdata, 2) ' iterate through array and return text reference object ' check if sorting algorithm is right For i = 0 To UBound(txtdata, 1) Set otext = ThisDrawing.HandleToObject(txtdata(i, 3)) Debug.Print otext.TextString Next i End If End Sub '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' ' written by Fatty T.O.H. () 2006 * all rights removed ' ' SourceArr - two dimensional array ' ' iPos - "column" number (starting from 1) ' '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' Public Function CoolSort(SourceArr As Variant, iPos As Integer) As Variant Dim Check As Boolean ReDim tmpArr(UBound(SourceArr, 2)) As Variant Dim iCount As Integer Dim jCount As Integer Dim nCount As Integer iPos = iPos - 1 Check = False Do Until Check Check = True For iCount = LBound(SourceArr, 1) To UBound(SourceArr, 1) - 1 If SourceArr(iCount, iPos) < SourceArr(iCount + 1, iPos) Then For jCount = LBound(SourceArr, 2) To UBound(SourceArr, 2) tmpArr(jCount) = SourceArr(iCount, jCount) SourceArr(iCount, jCount) = SourceArr(iCount + 1, jCount) SourceArr(iCount + 1, jCount) = tmpArr(jCount) Check = False Next End If Next Loop CoolSort = SourceArr End Function Quote Link to comment Share on other sites More sharing options...
habakay Posted May 4, 2014 Author Share Posted May 4, 2014 Thanks for your interest. Quote Link to comment Share on other sites More sharing options...
habakay Posted May 6, 2014 Author Share Posted May 6, 2014 habakay, I think there is enough to use 2 decimal arrayinstead of collection, again, this one is from my oldies, sorry, havent have a time to explain good fixo thanks for your codes. I make use of your codes and fix my codes. But still I have error. The arrays gives "Type mismatch" error. Can you take a look? Here is my codes Option Explicit Const xlFileName As String = "C:\Users\halil.abakay\Desktop\AutoCAD.xlsx" '<--change existing file name here Public Sub Text_to_Excel() Dim SS As AcadSelectionSet Dim ftype(0) As Integer Dim fdata(0) As Variant Dim obj As AcadObject Dim otext As AcadText Dim txtdata_km Dim txtdata_srbst Dim txtdata_dolgu Dim txtdata_yarma Dim counter1 As Long Dim counter2 As Long Dim counter3 As Long Dim counter4 As Long Dim counterveri As Integer Dim k As Integer Dim xcoord As Double Dim ycoord As Double Dim txtstring As String Dim xlApp As Object Dim xlBook As Workbook Dim xlSheet As Worksheet Dim lngRow As Long, lngCol As Long On Error Resume Next '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Set xlApp = GetObject(, "Excel.Application") If Err <> 0 Then Err.Clear Set xlApp = CreateObject("Excel.Application") If Err <> 0 Then MsgBox "Impossible to run Excel.", vbExclamation End End If End If xlApp.Visible = True Set xlBook = xlApp.Workbooks.Open(xlFileName) Set xlSheet = xlBook.Sheets(1) xlApp.ScreenUpdating = True If xlSheet.Range("A1") = "" Then lngRow = 1: lngCol = 1 Else lngRow = xlSheet.Range("a65536").End(3).Offset(1, 0).Row: lngCol = 1 End If '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ftype(0) = 0: