gotchy Posted May 11, 2014 Share Posted May 11, 2014 Sorry, I couldn't find the "manage attachments". I enclose the relevant files compressed. Thank you, Gotchy Connector.zip Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 11, 2014 Share Posted May 11, 2014 What version of SolidWorks did you say you are using? (files are not backward compatible) Why aren't your sketches dimensioned/constrained? Sheet metal parts are usually modeled in finished form. (wasn't this already covered here http://www.cadtutor.net/forum/showthread.php?86231-Getting-a-curl-instead-of-a-straight-bend&p=592597#post592597 ) Isn't this a simple Circular Pattern feature? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 11, 2014 Share Posted May 11, 2014 What happens if you do a Ctrl Q on your part? Shouldn't this be a continuation of this thread? http://www.cadtutor.net/forum/showthread.php?86316-To-make-one-solid-body-from-two-parts-that-have-been-assembled Quote Link to comment Share on other sites More sharing options...
gotchy Posted May 11, 2014 Author Share Posted May 11, 2014 I am using Solidworks 7. I started a new thread because I did not have the option to manage the attachment, and a new thread was the only way I had the option. I wanted to send the files. I did use the Combine function a while back and it worked ok, however I do not get the option to do so in this case. Thank you anyway, I will research the help files or the internet further for this issue. Thank you, Gotchy Quote Link to comment Share on other sites More sharing options...