fdata(0) = "TEXT": With ThisDrawing.SelectionSets While .Count > 0 .Item(0).Delete Wend End With With ThisDrawing.SelectionSets Set SS = .Add("Textkubaj") End With SS.SelectOnScreen ftype, fdata If SS.Count = 0 Then MsgBox "Nothing selected" Exit Sub Else counter1 = 0 counter2 = 0 counter3 = 0 counter4 = 0 counterveri = 0 For Each obj In SS Set otext = obj If InStr(1, otext.TextString, "Km =") > 0 Then counter1 = counter1 + 1 ReDim Preserve txtdata_km(0 To 2, counter1 - 1) xcoord = otext.InsertionPoint(0) ycoord = otext.InsertionPoint(1) txtstring = otext.TextString txtdata_km(0, counter1 - 1) = xcoord: txtdata_km(1, counter1 - 1) = ycoord: txtdata_km(2, counter1 - 1) = txtstring counterveri = counterveri + 1 ElseIf InStr(1, otext.TextString, "Serbest Kazı=") > 0 Then counter2 = counter2 + 1 ReDim Preserve txtdata_srbst(0 To 2, 0 To counter2 - 1) xcoord = otext.InsertionPoint(0) ycoord = otext.InsertionPoint(1) txtstring = otext.TextString txtdata_srbst(0, counter2 - 1) = xcoord: txtdata_srbst(1, counter2 - 1) = ycoord: txtdata_srbst(2, counter2 - 1) = txtstring counterveri = counterveri + 1 ElseIf InStr(1, otext.TextString, "Dolgu =") > 0 Then counter3 = counter3 + 1 ReDim Preserve txtdata_dolgu(0 To 2, 0 To counter3 - 1) xcoord = otext.InsertionPoint(0) ycoord = otext.InsertionPoint(1) txtstring = otext.TextString txtdata_dolgu(0, counter3 - 1) = xcoord: txtdata_dolgu(1, counter3 - 1) = ycoord: txtdata_dolgu(2, counter3 - 1) = txtstring counterveri = counterveri + 1 ElseIf InStr(1, otext.TextString, "Yarma =") > 0 Then counter4 = counter4 + 1 ReDim Preserve txtdata_yarma(0 To 2, 0 To counter4 - 1) xcoord = otext.InsertionPoint(0) ycoord = otext.InsertionPoint(1) txtstring = otext.TextString txtdata_yarma(0, counter4 - 1) = xcoord: txtdata_yarma(1, counter4 - 1) = ycoord: txtdata_yarma(2, counter4 - 1) = txtstring counterveri = counterveri + 1 Else: GoTo devam End If devam: Next obj End If For k = 0 To counter1 - 1 MsgBox txtdata_km(k, 0) xlSheet.Cells(lngRow, lngCol + 1).Value = txtdata_km(k, 0) xlSheet.Cells(lngRow, lngCol + 2).Value = txtdata_km(k, 1) xlSheet.Cells(lngRow, lngCol).Value = Replace(Replace(txtdata_km(k, 2).TextString, "Km =", ""), ".", ",") lngRow = lngRow + 1 Next k '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' xlSheet.Columns.HorizontalAlignment = xlHAlignLeft xlSheet.Columns.AutoFit xlApp.ScreenUpdating = True xlBook.Save xlBook.Close xlApp.Quit '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' Set xlApp = Nothing Set xlBook = Nothing Set xlSheet = Nothing counter1 = Empty counter2 = Empty counter3 = Empty counter4 = Empty counterveri = Empty k = Empty Set txtdata_km = Nothing Set txtdata_srbst = Nothing Set txtdata_dolgu = Nothing Set txtdata_yarma = Nothing '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' MsgBox "Done" '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' Err_Control: If Err.Number <> 0 Then MsgBox Err.Description End If End Sub Thanks. Quote Link to comment Share on other sites More sharing options...
RICVBA Posted May 7, 2014 Share Posted May 7, 2014 here you can find my proposals, along with some comments (they're all preceeded by " Option Explicit Const xlFileName As String = "C:\Users\halil.abakay\Desktop\AutoCAD.xlsx" ' <-- change existing file name here Public Sub Text_to_Excel() Dim SS As AcadSelectionSet Dim ftype(0) As Integer Dim fdata(0) As Variant Dim obj As AcadObject Dim otext As AcadText Dim txtdata_km ' <--- RICVBA: this way you declare this object as Variant. here it works. you may want to delcare it ina more specific manner: "Dim txtdata_km() As Variant" so as to better control what you actually need it for Dim txtdata_srbst ' <--- see what above Dim txtdata_dolgu ' <--- see what above Dim txtdata_yarma ' <--- see what above Dim counter1 As Long Dim counter2 As Long Dim counter3 As Long Dim counter4 As Long Dim counterveri As Integer 'Dim k As Integer' <--- Dim k As Long ' <--- I'd recommend using same variable type you use for "counter1", "counter2", ... since you're going to add K to them Dim xcoord As Double Dim ycoord As Double Dim txtstring As String Dim xlApp As Object Dim xlBook As Excel.Workbook ' <--- RICVBA: - I'd recommend using "Excel." object specifier. have you addede Microsoft Excel Object 14.0 (or whatever is your installed version) Library to your references? Dim xlSheet As Excel.Worksheet ' <--- RICVBA: - I'd recommend using "Excel." object specifier Dim lngRow As Long, lngCol As Long ReDim txtdata_km(0 To 2, 0 To 0) ' <--- RICVBA: dim your variant array the first time. so as to allow for following statements like "ReDim Preserve ..." ReDim txtdata_srbst(0 To 2, 0 To 0) ' <--- RICVBA: dim your variant array the first time. so as to allow for following statements like "ReDim Preserve ..." ReDim txtdata_dolgu(0 To 2, 0 To 0) ' <--- RICVBA: dim your variant array the first time. so as to allow for following statements like "ReDim Preserve ..." ReDim txtdata_yarma(0 To 2, 0 To 0) ' <--- RICVBA: dim your variant array the first time. so as to allow for following statements like "ReDim Preserve ..." 'On Error Resume Next ' <--- RICVBA: I'D RECOMMEND NEVER TO USE THIS STATEMENT!!! So as to always be able see which problems arise and where 'On Error GoTo Err_Control ' <--- RICVBA: this was missing. while you defined this label (see near the end of your code. but while debugging I'd recommend not to make this active so as to be able to see exactly where problems arise. afte you're quite sure your code runs neatly than you can activate this statement to have a proper error treatment from the user's point of view '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Set xlApp = GetObject(, "Excel.Application") If Err <> 0 Then Err.Clear Set xlApp = CreateObject("Excel.Application") If Err <> 0 Then MsgBox "Impossible to run Excel.", vbExclamation End End If End If xlApp.Visible = True Set xlBook = xlApp.Workbooks.Open(xlFileName) Set xlSheet = xlBook.Sheets(1) xlApp.ScreenUpdating = True If xlSheet.Range("A1") = "" Then lngRow = 1: lngCol = 1 Else lngRow = xlSheet.Range("a65536").End(3).Offset(1, 0).Row: lngCol = 1 End If '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ftype(0) = 0: fdata(0) = "TEXT": With ThisDrawing.SelectionSets While .Count > 0 .Item(0).Delete Wend End With With ThisDrawing.SelectionSets Set SS = .Add("Textkubaj") End With SS.SelectOnScreen ftype, fdata If SS.Count = 0 Then MsgBox "Nothing selected" Exit Sub Else counter1 = 0 counter2 = 0 counter3 = 0 counter4 = 0 counterveri = 0 For Each obj In SS Set otext = obj ' <--- RICVBA: these following statements you can place here outside "If-Then" block, since they apply to every condition you can avoid reapeting them every time xcoord = otext.InsertionPoint(0) ycoord = otext.InsertionPoint(1) txtstring = otext.TextString ' <--- RICVBA If InStr(1, otext.TextString, "Km =") > 0 Then counter1 = counter1 + 1 ReDim Preserve txtdata_km(0 To 2, counter1 - 1) counterveri = counterveri + 1 ElseIf InStr(1, otext.TextString, "Serbest Kazi=") > 0 Then counter2 = counter2 + 1 ReDim Preserve txtdata_srbst(0 To 2, 0 To counter2 - 1) txtdata_srbst(0, counter2 - 1) = xcoord: txtdata_srbst(1, counter2 - 1) = ycoord: txtdata_srbst(2, counter2 - 1) = txtstring counterveri = counterveri + 1 ElseIf InStr(1, otext.TextString, "Dolgu =") > 0 Then counter3 = counter3 + 1 ReDim Preserve txtdata_dolgu(0 To 2, 0 To counter3 - 1) txtdata_dolgu(0, counter3 - 1) = xcoord: txtdata_dolgu(1, counter3 - 1) = ycoord: txtdata_dolgu(2, counter3 - 1) = txtstring counterveri = counterveri + 1 ElseIf InStr(1, otext.TextString, "Yarma =") > 0 Then counter4 = counter4 + 1 ReDim Preserve txtdata_yarma(0 To 2, 0 To counter4 - 1) txtdata_yarma(0, counter4 - 1) = xcoord: txtdata_yarma(1, counter4 - 1) = ycoord: txtdata_yarma(2, counter4 - 1) = txtstring counterveri = counterveri + 1 'Else: GoTo devam ' <--- RICVBA: this you can avoid. since after the execution of whatsoever "If" or "ElseIf" or "Else" blocks of statements the program jumps directly below "End if" statement, thus processing "Next obj" one End If 'devam: '<--- RICVBA: this you can avoid. see preceeding comment Next obj End If For k = 0 To counter1 - 1 ' <--- RICVBA: beware! you dimensioned these arrays with the first index ranging from 0 to 2. while you were treating them as if this was true for its second index !!' <--- ' MsgBox txtdata_km(k, 0) ' xlSheet.Cells(lngRow, lngCol + 1).Value = txtdata_km(k, 0) ' xlSheet.Cells(lngRow, lngCol + 2).Value = txtdata_km(k, 1) ' xlSheet.Cells(lngRow, lngCol).Value = Replace(Replace(txtdata_km(k, 2).TextString, "Km =", ""), ".", ",") MsgBox txtdata_km(0, k) ' <--- RICVBA: see preceeding comment xlSheet.Cells(lngRow, lngCol + 1).Value = txtdata_km(0, k) ' <--- RICVBA: see preceeding comment xlSheet.Cells(lngRow, lngCol + 2).Value = txtdata_km(1, k) ' <--- RICVBA: see preceeding comment xlSheet.Cells(lngRow, lngCol).Value = Replace(Replace(txtdata_km(2, k), "Km =", ""), ".", ",") '' <-- RICVBA: in addition to preceeding comment, txtdata_km is a (dinamic) array, not a object. so it doesn't have any property (like "textstring") to access via a "dot" operator. you previously stored the "textstring" property of "otext" object in the 3rd column of your array, so you have to simply access its position lngRow = lngRow + 1 Next k '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' xlSheet.Columns.HorizontalAlignment = xlHAlignLeft xlSheet.Columns.AutoFit xlApp.ScreenUpdating = True xlBook.Save xlBook.Close xlApp.Quit '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' ' <--- RICVBA: set objects to "nothing" in reverse order with respect to the one followed when instantiating them ' <--- Set xlSheet = Nothing Set xlBook = Nothing Set xlApp = Nothing counter1 = Empty counter2 = Empty counter3 = Empty counter4 = Empty counterveri = Empty k = Empty ' <--- RICVBA: arrays are not objects. you can't set them to nothing. instead set them to Empty' <--- 'Set txtdata_km = Nothing 'Set txtdata_srbst = Nothing 'Set txtdata_dolgu = Nothing 'Set txtdata_yarma = Nothing txtdata_km = Empty ' <--- RICVBA: see preceeding comment txtdata_srbst = Empty ' <--- RICVBA: see preceeding comment txtdata_dolgu = Empty ' <--- RICVBA: see preceeding comment txtdata_yarma = Empty ' <--- RICVBA: see preceeding comment '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' MsgBox "Done" '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' Err_Control: If Err.Number <> 0 Then MsgBox Err.Description End If End Sub bye Quote Link to comment Share on other sites More sharing options...
habakay Posted May 7, 2014 Author Share Posted May 7, 2014 here you can find my proposals, along with some comments (they're all preceeded by " bye I'm very grateful. It works perfect. Quote Link to comment Share on other sites More sharing options...
RICVBA Posted May 7, 2014 Share Posted May 7, 2014 I'm very grateful. It works perfect. fine good work! Quote Link to comment Share on other sites More sharing options...
